Ganzo and Sanremu
cody6268 · 165 · 20574
no Offline Vidar
Re: Ganzo and Sanremu
Reply #120 on: August 31, 2018, 02:43:07 PM
Still really enjoying this 7010 - especially as it's a part of the limited edition 'Beasts Aflame' series
For the price that knife is very good - I'm enjoying mine too :cheers:
"Simple is hard"
"Hard is hard too"
wales Offline magentus
  • mmmmm SAKrelicious
Reply #121 on: August 31, 2018, 02:57:55 PM
:cheers: It's great isn't it! Any pics of yours?
* 20180511_133057.jpg (Filesize: 128.16 KB)
no Offline Vidar
Reply #122 on: September 01, 2018, 04:56:08 PM
It is just regular all steel ones wit the file on the side. I'll see what I can do later :)
"Simple is hard"
"Hard is hard too"
no Offline Vidar
Reply #123 on: September 04, 2018, 12:30:17 AM
So this was what I found of Sanrenmu laying about - I know I got at least a tiny SAK like multitool (that one has a great blade!), and some other folder, but they seem to be in use somewhere. (That is code for: I have no idea where they are).
So from left to right on the first picture:
Sanrenmu 4024LUE-SCX
Sanrenmu 7010 LUC SA
Sanrenmu 7010 (seems I have two)
Sanrenmu 7063AUC-LI great except that the line from the pivot to the lanyard is on the wrong side of the blade center of gravity. A hard pull on the line releases the blade..
Sanrenmu 7056LUK-SK
Sanrenmu 7056LUF-GHP-T4 Good grip and includes a flat driver/ bottle opener, hook blade and glass breaker
* IMG_9225_SRM.jpg (Filesize: 157.18 KB)
* IMG_9228_SRM.jpg (Filesize: 163.71 KB)
* IMG_9232_SRM.jpg (Filesize: 218.08 KB)
"Simple is hard"
"Hard is hard too"
no Offline Vidar
Reply #124 on: September 04, 2018, 07:21:48 AM
Seems I forgot the last one:
Sanrenmu WA731-A1 Quality SAK (
"Simple is hard"
"Hard is hard too"
Reply #125 on: September 04, 2018, 09:56:33 AM
Nice collection! Favourites?
no Offline Vidar
Reply #126 on: September 04, 2018, 02:00:50 PM
It used to be the 7063, but after I jumped down once and suddenly found I had an open knife hanging from the lanyard line I retired that one.
Sanrenmu 7056LUF-GHP-T4 - good grip for my hand. Maybe because it is a bit wider due to the extra tools. That said I have considered doing extensive modifications to it - like removing the glass breaker.. :)
For "civil" use the 7010 is great. It looks stylish and civil. So far nobody has done the "OMG he got a knife" with that one :)
« Last Edit: September 04, 2018, 02:03:02 PM by Vidar »
"Simple is hard"
"Hard is hard too"
Reply #127 on: September 27, 2018, 11:13:02 AM
Ltd ed Black ops Flammable Panther SRM7010
* 20180927_090925.jpg (Filesize: 230.3 KB)
Reply #128 on: October 07, 2018, 01:01:34 PM
I had no idea Sanrenmu made a multi-tool!  :o
Reply #129 on: October 07, 2018, 07:23:34 PM
Doesn't look like a bad design either. Looks to be decently sized, but slim and light enough for pocket EDC.  Unfortunately, it seems discontinued.
Offline helenhendi
  • New User
Reply #130 on: November 23, 2018, 01:14:04 PM
I also ordered this Ganzo F7611-CF on Amazon and I`m in love with this knife, action is so smooth.
Who is interested in here it is a link where I bought
 :spamkiller:
« Last Edit: November 23, 2018, 02:02:15 PM by SteveC »
Reply #131 on: November 27, 2018, 02:31:52 PM
Had this since April and still use it daily at work - plus great fiddle factor. Wish it was UK legal.
* 20181127_132459.jpg (Filesize: 364.07 KB)
* 20181127_132437.jpg (Filesize: 408.93 KB)
Reply #132 on: November 27, 2018, 08:13:31 PM
It sure is a looker, Mags :tu: :like:
Reply #133 on: December 14, 2018, 01:24:12 PM
Darkside Sith Nikki Sixx Mournblade 'Puma Ablaze' ltd ed. 7010 made by the famous Sam Ren Mu. Love this!
* 20181214_121244.jpg (Filesize: 197.83 KB)
no Offline Vidar
Reply #134 on: December 15, 2018, 12:30:03 PM
It seems they make two. I've ordered that one so I will have an up close and personal look soon. I'll do pictures. :cheers:
"Simple is hard"
"Hard is hard too"
us Offline Blackbeard
  • One Day Closer To Death
Reply #136 on: December 29, 2018, 10:39:43 AM
SR Land 910 - Just completed successful brain surgery on this, arrived with stinky Chinese grease that they use on these bearing knives, not sure if the Byrd & tenacious knives are made in same factory or not but similar grease was on those.
Was hesitant on taking it apart cause I ruined 2 T6 bits on my Ruike P801 which has nasty loctite and I gave up, but this one just had some weak reddish one on screws and was easy disassembly/clean and lube,
Very nice action, good lockup, no blade play, almost have it dropping shut after the procedure, razor sharp, a little on the heavy side tho, excellent value at $12, might order another
« Last Edit: December 29, 2018, 10:45:21 AM by Blackbeard »
BB :B:
no Offline Vidar
Reply #137 on: January 06, 2019, 12:26:17 PM
I got the presumed Sanrenmu T4 multitool here the other day. Presumed as it doesn't actually say Sanrenmu anywhere on it. It does look like it though, and it comes from a vendor that sells all things Sanrenmu. (And quite often under silly brand names instead).
Anyway, this thing is slim. Just about 8.8mm thick excluding the rivets. Being fairly wide it is easy to hold onto, while the slimness should make for a decent pocket carry. Build quality seems fine and snappy. The overall feeling in that regard is somewhat similar to a Gerber Dime - err on the better side.
The plier is very slim indeed - just 3.5mm by the root, narrowing down to about 2.3mm at the tip. Not really confidence inspiring, but likely ok for likesized tasks. The cutter area is very short - roughly 3.5mm long. It does cut the tiny stuff I've fed it so far. (Some thin metal string that was laying around).
There aren't a lot of tools on it - plier, knife, file, cross driver, 3 fairly similar sized flat drivers, and a bottle opener. First impression is in the maybe okish category - not up there with the the Sanrenmu/ Böker SAK style tools.
I might have to try and carry for a bit to get to know it. Kind of interesting form factor and build quality seems good, but not quite convinced by the tools as such. Maybe I'll be surprised with use. The SAK style Sanrenmu tools are certainly well made.
* IMG_9792_sanrenmu t4_small.jpg (Filesize: 190.06 KB)
* IMG_9795_sanrenmu t4_small.jpg (Filesize: 233.41 KB)
"Simple is hard"
"Hard is hard too"
ph Offline an0nemus
  • I Tool Therefore I Am
Reply #138 on: March 06, 2019, 12:10:54 PM
Finally got my FH21 and am liking it a lot!
us Offline gerleatherberman
Reply #139 on: March 08, 2019, 04:46:57 AM
(Image removed from quote.)(Image removed from quote.)(Image removed from quote.)
That is quite a good looking knife. Looks well made too! :like:
ph Offline an0nemus
Reply #140 on: March 08, 2019, 04:54:32 AM
It's Ganzo's latest and greatest and I'm luvin how smooth and slim it is. I guess it falls under Gentleman's tactical category
br Offline enricodepaoli
  • New User
Reply #141 on: April 08, 2019, 10:27:37 AM
Several outdoors supply outlets here have begun featuring Ganzo MTs. I've held them and they seem OK.  But like those #@%!! unboxing "reviews" we learn nothing of overall durability or blade metal. I have a 440C Hunter Pro by Victorinox, and the blade has held up excellently, as has the lockback mechanism and the scale material.
Hello! New here at the forum. How long have you had the Hunter Pro for? I’ve been thinking about getting one but I never know durable those scales really are. I always think they will get gummy/sticky or deformed or will just dry out and crack! Or are they as durable as Victorinox classic Cellidor scales?  Many thanks!
us Offline genevabuck
Reply #143 on: May 30, 2019, 10:30:29 PM
I just bought an interesting one.
https://www.ebay.com/itm/Sanrenmu-SRM-8Cr14MoV-Blade-multifunction-tools-knife-7048LUC-PH-T4-/173600661479
Looks good! Except for some reason, I'm a little leery over folding knives with exposed blades.
Reply #144 on: June 26, 2019, 06:10:37 PM
Well, I just got it and neither blade will open. I keep looking for some sort of lock but I don’t see one. Puzzling
Reply #145 on: June 28, 2019, 04:40:31 AM
This thing cuts like a lightsabre, wonder if they are made in Byrd factory, almost identical to meadowlark, good deal at about $10 shipped, only issue is clip screw was installed at an angle, not sure if I should try to fix it or just leave alone cause I'm worried screw will strip
Untitled by randall1910, on Flickr
Reply #146 on: December 08, 2019, 04:14:53 PM
Was given this gorgeous 7010 by Hiraethus - lovely little knife. Thanks chap  :cheers:
* 20191130_135130.jpg (Filesize: 67.2 KB)
* 20191130_135011.jpg (Filesize: 170.41 KB)
Reply #147 on: January 04, 2020, 04:18:38 PM
These 7010's are so nice to carry and play with - brilliant quality
* 20200104_124933.jpg (Filesize: 201.63 KB)
* 20200104_124956.jpg (Filesize: 188.92 KB)
Reply #148 on: January 05, 2020, 04:22:38 AM
Latest Sanrenmu is the 1161. Fantastic. :like:
Reply #149 on: January 05, 2020, 09:24:01 AM
That looks lovely RP  :cheers:
