Diamond file mod for Rebar
SteveC · 48 · 8557
us Offline Monrogue
  • Wooooo!
Re: Diamond file mod for Rebar
Reply #30 on: August 04, 2016, 08:10:41 PM
Yes, you will have to make the notch bigger for it to lock and also so it can open far enough to be inline with the handle. Take your time and I think you'll be fine. The best way to mark it is to lay the Rebar file on top and use it to mark with a fine tip Sharpie. You can use a drill bit to help line up the holes while you mark it.
Cool, thanks for the info Steve :salute:
K-Tibbs
Reply #31 on: August 04, 2016, 09:43:25 PM
Just remember take off to the line then check it ;) If it isn't what you want then cut some more :cheers: Just go slow because there is no rush :D
us Offline Monrogue
  • Wooooo!
Reply #32 on: August 05, 2016, 01:02:24 AM
K-Tibbs
Reply #33 on: August 05, 2016, 08:42:49 PM
I decided to use the file from my old original PST to check to see if it would lock. I didn't want to use my diamond file but they are the same profile.
Notch
Lock up
I made the notch just a hair wider than the Rebar file taking a bit more off the back where the rounded portion is.  The file does lock up
with just a little play. It is a really hard to deploy without a nail nick. I think it would work better to swap positions with the the knife blade. You would then have the cut out in the handle for the file and the nail nick would still be on the right side for the knife blade.
Reply #34 on: August 05, 2016, 09:57:27 PM
Notch
Lock up
The more I think about it Steve the more the swapping of the file and blade make sense :salute:
Reply #35 on: August 05, 2016, 10:21:52 PM
Yes, I think that is the way to go.  :cheers:
us Offline Monrogue
  • Wooooo!
Reply #36 on: August 06, 2016, 12:21:52 AM
Ditto
K-Tibbs
Reply #37 on: December 09, 2016, 06:12:38 PM
Bump for Obi   :tu:
us Offline Obi1shinobee
Reply #38 on: December 09, 2016, 06:25:22 PM
Reply #41 on: July 01, 2017, 03:34:12 PM
Thanks Z it's now public.  f-ing photobucket   :rant:
Reply #42 on: September 09, 2017, 01:54:05 AM
Reply #43 on: January 30, 2024, 11:40:06 AM
Necroing this topic but did PST/PST2 file fitted to Rebar, noticed that some play was there but would deeper nothch solve that play. Im taking today my mod PST2 to apart and thinked would it fit on to Rebar.
Only Tools Matters
Reply #44 on: January 30, 2024, 02:06:22 PM
Now im between 2 choices, i kinda want diamond file to Rebar but also want file and saw to Gerber Center Drive (now that challenge is coming) both requires bit work to make them to work
Only Tools Matters
Reply #45 on: January 30, 2024, 05:35:02 PM
The PST/PST II file fits but has to be grinded on a little to make it work properly  :salute: I have one of these files in a Blast and had to grind it similar to what would fit the Rebar :tu: due to the way it is made for the PST II it slips out of the lock even after grinding but if the tool is closed that isn't a problem, plus this type of file never locked in the tools they were designed for anyways :D
I am actually the owner of the file that Steve cut to fit now and it has been great :woohoo: it fits very well, locks up nice and it really is hard to beat the diamond file :tu: :like:
Reply #46 on: January 30, 2024, 05:49:19 PM
Here is my thread about the Blast :cheers:
It has a few pics of the file being grinded as well :tu:
Total Receipts: $135.65
PayPal Fees: $8.11
Net Balance: $127.54
Below Goal: $172.46
43%
