Favorite Matches!
Poncho65 · 354 · 17208
Re: Favorite Matches!
Reply #300 on: April 10, 2019, 03:06:00 PM
Thanks Poncho.  They might be best as a fire extender paired up with good matches or a lighter  :dunno:.  My mind went to fatwood more or less.
Reply #301 on: April 11, 2019, 12:12:38 PM
If the wind hadn't been a factor they would have lit themselves :salute: at least I will try again when the wind isn't blowing and see for myself :cheers: They are relatively cheap at about $15 for a box of 48 :o So they are priced right :D Not advertised to do anything with outdoor survival or camping is
probably why the prices aren't bad ;)
Once lit though, it burned very well :tu: I really haven't bought many other type firestarters so I can't comment how they stack up against others :cheers: I usually use paper or cardboard to start fires around home but a few of these thrown into a pack with some other matches a striker or a lighter would weigh nothing :like: Worth the purchase to me for sure though :tu:
Reply #302 on: April 11, 2019, 01:16:41 PM
Lots of interesting items in here. :like:
Standard matches were always enough for me. I was going to pick up a nice orange container with those nice stormproof matches, but I talked myself out of it. I may reconsider.
Even a full matchbox was overkill, so I split it into two slender halves. Nice and thin, and still plenty of matches. :cheers:
Reply #303 on: April 11, 2019, 03:23:57 PM
Great way to carry matches in a smaller package :tu: You really ought to try those Stormproof matches by UCO though (regular size or the Titans :like: ) :dd: The Zippo ones are good as well :cheers: It is a different experience than a regular match for sure :salute: :tu:
Reply #304 on: April 11, 2019, 04:30:23 PM
Nice job, RP!  :like:
Reply #306 on: November 02, 2019, 06:07:56 PM
The weather is starting to cool here again :whistle: I have gotten a little money for my birthday and I bought some of the UCO waterproof matches :D no pics but I did try a couple and they work :D I also got one of the Zippo branded match safes and it even keeps the striker dry :like: I will have to get some pics but for not I thought I could light a match under this thread and get it going again ::) :rofl:
Reply #307 on: November 28, 2020, 04:01:44 AM
Well, I didn't light to much of a fire under this thread last time :ahhh :ahhh :ahhh :oops: :D
Have any new matches came out lately :think: I know it is a very small niche in the market but was hoping to find some new info on matches, match safes or anything match related :cheers:
Reply #308 on: November 28, 2020, 09:58:48 PM
I picked up some of these in the grocery store the other day:
Not bad at all. Not as great as the "strike anywhere" matches of yore, but they work nicely if 'struck' carefully on a rough surface.
I rubbed a little paraffin wax on the wooden sticks of a few (being careful not to get any wax on the white tips) and found that they burned a bit longer & hotter. Sort of a Redneck Hurricane match. Not waterproof, but could be a good addition to a match safe.
Reply #309 on: November 30, 2020, 01:36:23 AM
Good ole Diamond Strike Anywheres :cheers: I still have some of the red tipped Strike Anywhere ones that they use to sell along with the newer green tipped ones like you have pictured :salute: I like the idea of using wax to make them burn longer as well :tu: :like:
Reply #310 on: November 30, 2020, 02:41:57 AM
I'm thinking if you coated the entire match, they would be waterproof, but then you would need to remove the wax from the white tip before they would light.  Always a trade-off...
Reply #311 on: February 12, 2021, 01:20:04 PM
Hum... favourite matches.
 :think: :think:
I'd have to say New Zealand vs South Africa. Awlso, any rugby game with the all Blacks, South Africa or Australia.
 :cheers: :tu:
Reply #312 on: August 05, 2022, 01:56:04 PM
I've been using these a lot more lately- they aren't as cheap as some of the others, but as you don't use ten matches each time, they probably even out!
* 16595433099092.jpg (Filesize: 213.84 KB)
Reply #313 on: August 05, 2022, 03:27:03 PM
Exactly Def!  I get so frustrated with matches that flame out a half second after you strike them.
Reply #314 on: August 05, 2022, 05:34:45 PM
Don't get me started!
I live on the ocean- the air is always damp here and almost always windy.  Most matches don't stand a chance!   :ahhh
Unfortunately I am also pretty cheap at times and hate spending money on something that I am literally going to burn!
Reply #315 on: August 06, 2022, 03:05:03 AM
Do you guys use matches regularly?
I have some of those stormproof matches in my fire kit, but they are really just a backup to my Bics.
Reply #316 on: August 06, 2022, 04:06:16 AM
Yeah, I use matches quite frequently for lighting my BioLite camp stove at work.  Since it is usually windy (I'm only a few hundred yards from the ocean) it is easier to drop a lit match into the burn chamber than it is to try and ignite something in the open and drop it in.
Reply #317 on: August 06, 2022, 04:06:33 AM
I went the opposite way.  I now use the long reach lighters for my Coleman stoves.
This is what I do.  I have a Soto extendable which is awesome for lighting stoves, even twig ones and alcohol.
Reply #318 on: August 06, 2022, 04:08:21 AM
I haven’t used anything other than strike anywhere with a wax coated tip in a long time, but have been contemplating giving some stormproof ones a try.  The UCO do look interesting.
Reply #319 on: August 06, 2022, 11:43:53 AM
I haven't tried it, but apparently they stay lit even when dunked in water.
Reply #320 on: August 06, 2022, 04:10:30 PM
I can confirm they do stay lit when dunked in water.  We thought it was hype or some trick but when we tried  :o.  I light rain wouldn't bother those UCO matches IMO.  I'd be pretty confident in wet weather situations tho I am not sure how much wind they can withstand  :dunno:
Reply #321 on: August 06, 2022, 05:58:37 PM
They are some of the best and I have tried it more than once to see if they would stay lit :ahhh :like:
The Zippo brand ones do just as well :cheers:
They also have the regular sized ones (the Zippo ones are more similar sized to the Titan ones) and the ones you have are a bigger more awesome version of the regular ones :o they burn longer and have all the same pluses of the regular sized ones :salute: the regular ones are cheaper though :tu:
Man do I love matches :dd: :D
Reply #322 on: August 06, 2022, 06:49:26 PM
Anything worth doing is worth overdoing.  I will keep using the Titans.  When you are trying to get something to light, it's not a bad thing to have more fire.
Reply #323 on: August 06, 2022, 09:57:46 PM
Totally  :D More fire is more better :D :like:
Reply #324 on: August 08, 2022, 04:27:11 PM
Reply #325 on: August 08, 2022, 07:42:41 PM
I kinda figured you guys would agree with that!
I see Les Stroud and Dave Canterbury talking about having one match and having to live off it, and I'm pretty sure that would mean I was going to die.   :facepalm:
Reply #326 on: August 08, 2022, 08:21:11 PM
 :iagree: me too :ahhh I sure wouldn't want to rely on just 1 match :dwts: :D
Reply #327 on: August 08, 2022, 10:00:15 PM
Yeah they can have their one match but I'll have several UCO and a ferro rod plus some magnesium and fat wood to boot all as back up to my lighter.  While I like to fool with fire I am not going to be relying on a match or a lighter.  I have my emergency fire kit stocked with UCO matches.
Reply #328 on: August 09, 2022, 06:07:18 PM
Yeah I am thinking of picking up a bunch of them to stash in different places.  Short of lighting candles in the house, I cannot forsee a situation where that much fire would not be a welcome thing.
Reply #329 on: August 10, 2022, 01:20:14 PM
I ended up getting a few things for work yesterday at Walmart and was passing the Outdoor section :whistle: I found some of the Zippo Typoon matches :facepalm: I bought the 25 without the waterproof case vs the 15 with the case :D they also have the regular UCO Stormproof ones but I have enough of those for now :D
December Goal: $300.00
Due Date: Dec 31
Total Receipts: $137.67
PayPal Fees: $7.57
Net Balance: $130.10
Below Goal: $169.90
43%
December Donations
