Mora Club
Grathr · 1882 · 80589
Re: Mora Club
Reply #1860 on: November 09, 2022, 04:11:15 AM
They're great and built like a tank!  I have a couple Companions
cz Offline Chidling
Re: Mora Club
Reply #1861 on: November 09, 2022, 06:16:57 AM
Re: Mora Club
Reply #1862 on: November 09, 2022, 03:39:59 PM
Re: Mora Club
Reply #1863 on: November 11, 2022, 03:58:00 PM
I have a Companion, Basic 546, and Pro. Absolutely great knives.
However, the Basic and Pro have a small gap between the base of the handle and the sides of the blade where water can and does get into. It's only a very narrow gap, but I think I should fill it somehow.
I'm debating trying to melt the handle into the sides of the blade, or fill it with hot glue or something that has a bit of give to it. Any ideas?
Sorry I missed this the first time.  I would close that gap for sure.  I don't think I'd melt the handle tho.  Hot glue does seem the easiest and should work.  If not then you can move on to epoxy.  Good luck if you haven't already fixed this.
Re: Mora Club
Reply #1864 on: November 16, 2022, 03:33:37 PM
Found this MORA CLUB yesterday, so gathered up my current group for a picture.
This is my latest, I believe it is a #1, but other 1s I have seen do not have the finger guard!
The person I purchased from was not aware of the model and indicated the sheath was new as he neglected the first one. But assured me the knife was always cleaned and oiled after any use.  Any help confirming or correcting will be appreciated.
Re: Mora Club
Reply #1865 on: November 16, 2022, 03:50:49 PM
Great collection.  The Mora in question is a #2.  The blade length should be 105mm overall length 215mm.  Its a great one from Mora as are all the classics IMO.  Nice sheath too as its the newer one.
Re: Mora Club
Reply #1866 on: November 16, 2022, 05:26:02 PM
My son got one of those for me.  It's a razor sharp knife!
us Offline Vadim
Re: Mora Club
Reply #1867 on: December 10, 2022, 09:45:38 PM
Re: Mora Club
Reply #1868 on: December 11, 2022, 12:15:11 AM
Vadim, great work!
Re: Mora Club
Reply #1869 on: December 11, 2022, 03:42:20 AM
Re: Mora Club
Reply #1870 on: December 11, 2022, 05:45:24 AM
us Offline Vadim
Re: Mora Club
Reply #1871 on: December 11, 2022, 08:00:18 AM
Thank you all, really appreciate it !  :hatsoff:
us Offline Vadim
Re: Mora Club
Reply #1872 on: December 11, 2022, 08:13:53 AM
Mora Companion Heavy Duty.
I made a handle for it and a left handed leather sheath.
[/url]
« Last Edit: December 11, 2022, 08:20:04 AM by Vadim »
Re: Mora Club
Reply #1873 on: December 11, 2022, 03:41:57 PM
A very nice enhancement to a great knife, making it near perfect.
I had read just last night, that handles originally were made with mahogany, then when difficult to obtain, switch to birch, and painted or stained red to resemble mahogany.
And then finally, the present handles seen today.
Re: Mora Club
Reply #1874 on: December 13, 2022, 12:49:19 PM
(Image removed from quote.)[/url]
Lovely.  :drool:  You even might the proper sheath for me.  :D
us Offline Roc
Re: Mora Club
Reply #1875 on: December 25, 2022, 01:59:10 AM
Mora Companion. Have an hd on the way. Really impressed with the grind.
us Offline VICMAN
Mora Garberg Multi-Mount sheath
Reply #1876 on: April 13, 2023, 10:43:33 PM
If anyone has a Mora Garberg with the Multi-Mount sheath, here is a quick fix so that you can use the ring with the snap and and the ring with the belt loop at the same time without the ring with the belt loop being loose. Just cut a piece of duct tape the same width as the ring with the belt loop and tape it on the inside of the ring and then slide it on the sheath. It will now be snug enough to not slip off.
Click on pictures to see full picture.
* IMG_1878.jpg (Filesize: 214.15 KB)
* IMG_1879.jpg (Filesize: 263.51 KB)
us Offline VICMAN
Re: Mora Club
Reply #1877 on: April 14, 2023, 08:18:48 PM
Nicely done! : :like: :tu: :tu:
us Offline VICMAN
Re: Mora Club
Reply #1878 on: April 14, 2023, 08:20:15 PM
Re: Mora Club
Reply #1879 on: December 26, 2024, 01:34:39 PM
Bump!  It's been quite awhile  :D
* 1000008719-01.jpg (Filesize: 146.79 KB)
Re: Mora Club
Reply #1880 on: December 27, 2024, 01:19:54 AM
Nice bump, Barry! :tu:
Re: Mora Club
Reply #1881 on: December 27, 2024, 03:14:13 AM
Thanks Dan!  Believe it or not, my youngest and I found that one lying in the middle of the road one summer.
Total Receipts: $407.03
PayPal Fees: $21.76
Net Balance: $385.27
Above Goal: $85.27
128%
