Leatherman PST
Gohard · 22 · 1110
au Offline Gohard
  • Leatherman fanatic!!
Leatherman PST
on: August 10, 2016, 12:04:37 PM
Help Identify this year model on this leatherman please.
By the looks of it its closer to a pst2 older version with the square type phillips screwdriver?
* IMG_3312.PNG (Filesize: 203.12 KB)
« Last Edit: August 10, 2016, 12:09:05 PM by Gohard »
Re: Leatherman PST
Reply #1 on: August 10, 2016, 02:07:57 PM
Early model PST II. aren't there any date codes ?
au Offline Gohard
Re: Leatherman PST
Reply #2 on: August 10, 2016, 02:23:33 PM
Not according to the seller
Re: Leatherman PST
Reply #3 on: August 10, 2016, 03:14:26 PM
Sometimes they are hard to read but I'm sure that it would have date stamps.
au Offline Gohard
Re: Leatherman PST
Reply #4 on: August 10, 2016, 03:17:03 PM
Thanks
Re: Leatherman PST
Reply #5 on: August 10, 2016, 03:19:26 PM
I would guess 1996-97 due to the PST handles they used up until they switched to the PST II marked handles.
Re: Leatherman PST
Reply #6 on: August 10, 2016, 03:24:01 PM
Steve knows what he is talking about and yes it should have date codes :tu: All LM from 1993 til at least 2004 all have them :cheers: There are a few models that don't now but all the old school ones had date codes once they starting putting them in 93 :cheers:
au Offline Gohard
Re: Leatherman PST
Reply #7 on: August 10, 2016, 03:37:53 PM
Thanks you two. Didn't doubt Steve.
Don't want to ask too many questions at this stage. The seller will start thinking!!
Not many PST II around this area. Seemed a bit odd with PST II insides with PST handles.
Re: Leatherman PST
Reply #8 on: August 10, 2016, 03:49:17 PM
The only bad thing about the early model PST II's are that the scissors had a design flaw which they remedied later on.  It is an easy fix though.
Covered in these threads
http://forum.multitool.org/index.php/topic,62385.msg1161866.html#msg1161866
http://forum.multitool.org/index.php/topic,62441.0.html
au Offline Gohard
Re: Leatherman PST
Reply #9 on: August 10, 2016, 03:59:06 PM
Thanks steve
Re: Leatherman PST
Reply #10 on: August 10, 2016, 04:05:00 PM
Thanks steve
Those are some good threads about the PST II Steve :tu: :D
« Last Edit: August 10, 2016, 04:06:03 PM by Poncho65 »
Re: Leatherman PST
Reply #11 on: August 10, 2016, 04:07:13 PM
au Offline Gohard
Re: Leatherman PST
Reply #12 on: August 21, 2016, 08:17:41 AM
Thanks Steve. This one I bought yesterday was al good on the scissors side. But the file is worn out and awl has broken tip.
Now I need some spare parts for this. You were spot on with the Date stamp. 0497
au Offline Gohard
Re: Leatherman PST
Reply #13 on: August 21, 2016, 08:26:34 AM
Thanks Steve. This one I bought yesterday was al good on the scissors side. But the file is worn out and small flat has got a broken tip.
au Offline pietervn
Re: Leatherman PST
Reply #14 on: August 21, 2016, 10:11:45 AM
Nice find GoHard!!!
They did not come with an awl only the PST did. Post a pic of the tool once you get it. It is usually the small screw driver that gets bent or broken.
I can help with a PST file in reasonable condition. I also have a few spare drivers. Let me know what you need.
Cheers,
Pete
au Offline Gohard
Re: Leatherman PST
Reply #15 on: August 21, 2016, 10:33:49 AM
Thanks Pieter. Correct about the awl. Realised after I posted. Also need to get the proper tool to undo the screws.
au Offline pietervn
Re: Leatherman PST
Reply #16 on: August 21, 2016, 11:30:34 AM
Get into contact with Loki-mobile, I have a set he makes and they are fantastic. He might have some parts too, PM him with a description.
The screws may be a little hard to get out, use patience. Let me know if you need any help. I have taken a few PST's and PST II's apart.
Cheers,
Pete
au Offline Gohard
Re: Leatherman PST
Reply #17 on: August 21, 2016, 11:34:37 AM
Thanks. Will do.
au Offline pietervn
Re: Leatherman PST
Reply #18 on: August 22, 2016, 02:27:19 AM
I have these
Pete
* IMGP2814.JPG (Filesize: 120.36 KB)
* IMGP2817.JPG (Filesize: 117.91 KB)
au Offline Gohard
Re: Leatherman PST
Reply #19 on: August 22, 2016, 03:04:16 AM
Thanks Piet. PM sent
Re: Leatherman PST
Reply #20 on: August 22, 2016, 03:20:15 AM
A big +1 about the loki-mobile wrenches as well :cheers: I have 2 of the 4 way wrenches and they have been very useful and are a excellent fit as well :tu: I also agree that he has many parts as well :like: Good luck with the modding and restoration
au Offline Gohard
Re: Leatherman PST
Reply #21 on: August 22, 2016, 04:30:59 AM
Thanks poncho
