How do I remove the scale with the LCD?
The LCD does not work and I want to clean and check the contacts on my Traveller.
Quote from: bigz89 on January 04, 2017, 03:46:09 AMHow do I remove the scale with the LCD?Hi, I have the same problem and need to open the lcd scale to clean the terminals can anyone tell me how to open it please? I did check that the battery is in the right position before posting
Problem solved, some "dummy" had put the new battery in upside down. Downloaded the manual as well so got it all set up correctly. Thanks for your suggestions.
