Quote from: Yalius on March 16, 2017, 02:57:17 AMLet's see, let's see, let's see... ah, heck, this should be easy...What's the longest Leatherman multi when closed?Is it the LM Genus MT (pruners) ?
Quote from: gregozedobe on March 16, 2017, 07:14:41 AMQuote from: Yalius on March 16, 2017, 02:57:17 AMLet's see, let's see, let's see... ah, heck, this should be easy...What's the longest Leatherman multi when closed?Is it the LM Genus MT (pruners) ?Whoa, didn't even know such a tool existed
Quote from: gregozedobe on March 16, 2017, 07:14:41 AMQuote from: Yalius on March 16, 2017, 02:57:17 AMLet's see, let's see, let's see... ah, heck, this should be easy...What's the longest Leatherman multi when closed?Is it the LM Genus MT (pruners) ?This is correct!
HmmmmBear & Sons Bird Shears, Gerber Cable Dawg, Paul Chen Multitasker
I guess I will go then What function came out on the OG Supertool that was later also included on the PST, as it didn't have this function from the beginning?
Quote from: Poncho65 on March 18, 2017, 05:38:17 AMI guess I will go then What function came out on the OG Supertool that was later also included on the PST, as it didn't have this function from the beginning? I'll guess it's the hard wire notch.
Quote from: David on March 18, 2017, 06:34:09 AMQuote from: Poncho65 on March 18, 2017, 05:38:17 AMI guess I will go then What function came out on the OG Supertool that was later also included on the PST, as it didn't have this function from the beginning? I'll guess it's the hard wire notch.That is correct David Now what question do you have in store for us
Measuring markings on PW II, but not on PW.Also, I think the PW was stainless, but the first generation of PW II were chrome-vanadium.
Genus combination wrench/diamond file? If that's not counted then the Piranha?
What does the Crunch have in common with the Spirit?
Quote from: zoidberg on March 21, 2017, 07:50:09 AMWhat does the Crunch have in common with the Spirit?You can have both for breakfast? (Image removed from quote.)(Image removed from quote.)
Well, assuming it's the standard Spirit and not the X, they both have only a serrated blade, no plain edge?
Quote from: ddogu on March 16, 2017, 10:15:30 AMQuote from: gregozedobe on March 16, 2017, 07:14:41 AMQuote from: Yalius on March 16, 2017, 02:57:17 AMLet's see, let's see, let's see... ah, heck, this should be easy...What's the longest Leatherman multi when closed?Is it the LM Genus MT (pruners) ?Whoa, didn't even know such a tool existed In that case then you probably didn't know about the Vista and Hybrid pruners either .....http://wiki.multitool.org/tiki-index.php?page=Genushttp://wiki.multitool.org/tiki-index.php?page=Vistahttp://wiki.multitool.org/tiki-index.php?page=Hybrid
