Adjust Blades on SOG Powerplay
Offline RockyRoy
  • New User
on: January 07, 2017, 01:24:33 AM
Good day to all -I hope this finds everyone well and in great spirits .. Ive just received my first SOG product --PowerPlay - and I would like to loosen the tension on the blades - its very hard to open one handed . Its seems straight forward enough but thought Id take a moment to ask if there are any surprises awaiting me . Any experience would be appreciated  thank in advance
us Offline rdub934
Re: Adjust Blades on SOG Powerplay
Reply #1 on: January 07, 2017, 01:50:52 AM
Hi there! I've never handled a PowerPlay, specifically, but basically every multiool can be adjusted by loosening or tightening the pivot screw. I say loosen it an 1/8 of turn and see if it gets a bit easier to deploy. If so, make sure the lock still functions properly. If so, keep going until you get the deployment the way you want it - you're golden. Two things to keep an eye on, though: lock function (should be unaffected but just make sure) and tool deployment (implements should not freely open from stowed position).
Reply #2 on: January 07, 2017, 02:00:11 AM
+1 to everything rdub said.
Also check tools do not wobble side to side after loosening the pivot, and consider trying to lubricate the tool with some mineral oil or 3 in 1. There might just be some "factory gunk" in there that's binding it up. The oil will not only lubricate, but help flush out any debris
se Offline Fortytwo
Reply #3 on: January 08, 2017, 12:40:43 PM
This, my latest and only factory SOG (a Pocket PowerPlier) had a lot of metal grit in it. Especially the badly cast Philips where the pivot hole was more egg-shaped than round. So try some 3 in 1, WD-40 or similar followed by folding the blade in and out a bit and see if that helps to begin with.
Total Receipts: $168.99
PayPal Fees: $9.87
Net Balance: $159.12
Below Goal: $140.88
53%
