Modding a Wenger Standard Issue with Scissors?
gb Offline Oxford_Guy
on: October 16, 2016, 11:22:42 AM
How straightforward would it be to mod a Wenger Standard Issue to take scissors? As I've mentioned in a few places elsewhere, I'm not a fan of the keyring on the 93mm SAKs, as find it digs into the palm of my hand (but don't find this an issue on the 91mm knives), but I do like to be able to dangle my SAKs from a Tec P7 clip - this is one of the reasons I've recently purchased a Wenger Standard issue, as it has a bail. I'd like scissors, though, so was wondering how difficult a mod it would be to add scissors to this and retain the bail?
Is it possible to replace the hollow rivet with one long enough for a 3-layer knife?
Is it possible to use the scissors and backspring from the Pionner X with a Wenger Standard Issue, would they fit without much/any modification? TBH I'd prefer the scissors from a 91mm model with the nail nick on the "correct" side, but how would you then do the back spring?
"We broke into Mir using a Swiss Army knife. Never leave the planet without one." - Chris Hadfield, Astronaut
id Offline jaya_man
Re: Modding a Wenger Standard Issue with Scissors?
Reply #1 on: October 16, 2016, 12:33:37 PM
I've read somewhere in this forum that the backspring from a 93mm solo would work well for scissors... just enlarge the pivot hole on the scissors.. maybe do a little mod to the backspring so that scissors would sit well...If my memory serves me right...
not to sure how to peen a hollow rivet though... adding scissors layer would make the SI thicker, a new custom bail would be required.
Reply #2 on: October 16, 2016, 02:40:42 PM
Yes I peening the hollow rivet and creating a custom bail could be the tricky parts...
wales Offline magentus
  • mmmmm SAKrelicious
Reply #3 on: October 18, 2016, 09:58:55 PM
The peening is quite tricky. I used a fluted driver bit to widen the rivet - very slow and painstaking process - I had 3 rivets and the first one cracked after a while, but the second one worked. I think I still have a stainless steel one if you want it (a kind member here made them up for me). I will measure it to see if it's long enough for what you want. (That's what she said).
The bail is straightforward enough. I used wire from a coat hanger - pliable but strong. I was pleased with the results and it's stood up to some proper work so far.
wales Offline hiraethus
  • I brake for cake
Reply #4 on: October 18, 2016, 10:36:50 PM
I can't remember if yours is a Wenger or a Vic, magentus.  I have a feeling that the hollow rivet in the Wengers is larger than the pin on the Vic - something tattosteve said a while back - but I've not taken one apart to check.
Either way, it should be reasonably straightforward to do - might just need to drill out the scissors pivot to suit.  And source a hollow rivet ...
Reply #5 on: October 18, 2016, 10:41:03 PM
Thanks, sounds like the mod might be a bit advanced for me currently, but maybe for the future...
ca Offline Syph007
  • SAK Surgeon
Reply #6 on: October 19, 2016, 12:22:01 AM
Yes the wenger hollow rivet is 3.5mm vs standard rivet of 3mm.
The mod is possible for sure, but making the hollow rivet is a pain.
Modding thread : Here
Website : WWW.SAKModder.com
Facebook : SAKModder
Instagram : robertjlessard
Reply #7 on: October 19, 2016, 02:41:03 PM
That's a shame, a Soldier/Standard Issue on a bail with scissors would be pretty much an EDC "grail" for me...
ca Offline Syph007
  • SAK Surgeon
Reply #8 on: October 19, 2016, 02:48:08 PM
It could be done but I think the easiest would be to peen a rivet then machine a conical hole on each end.   Or would it need to to all the way through.  Either way that should work.  Finding a good bail material is harder as it should be made of spring steel or I guess Ti rod.  You don't want it to bend once it's installed.
« Last Edit: October 19, 2016, 02:50:43 PM by Syph007 »
Reply #9 on: October 19, 2016, 03:04:22 PM
I don't think the hole would need to go all the way through as long as the machined holes would deep enough for the bail to be a secure fit. I agree you don't want the bail to bend once fitted, Titanium would be nice...
Reply #10 on: October 19, 2016, 09:21:29 PM
Bicycle spokes work great for bail material.
http://forum.multitool.org/index.php/topic,63965.0.html
« Last Edit: October 19, 2016, 09:23:27 PM by SteveC »
