The Great Gallery Reorganisation Project Hello Playmates / Knights,
Welcome to another
TL:DR post from your friendly Wiki editor
This post will only be of interest to Wiki gallery/image users - Although Wiki editors please read!
Introduction Who here uses (ie browses) the Wiki galleries?
I know I did not.
From time-to time I have to upload a picture and that was the only time I ever used them.
But here is an interesting statistic
- The galleries in the Wiki get over
600 hits per day and that is the hits to the galleries themselves -
Not the hits to the images in the galleries - Which are counted separately.
Or put another way the 91mm main menu page has had about 350k hits, during the life of the Wiki, the 91mm gallery has had 225k hits - ie the galleries are browsed nearly as much as the main pages
Interesting - eh? Gallery Structure The galleries are organised in a hierarchical
family tree structure with four main roots:
Victorinox, Victorinox Delemont, Wenger and
SwissBuck.
The level below the roots are galleries for the various families of models according to their
sizes (length)
The galleries are accessed via the small icons on the right of the size menu box - which is on the right hand side of a Wiki screen on your PC.
Any galleries contained in (ie below) a certain gallery are called
sub-galleries. They always appear at the top of the page when viewing a gallery
A gallery page, when displayed contains sixty images!
The Problem / Reason for Change Anyway, I was looking at the galleries and some were 3,4, or 5 pages long ie contain
180,
240 or
300 images. The Wenger 85mm gallery had
8 pages!
Aaargh. In addition to this, all the images appeared to be in
totally random order (more about that later) !
- For me this is unusable / unmanageable - So I decided something had to be done about it! New Sub-galleries I set about creating new sub-galleries in all the main size galleries to contain groups of images.
To give you a simple example:
The 93mm images were all in one 93mm gallery (apart from the Black Beauty images - for some reason!!) - This gallery stretched over
four pages.
So I created new
Farmer,
Soldier and
Pioneer sub-galleries and moved the relevant images into those galleries
- So now the main gallery is just
two pages long and is
much more manageable.
All-in-all, there are about
fifty new sub-galleries and over
1,000 images have been moved! The creation of sub-galleries is always specific to the images in the parent gallery and which new groupings for sub-galleries made sense for that parent gallery
- Check out the galleries - You'll see what I mean This move seems to have been successful as within a week or so of the move the new galleries had had about 2,000 hits - And now, for instance, the new 111mm sub-galleries alone have had over 2,600 hits!
New Gallery Access Buttons and New High Level GalleriesFour brand new
gallery access buttons have been created - two each for Vic and Wenger - These are for the
Series / Catalogues and the
Tools / Tangs galleries.
They can be found in the logical spot on the right-hand menu.
Several new Series sub-galleries have also been created.
I was never sure why we did not have these access points to the galleries in the first place - So am very happy with that change.
New Image Sequence in the GalleriesI was looking at two new sub-galleries I had created which really should have been next to each other on the screen and they were not. This was irritating!!
So I dug into the gallery configuration options and made an
amazing discovery........
There are options to set the sequencing of the gallery images - This was set to creation date sequence order.
Ie All the images in the galleries are sequenced by the date they were created - Which, of course, with multiple editors over many years, means the images are in random order.
But guess what? - They can be in alphabetical order, which makes much more sense!!
So now all the images in the galleries are in alpha order -
- Why they were not like this in the first place is also a mystery! New Image NamingWell everything in the gallery is now in alpha order - But how did this sequencing work out?
Think about an image of a Pioneer:- It could be named Red Alox Pioneer, Pioneer Red Alox, Victorinox Pioneer - Alox - red etc etc - and of course depending on the name it would be in a totally different place in the list.
To be honest we were quite lucky on this - As most images are named
Brand Model Feature or
Model Feature - So it did not work out too badly
However I did rename a few hundred images to fit into the alpha list better
Image Naming ConventionEditors Please Note: - When uploading new images please follow this naming convention:
Brand Model - Feature eg Victorinox Pioneer - Red Alox
Or, if appropriate... Follow the naming convention of that particular sub-gallery which may have its own naming convention - eg all VSAKCs images are prefixed with VSACKS YYYY
New Gallery Naming ConventionThis is more relevant to the editors I have created a new gallery naming convention and renamed pretty much all the galleries!! Hopefully this is logical
- eg All Wenger series galleries are all prefixed
'Wenger Series...' eg
Wenger Series - United Woods and all size sub-galleries are pre-fixed with
'Brand - Size - .... ' eg
V - 84mm - Cadets Effect on the Wiki pages You will be pleased to hear that all this renaming re-ordering etc etc has absolutely
no effect on the Wiki pages
- As the Wiki pages all work off gallery and image numeric identifiers - Which have not changed!!
Project for another day As I mentioned the image sequencing is now not bad in every gallery
- A project for another day might be to go through all the galleries to ensure that they all follow the naming convention above.
Instructions for editors uploading images When uploading images please all make sure you load the images to the correct (new) gallery or sub-gallery.
I would suggest this sequence:
- Is the image of a tool, catalogue page or member of a series?
- If so go to the corresponding gallery (via the gallery buttons) and find the appropriate sub-gallery
- If not 1 - Check the size of the model
- Go to the corresponding gallery for that size
- Is the image/SAK a special edition or model in that size for which a sub-gallery exists for that group?
- If so put the image in the appropriate/corresponding sub-gallery
- If not put the image in the main size gallery - In this case it should be just a regular model for that size !!
- If this has not worked - It may mean you need a new gallery - If so please contact me and we can resolve - I think only admins can create new galleries
Of course in all instances follow the naming convention above
Wrap Up I hope, and certainly believe that, these changes will make the galleries much more user friendly for our Wiki users !!
As I mentioned above rather than reading all this waffle...
- Check out the galleries - You'll see how it all works / looks
