Leatherman needed
Deano3 · 20 · 1013
Offline Deano3
Leatherman needed
on: December 09, 2016, 07:19:23 PM
Hi everyone I am a bit of a tool fanatic and have a few multitools, have the skeletool and a victorinox climber and a sog and gerber etc but I love the leatherman designs and they are for more heavy work , I am a mechanic by trade and want a tool for work and home
I don't think there is one with everything I want but bet everyone says that haha
Want a bit holder for sure already have the leatherman bits, I want a decent blade and pliyers I really wanted the changeable wire cutters as wil get used at work but don't think any I like have them
I don't want a huge tool like the surge preferably something wave sized or charge tti I love the look of these 2 but do any have changeable wire cutters
Thanks dean
Sent from my SM-G930F using Tapatalk
Re: Leatherman needed
Reply #1 on: December 09, 2016, 07:25:32 PM
Welcome aboard Dean  :cheers:
The Rebar has the replaceable cutters you are looking for, and there is a Leatherman bit adaptor available seperately which sits on the Phillips and lets you use the bits  :cheers:
ch Offline Etherealicer
Reply #2 on: December 09, 2016, 07:27:28 PM
Victorinox Spirit is always the answer, and just because they are pretty doesn't mean they can't take a beating :D
Nah... what you want is a Re-Charge / Re-Wave, a Charge/Wave with a Rebar head. There are several options on how to get one.
Easiest but expensive, would be get one from TTC
Alternatively, you can do it yourself, it is really not that hard, me (IT guy) did manage. Now Rebar heads are not that easy to come by, my best bet would be to PM loki-mobile.
Offline Deano3
Reply #3 on: December 09, 2016, 07:42:22 PM
Hi and thanks guys, I am from UK I forgot to add and I have also been hanging around here for ages keep looking at all the awesome tools, I seriously have a problem always buying tools at work and home and they just sit in drawer half the time but want a multitool to use, the last ones look to nice to use but that's what they are for 😂, sorry to be picky but don't like the look of the square rebar I love the wave and the charge tti so think going to have to pass on changeable heads, unless someone knows of bringing them out with them on ? So going to have to look at reviews on the charge tti as just found that and it's another good looking tool packed with cool tools, much more expensive though, the wave is excellent and already watched loads on wave
What's your opinions on wave vs charge tti ?
« Last Edit: December 09, 2016, 08:17:12 PM by Deano3 »
00 Offline Mechanickal
Reply #4 on: December 09, 2016, 08:20:35 PM
The change between TTI, ALX etc is namely to be found in the handle materials.
TTI: titanium
AL & ALX: alox
Between AL & ALX is a small tool configuration difference.
Offline Deano3
Reply #5 on: December 09, 2016, 09:13:01 PM
Thanks for that information , so it's the wave vs tti , he'll of a price difference but I do like the belt cutter, is there no wave with s30v steel I thought there was, might try the wave 😊
Also anyone know what models will he changing next year etc
Reply #6 on: December 09, 2016, 09:24:46 PM
The wave is basicaly a no-nonsense version of a TTI, without belt cutter.
Now, in a pinch, wouldn't you cut your/someone elses seatbelt with the regular serrated blade?
The point ain't THAT sharp.
Above all, under stress chances are you won't be able to aim the seatbelt cutter over the seatbelt.
Better to survive with a cut then to die.
My advice: try looking for a decent second hand wave. I found some for €35 over here.
If you'd like to level it up after some time, go for a TTI.
The Wave is a more then decent tool for the money. And there is a reason it's one of Leatherman's most sold tools...
Offline Deano3
Reply #7 on: December 09, 2016, 10:23:56 PM
Is there any sites in uk what sell second hand multitools etc
Reply #8 on: December 09, 2016, 10:24:58 PM
I believe they occasionally pop up on Gumtree
Offline Deano3
Reply #9 on: December 09, 2016, 10:35:37 PM
Thanks I will have a look any other sites in uk ?
Offline Deano3
Reply #10 on: December 09, 2016, 10:55:27 PM
If I end up buying new there is option for engraving and it will be a present off my kids for Xmas so might engrave or does it fade and end up looking messy  ?
Reply #11 on: December 10, 2016, 08:32:30 AM
Engraving lasts as long as your tool ;)
It makes for a wonderfull present, but you'll have to hurry...
Offline Deano3
Reply #12 on: December 10, 2016, 09:19:04 AM
Even if it is the lazer engraving so not actually cutting into knife but on top of it ?
Reply #13 on: December 10, 2016, 09:24:06 AM
It etches a darkened text/logo on the tool.
I've seen some abused tools that still had their laser etch perfectly readable.
It's one of the nicest ways of etching in my oppinion.
Rest asured, it'll last.
Reply #14 on: December 10, 2016, 09:28:39 AM
Keep in mind though, if you order a laser etched tool online, you position the etching correctly.
Because some sites not only let you choose the engraving, but also the location of the etching (blade or handle)
Sometimes you can even virtualy position your etching on the product to choose where it'll be etched.
In this case you have to make sure you won't etch over any other brand/type markings on the tool.
Offline Deano3
Reply #15 on: December 10, 2016, 09:46:26 AM
OK thanks and we're you think is best tool or blade, on blade least it's hidden until you want to see it sure both will be excellent thanks a lot for help and I will be hanging around a lot more and sharing my experiences 😉
fi Offline Padre
Reply #16 on: December 10, 2016, 10:42:50 AM
Wave is a good tool to go. I have been using both Wave and TTi at work. TTi is better if you have small hands, because Wave opens wider. Other than that Wave is a fantastic beater and best MT for the money.
Leatherman:
Charge TTi, AL, Squirt PS4, Surge, Juice XE6, CS4, S2, ST300, Crunch, OHT, MUT, Rebar, Brewzer, Signal, Raptor, Tool Adapter, Croc, Wave, Style CS, Freestyle, Skeletool RX, Micra, Wingman
SOG:
PPP, PowerLock, SwitchPlier 2.0, Paratool, PowerAssist, Reactor, CrossCut, PowerPlay
Gerber:
FliK, MP600 ProScout, MP600 blunt, Dime, MP-1, Diesel, MP400
Bahco:
MTT151, MTT051, MTT121
Knives:
Spyderco PM2, Tatanka, Bug, ZT 0452CF, CS Recon1XL, Benchmade 940-1 and 482
SAKs:
Too many to list here...
Reply #17 on: December 10, 2016, 10:48:40 AM
Personal prefference.
However, if you ever damage the blade, you can have it replaced, but you'll lose the etching.
The handle takes a lot less beating and should last you forever...
-> I <- Would pick the handles.
That way you can enjoy it, and the memories behind it, without having a sharp edge out too!
Offline Deano3
Reply #18 on: December 10, 2016, 12:17:01 PM
Brilliant thanks for all the input everyone and warm welcome
Reply #19 on: December 10, 2016, 01:02:51 PM
You're welcome!
Enjoy your stay and make sure to keep us informed (with pictures!!) Of your new toys :D
