What modded SAK Setup would you call perfect?
Poncho65 · 162 · 14083
Re: What modded SAK Setup would you call perfect?
Reply #30 on: November 13, 2016, 03:41:30 AM
Still without an inline awl :-\ :D I have decided to start disassembly of my other two donors >:D :ahhh I have already popped off the scales of the Champion and took all the extras like the pin, pen, T and T out and put them aside in a spare Altoids tin :cheers:
Just wondering now though :think: What is the best way to take off the bushings and still be able to reuse the pin stock?  I am thinking a drill would be best and go slowly as to not mess the bushing up but would a file of some type be better :shrug:
Also what is the best way to take out the pins in the pruner :think: Drill? Or since I am not reusing anything but the blade would a file be quicker?
20161112_195915 by Poncho 65, on Flickr
20161112_200747 by Poncho 65, on Flickr
20161112_200752 by Poncho 65, on Flickr
Reply #31 on: November 13, 2016, 03:42:03 AM
New page banana man dance
:nanadance:       :nanadance:
id Offline jaya_man
Reply #32 on: November 13, 2016, 03:49:39 AM
Start on the backside with the corkscrew side facing up... drill the holes using 2.5mm and 2.2mm drill bits respectively... gently loosen and remove to bushing for later use...
I use nail punches to tap out the pins slowly... do this layer per layer so that it will be easy to lay out all the parts... easier this way to remember which goes where... that's how I took this pic
Reply #33 on: November 13, 2016, 04:29:22 AM
Awesome jaya thanks for the tips buddy :cheers: :cheers: :cheers:
That diagram will certainly help as well :like:
id Offline jaya_man
Reply #34 on: November 13, 2016, 04:39:18 AM
Good luck buddy... :cheers:
wales Offline hiraethus
  • I brake for cake
Reply #35 on: November 13, 2016, 08:48:04 AM
Poncho, have a read of this: http://forum.multitool.org/index.php/topic,9808.0.html - I found it very helpful. :tu:
I'd file the ends of the pins on the pruner - as you don't need to keep the scales there's no need to worry about wrecking them.
Reply #36 on: November 13, 2016, 04:13:13 PM
You would think I would have known to read that first :facepalm: :whistle: I did read it when Gareth first posted it but after 7 years guess I forgot everything I read in it :D Thanks for the link Hi and yes the file route on the pruner seems to be the most effective way to get the blade out since I am not saving the sales on it :tu:
Reply #37 on: November 13, 2016, 04:13:52 PM
Thanks buddy :cheers:
« Last Edit: November 14, 2016, 06:46:53 PM by Poncho65 »
id Offline jaya_man
Reply #38 on: November 14, 2016, 02:16:52 PM
Hmmm, kinda got me thinking... Now I have the urge to build a Ranger with minimal backtools (with just corkscrew and awl) and replace the small blade with an inline awl... :sigh:
Reply #39 on: November 14, 2016, 03:38:46 PM
If not for wanting the inline Phillips, that would be the way I went pretty much as well :cheers:
Reply #40 on: November 14, 2016, 06:36:49 PM
Poncho, if you save the scales someone else might be able to make use of them?
Why not practice with the drill, if doesn't matter if you wreck them anyway? Good practice for if you ever want to save the scales?  :D
Reply #41 on: November 14, 2016, 06:46:37 PM
Someone want Claude the Cat scales :D That is what someone etched in them anyways :ahhh They are not to bad of shape so I may try and drill them out and put a saw in it maybe :think: Good idea Pablo :cheers: :like:
Reply #42 on: November 14, 2016, 06:49:34 PM
No problem, just my 2 cents. :D
I'm just of the opinion that if you have a alox knife to disassemble and the scales don't matter, its a great opportunity to practice your fine drilling!
And if you make a thin alox with saw...
 :worthless:
« Last Edit: November 14, 2016, 06:50:52 PM by Pablo O'Brien »
us Offline Aberdrew13
Reply #43 on: November 14, 2016, 09:07:00 PM
I think a good modded SAK would be a tool only SAK to pair with a dedicated folder.
Maybe I can attempt this soon.
Who knows I may try something along this lines as well :think:
I'm thinking, opening layer, magnifying glass and inline Phillips pliers, scissors, maybe saw and file.  Backside Phillips, hook, chisel, and awl on back.....
If my text is in blue, read it with sarcasm.  That is how it's meant!
Reply #44 on: November 14, 2016, 10:47:51 PM
 :worthless:
I meant about drilling the pruner pins out ;) I may try and put a saw in this and it will be a saw and only a saw :D I will def take pics of whatever I do though :cheers:
Reply #45 on: November 14, 2016, 10:48:30 PM
I would  :like: to see this if you make it cause it sounds awesome  :cheers: :cheers: :cheers:
Reply #46 on: November 15, 2016, 05:32:45 AM
Still without an inline awl but I figured I would go ahead and disassemble and clean the champion and take out the pruner blade to prepare for my mod :tu:
20161114_183213 by Poncho 65, on Flickr
20161114_185645 by Poncho 65, on Flickr
20161114_185648 by Poncho 65, on Flickr
Then after I got it apart I put it all in warm soapy water to soak :cheers: After soaking for a bit I went in with a toothbrush and cleaned it all up :tu:
20161114_192422 by Poncho 65, on Flickr
Reply #47 on: November 15, 2016, 05:40:12 AM
After drying it all I figured I would give it a go and see how it was going to go :D I wanted to see if the pruner blade would go into the opening layer :tu:
20161114_204513 by Poncho 65, on Flickr
I realized that I was going to have to make a spacer and I just happened to think about an old Chinese knock off SAK I had taken apart many years ago (it probably was falling apart anyways :whistle: :D ) I found the can opener and marked it to make a spacer :cheers:
20161114_202713 by Poncho 65, on Flickr
I then took my Dremel and went to work on it :cheers:
The result was a very decent spacer that was the right width :like:
20161114_203639 by Poncho 65, on Flickr
Reply #48 on: November 15, 2016, 05:45:47 AM
Now back to assembly :cheers: It went smoother than I thought and I used a Champion that I already had to go by for putting it back together :tu:
20161114_214308 by Poncho 65, on Flickr
I ended up not having enough pin stock to finish with bushing and peening :facepalm: but I did get it back together enough to test it all and I am happy with the result :like: After I get some new pin stock and get the inline awl I am confident that I will be very satisfied with my new creation :cheers:
20161114_214327 by Poncho 65, on Flickr
20161114_214429 by Poncho 65, on Flickr
Reply #49 on: November 15, 2016, 05:46:27 AM
Now I am wondering what would be a good color for some scales :think: :D
Reply #50 on: November 15, 2016, 05:50:03 AM
Nice work P   :cheers:
Reply #51 on: November 15, 2016, 06:05:30 AM
Thanks Steve :hatsoff: Wasn't as hard as I thought it was going to be :cheers: Just wished I had the awl and long enough pin stock and I would have new scales ordered for this and it would be in my pocket ASAP :like:
id Offline jaya_man
Reply #52 on: November 15, 2016, 06:10:15 AM
Awesome work Poncho
Reply #53 on: November 15, 2016, 06:17:41 AM
Awesome work Poncho
Thanks jaya :cheers: All the encouragement I got on here about the mod and the tips and advise sure came in handy :tu:
Reply #54 on: November 15, 2016, 09:23:16 AM
Nice!
I especially like the spacer that you made.  :like:
wales Offline magentus
  • mmmmm SAKrelicious
Reply #55 on: November 15, 2016, 11:46:33 AM
Great work Ponch! I love the pruner blade idea.  :salute: Looking forward to seeing it finished.  :cheers:
Reply #56 on: November 15, 2016, 11:49:50 AM
Thanks gentlemen :cheers: I am very much looking forward to this to be finished as well :tu: :D I have already learnt a few things from the experience as well :cheers:
00 Offline Mechanickal
Reply #57 on: November 15, 2016, 12:02:49 PM
Custom SAK... Custom scales!!
Atleast you can give it a try... if it doesn't work you can still buy something else... nothing to lose ;)
Reply #58 on: November 15, 2016, 01:59:48 PM
I have thought of wood :cheers: But I want this SAK to have all the bells and whistles of Plus scales and I don't know if I would have the patience to add all the slots :think: :D
Reply #59 on: November 15, 2016, 02:34:11 PM
