This is my latest aquirement, a K9 Dingo which was made by Tom Krein & Daniel Koster in a series of only 50 pieces.
The knife is hardened by Paul Bos himself, and mine has number 13.
Pictures were taken from other forums.
What do you think ?
Specs of the knife:
Steel: CPM3V
Overall length: 26,5 cm
Blade length: 13,9 cm
Edge length: 12,7 cm
Blade thickness: 6,4 mm
Hardness: 59-60 HRC
Edge type: Plain Edge
Handle material: Bead-blasted Green canvas Micarta
Overall weight without sheath: 300 gram
Overall weight with sheath: 400 gram
Specs of the steel used in this knife:
'CPM 3V is a new tool steel made by the Crucible Particle Metallurgy process, designed to provide maximum resistance to breakage and chipping in a highly wear-resistant steel.
CPM 3V offers impact toughness greater than A2, D2,Cru-Wear or CPM M4, approaching the levels of S7 and
other shock resistant grades, while providing excellent wear resistance, high hardness and thermal stability for
coatings.
Intended to be used at HRC 58-60 CPM 3V can replace high alloy tool steels in wear applications
where chronic tool breakage and chipping problems are encountered.
The CPM process produces very homogeneous, high quality steel characterized by superior dimensional stability,
grindability, and toughness compared to steels produced by conventional processes.'
(Source:
www.crucibleservice.com)
