Nice job I've used a bench vice but also wrapped the warmed up knife in a towel and beaten it with a rubber mallet ! Well, it worked
Great job and sharp Climber! Timely in that I've scales on the way to do a replacement, too, as I've never done it before. Luckily I have a vice downstairs
I normally use a small bench vice... otherwise pounding on it with our fists also helpsSent from my iPhone using Tapatalk
Oh and "don't stand on your SAK" is definitely a thing.
Just posted this on the "What did you use your Sak on today?" thread, but it was appropriate here too.Changing scales on a couple of new backup Tinker´s today It takes patience on the vice to get the new scales flush with the outer liners, to give it a factory look. And when you tighten, you have to let it sit for a bit before you slowly relief pressure on it. Don't forget that plastic (cellidor) has some elastic proprieties, when you use pressure to fit it, you have to you tighten and hold it there for a while so it sits and then very slowly release the pressure. If you press and release instantly they will spring up a bit and there will be some gaps between the scales and the liners. P.S.: Oh... and before you ask... Yes, they are all red. I'm a real sucker for the classic red scales and probably always will be
Quote from: Guardian on January 29, 2017, 10:54:50 AMNice job I've used a bench vice but also wrapped the warmed up knife in a towel and beaten it with a rubber mallet ! Well, it worked Just don't use a claw hammer.
