October 30 day minimalist SAK challenge
hiraethus · 1369 · 56746
us Offline kaput
Re: October 30 day minimalist SAK challenge
Reply #750 on: October 15, 2016, 06:58:40 PM
15/30 powers gonna be shaking today with typhoons on the coast of Oregon  :o little pocket flashlight rolling with me to be able to get me to the big lights and candles if need be. Already used them both!
gb Offline Oxford_Guy
Reply #751 on: October 15, 2016, 07:11:01 PM
Hope you manage to ride out those storms okay! Love that electrician's sheepsfoot blade , going to have to get me a SAK with one at some point, pity Victorinox don't do an Electrician X yet, though (if they do, hope they continue to leave the keyring off. Never liked them on the Alox knives)
Nice slip BTW, do you find it stops the knife going horizontal in the bottom of your pocket? Where do you get it from?
« Last Edit: October 15, 2016, 07:12:45 PM by Oxford_Guy »
"We broke into Mir using a Swiss Army knife. Never leave the planet without one." - Chris Hadfield, Astronaut
fr Offline m47mu74nt
Reply #752 on: October 15, 2016, 08:53:18 PM
Better having one that you can rip off, than none that you can't add  >:D
nl Offline glenfiddich1983
Reply #753 on: October 15, 2016, 09:20:28 PM
Today still the soldier.
This is my day 15 entry by the way, just to make sure I keep count ;)
[--- arms length ---] (-.-)
                                ^-- where the cat sits
Reply #754 on: October 15, 2016, 10:13:50 PM
On the Alox knives I'd rather have a bail like on the Wenger Standard Issue. I don't have any issue with the key ring on the 91mm models, though
wales Offline magentus
  • mmmmm SAKrelicious
Reply #755 on: October 15, 2016, 10:15:23 PM
+1 Ox-Guzzle. I modded an SI to a Farmer with a Bail and it kicks butt.
WP_20160831_003 by magpie2112, on Flickr
« Last Edit: October 15, 2016, 10:20:43 PM by magentus »
us Offline jalind
Reply #756 on: October 15, 2016, 11:21:01 PM
:nanadance: :nanadance: (;,;)(;,;)(;,;)
Lest we forget to celebrate the new page!
se Offline Fortytwo
Reply #757 on: October 16, 2016, 12:00:22 AM
Day 15
Carried the Soldier again today. Could anyone explain how the cab opener is supposed to work? I can't seem to get it.
us Offline kaput
Reply #758 on: October 16, 2016, 12:18:02 AM
Storm should be fine. I'm about an hour and a half from the coast which is getting the worst of it. Powers clicked on and off a few times, no big.
The electricians great, for me. I would never really use a can opener, and if I did I have a couple hand crank kitchen utensils that do it in 2 seconds. So for me an extra blade is much more utilitarian. Especially the shorter sheepsfoot, with wire stripper. It's great for precision  work or just needing a blade to be half the length of the main blade. And yes an electrician x would be amazing!! I would definitely be owning one!
And the slip is a northwoods/ksf leather slip for my Northwoods Michigan Jack, but I haven't carried it because of this challenge so I've been using the slip for the 2 layer. It works good, and really it depends on the pants I'm wearing whether it rides horizontal or vertical. If I have slim fitting jeans it rides vertical no problem, but if they are looser pants with bigger pockets it can still fall horizontal. I also wear some chino style pants and the slip helps the knife from not slipping out of my pocket unexpectedly.
us Offline JasonJ
Reply #759 on: October 16, 2016, 12:44:30 AM
Day 14: (yesterday)
Needed to trim some stray stems on the front bushes. Works... But not the ideal blade for this.
« Last Edit: October 16, 2016, 12:53:49 AM by JasonJ »
us Offline JasonJ
Reply #760 on: October 16, 2016, 12:52:19 AM
Day 15: (today)
Transplanting some pet grass into a real plant pot. Definitely going to have to clean and sharpen the blade after this... Running it through roots and dirt is rough.
« Last Edit: October 16, 2016, 12:53:21 AM by JasonJ »
us Offline mrynnr
  • SAK Addict
Reply #761 on: October 16, 2016, 01:13:43 AM
Day 15...
If I'm not disqualified from touching a spyderco :facepalm:
« Last Edit: October 16, 2016, 01:15:23 AM by mrynnr »
us Offline jalind
Reply #762 on: October 16, 2016, 01:22:45 AM
Day 15
It works very much like the Wenger "eagle beak" opener. You hook the small tab on the lower portion under the rim on the outside of the can, and then punch the lid with the hook portion. With an "eagle beak" opener, you work the opener counter-clockwise moving the knife backward toward yourself, keeping the hooked part in the cut you've already made and simply slicing more of the can lid. Helps if you keep the hook as close to the rim as possible. Watch how he uses the Wenger eagle beak opener in this video that compares the Wenger to the Victorinox. He uses the Wenger first. Don't make the mistake he did when he started by pushing it in too far. Lots of smaller cuts work very quickly compared to trying to make big cuts in the can lid.
Hope this helps! There is a learning curve to using these openers (Vic and Wenger). I've opened hundreds of C-ration cans with a P-38, Vic and Wenger openers. Once you've used one a few times it gets much easier and you can open one almost as fast as with a typical kitchen crank and cutting wheel opener.
John
« Last Edit: October 16, 2016, 01:30:07 AM by jalind »
John
us Offline twiliter
Reply #763 on: October 16, 2016, 01:27:09 AM
Day 15...
If the Spydie drew blood, then yes, major DQ.  ;)
Reply #764 on: October 16, 2016, 01:29:38 AM
That's sweet, now you've got me thinking about adding scissors to mine, though that's probably a trickier job...
us Offline twiliter
Reply #765 on: October 16, 2016, 01:30:22 AM
I find that with a strategically placed safety pin, you can limit the movement of your carry. I do this when I pocket carry my Spirit, or any 111's, it keeps them vertical.  :tu:
Of course if you use a Vic safety pin from an SOS kit, it works just a little bit better.  ;)
« Last Edit: October 16, 2016, 01:32:38 AM by twiliter »
us Offline kaput
Reply #766 on: October 16, 2016, 01:34:19 AM
Interesting. I'm going to carry my 111 sunday. Maybe I'll tinker around with that. I take it you mean safety pin to "pinch" off the pocket and create a channel so to speak?
Clever  :tu:
« Last Edit: October 16, 2016, 01:36:10 AM by kaput »
us Offline twiliter
Reply #767 on: October 16, 2016, 01:36:05 AM
+1 When you get done with OG's Pioneer X with bail, I would like a Farmer X with bail, we'll keep you busy this winter Mags.  :cheers:
us Offline twiliter
Reply #768 on: October 16, 2016, 01:38:06 AM
Clever  :tu:
Yes exactly, a divider of sorts.
 :cheers: I hardly know I'm carrying the Spirit when it's vertical, it practically disappears.  :salute:
« Last Edit: October 16, 2016, 01:39:58 AM by twiliter »
us Offline Mizedog
  • Mizedog
Reply #769 on: October 16, 2016, 04:59:07 AM
Day 15
Instead of pushing the handle down as you would with other SAK models,  you pull the handle up to cut.  The bent piece becomes the fulcrum.  This is similar to other old can openers that require the point to be looked down through the top of the can.
Sent from my SAMSUNG-SM-N900A using Tapatalk
us Offline Mizedog
  • Mizedog
Reply #770 on: October 16, 2016, 05:09:46 AM
Day 15/30
Went fishing with the Executive today.  It worked for the tackle,
The peeler  wields well at opening sinkers.
Beautiful setting
But, I probably won't use it to clean these:
Reply #771 on: October 16, 2016, 10:40:29 AM
Day 16:
Alpineer:
us Offline cali-SAK-attack
Reply #772 on: October 16, 2016, 11:30:29 AM
 :rofl: :rofl: :rofl: He said OX Guzzle  :rofl: :rofl: :rofl:
Reply #773 on: October 16, 2016, 11:38:28 AM
Day 16:
My Micarta Compact freshly re-finished
us Offline jalind
Reply #774 on: October 16, 2016, 12:37:37 PM
Reply #775 on: October 16, 2016, 02:29:17 PM
Day 16, cadet
Reply #776 on: October 16, 2016, 02:42:10 PM
Charming!  :twak:
Reply #777 on: October 16, 2016, 02:43:21 PM
us Offline twiliter
Reply #778 on: October 16, 2016, 02:56:46 PM
16.
wales Offline hiraethus
  • I brake for cake
Reply #779 on: October 16, 2016, 03:40:13 PM
Cadet again:
