A Lil HELP Please - smooth Alox Cadet - Repair
us Offline cali-SAK-attack
on: February 08, 2017, 02:03:14 AM
 :mail:
Just in............ Came with broken spring on openers.
QUESTIONS  :think:  :D
1 - What DONOR back spring can be swapped in? (does it have to be a smooth alox cadet only? will any others work? etc,etc,etc  :D :tu: )
2 - What size brass pin stock is needed? - (yes i searched but not much out there on SMOOTH ALOX)  :bnghd:  :D  :tu:
3 - Is there a memeber here who has the parts for sale?  :cheers:
4 - Is there a member here who would be willing to tackle the spring swap, who already has spring and brass pin in there vast parts bins already?
5 - Does anybody know who the Advertised company is : "CJB"  :think: ( I searched online = ZIP/ZIPPO/ZILCH )  :D
I would love to fix or have it fixed and TOTE this thang!  :ahhh :drink:
 :whistle: I do have the othe half of the spring.... I put the whole knife in the Sonic Cleaner, when done with 2 cycles on level 3 , I rinsed it in the sink, and the damn thing fell down the drain into the "P" Trap....so I will get it out ASAP  :facepalm: :bnghd: :poh:  :rofl: :D
id Offline jaya_man
Re: A Lil HELP Please - smooth Alox Cadet - Repair
Reply #1 on: February 08, 2017, 02:18:18 AM
I think you can use opener backsprings from regular 84mm cellidors...
Pin sizes are the same as well... 2.2mm for all..
Reply #2 on: February 08, 2017, 02:24:10 AM
 :drink: Thanks , Jaya!
so any 84mm huh ..........  :think: hmmmm pretty sure I have a donor!
2.2mm brass rod - anybody know of a source in USA? nothin on my GO TO: eBAY  :rofl: :facepalm:
us Offline JamesJ
Reply #3 on: February 08, 2017, 06:11:05 AM
You'd of course want a Recruit spring unless you're trying to add an awl on back.
I've never found 2.2mm rod, I make it from 2.5mm.
-JJL
instagram: jamesjlarue (warning, lots of cat pics along with the SAKs)
Reply #4 on: February 08, 2017, 06:32:02 AM
 :cheers: Thanks , James!!!  8)
 RECRUIT donor is what I had in mind from my Doubles Pile  :tu:  - BUT GOOD STINKIN' THINKIN' , Ma Friend! I fergot about back tools.  :-[ :facepalm:
2.5mm I may just have a piece  ??? (Bought a small multi-pack at OSH not long back)  ... TO THE GARAGE >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>
 :ahhh :ahhh :ahhh :ahhh :ahhh :ahhh :ahhh :ahhh
Reply #5 on: February 08, 2017, 08:39:57 AM
UPDATE...........
I had a piece of 3/32" or 2.38mm  :2tu: :woohoo:
Taped off front scale, in prep.  :-\
Gonna go see about the Donor Recruit for spring now >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>   :ahhh
id Offline jaya_man
Reply #6 on: February 08, 2017, 08:53:37 AM
Ah, right not just 84mm opener springs.. Recruit opener springs...
Cali, think you will still need to reduce the pin diameter a bit... Vic's is actually 2.25mm but 2.2mm will do... I would also start with the back scales... just in case the drill bit decides to move about...
Good luck with your restoration... pics please afterwards...
If desired, you might want to add scissors to it... ah ah ah... :cheers:
« Last Edit: February 08, 2017, 08:56:21 AM by jaya_man »
Reply #7 on: February 08, 2017, 09:57:43 AM
REALLY APPRECIATE The HELP and REPLIES , Jaya & James...... Thanks guys  :cheers:  :drink:
:tu: Thanks again , Jaya  :cheers:
Yes,Sir ... I plan on chucking the rod in a hand drill....... and sanding it down a tad. I will keep checking spring holes for fitment.  :tu:
I am only removeing the center pin for this fix .................. but for future reference  , are the pivot pins a different size?  ??? :think:
Taped up knife - Cuz I am a Fumble Fingers  :D
Filed pin flat ( on rear side  :D )
Donor extras removed
Here is where I am at now (pics below) ..................... Gonna center punch pin on alox to drill out, NEXT.
Reply #8 on: February 08, 2017, 09:58:37 AM
Pics Cont...............  :whistle: :D
id Offline jaya_man
Reply #9 on: February 08, 2017, 10:06:29 AM
Removing just a pin might be too hard a task... backspring tension comes into play... but it's worth giving a shot...
Pin diameter is the same for all pins... :cheers:
Reply #10 on: February 08, 2017, 10:24:24 AM
 :facepalm: DANG...LOL....... Crosses fingers an toes , that I only have to do center.  :whistle:  :facepalm:
wales Offline hiraethus
  • I brake for cake
Reply #11 on: February 08, 2017, 10:24:43 AM
Should be possible to do it by only removing the middle pin.  You'll need to open up all the tools and use a vice or clamp to compress the springs into position so you can get the replacement pin in.   Peen the one end first before you push it through - you'll get a better finish that way.  Sand or file a nice long taper on the other end of the replacement pin to help it through the holes.
Reply #12 on: February 08, 2017, 10:27:19 AM
 :salute: 10-4 Thanks , "H"  8) :tu:
id Offline jaya_man
Reply #13 on: February 08, 2017, 10:58:35 AM
Ah, the master has spoken...
Reply #14 on: February 09, 2017, 12:43:06 PM
So it's 3:35 A.M. and I just finished her up.....besides a lil polish and a good sharpening on the Spyderco SharpMaker  8) :tu:
I can only post 4 pics per post .....so might be a couple posts...... But here are some pics of my lil adventure in bringing this knife back to "USER" statis. :tu:
1 - filed off the rivet head on Donor knife to get spring to drop out after I drive the pin out with a Punch.
2 - Pin out & Spring out  :ahhh :tu:
3 - Did the same with the ALOX CADET - Pin out , broken Spring out
4 - Broken spring  :td:  :D
wales Offline magentus
  • mmmmm SAKrelicious
Reply #15 on: February 09, 2017, 12:48:21 PM
3.35AM! You'll be wanted some well earned kip Cali!
Glad you got it done though - your first mod is a good feeling isn't it!  :salute:
Reply #16 on: February 09, 2017, 12:52:29 PM
Pics Cont..........................  :whistle:  :D
1 - With all blades open ..... Cadet into Vice ... Compress springs to line up holes in Scales/Liner/Springs.  8)
2 - Used a broken Drill Bit ...Slightly smaller than Brass pin/rod needed ...... To line up holes.  :tu:
3 - Sanded down 3/32" or 2.38mm Brass rod/Pin stock = chucked it into my Drill and held it on a sanding block with sticky back sand paper applied to it.
Once I got it to correct size, I tapped it into the knife,on a anvil with a hole in it ,so the pin on bottom could extend through.  :tu:
4 - Time to nip the ends , with my fancy schmancy Nippers ........  :D :cheers:
Reply #17 on: February 09, 2017, 12:56:22 PM
Cont ............................  :facepalm:  :whistle:  :D
1,2,&3 - Pin Nipped on both sides , Tested all blades for WALK N' TALK before i get ready to peen!  :ahhh
4 - Time to File the pins flat now that they are Nipped off where I want em.  :tu:
Reply #18 on: February 09, 2017, 12:59:37 PM
cont .................. :bnghd:  :whistle:  :D
1&2 - Both sides Filed Flat .......... READY TO PEEN!!!  :woohoo: :woohoo:
3 - Anvil and Hammer( AKA - Lil' Pecker  :D ) , Prepped to Peen!
Reply #19 on: February 09, 2017, 01:05:14 PM
 :surrender:  :D
1 & 2 - Peened up - tap,flip.............tap,flip..............tap tap flip...............tap tappitiy tap tap FLIP! TAP! FRIGGIN TAP....FLIP!!!!!! :D
3 - Sanded some scratches out of the blade, I think the last guy feathered n' scmooothed out the blade on a GUTTER CURB :facepalm: :D
I used 1000 grit wet dry and called her good ta GO >>>>>>>>>
More pics tomorrow after a lil polish and sharpening session.
THANKS AGAIN GUYS FOR THE ADVICE/HELP !  :cheers: :cheers: :cheers: :cheers: :drink: :drink: :drink: :drink:
« Last Edit: February 09, 2017, 01:50:00 PM by cali-SAK-attack »
Reply #20 on: February 09, 2017, 01:08:02 PM
Thanks , Mags!
I work nights , so I was just killin time....AKA Milkin' the clock  :D
Yep not my first pocket knife repair, but my 1st SAK  :tu: - Wanna try some others.........BUT,  still not sure about the Bushing thang on the Cell units. :-\
We'll see ........................  :whistle: :D
« Last Edit: February 09, 2017, 01:09:40 PM by cali-SAK-attack »
Reply #21 on: February 09, 2017, 01:11:16 PM
Lovely job!  :cheers:
us Offline twiliter
Reply #22 on: February 09, 2017, 01:16:04 PM
Good work Cali, that one should be easy to carry!  :cheers:
id Offline jaya_man
Reply #23 on: February 09, 2017, 01:47:38 PM
Awesome resto work Cali... Just lovely... clean job on the peening... Me likey... a looot... :like: :like: :cheers:
Reply #24 on: February 09, 2017, 01:50:49 PM
  8) Thanks Guys!  8)   :cheers:
us Offline FolderBeholder
Reply #25 on: February 09, 2017, 02:15:39 PM
Amazing job!  Thanks for all the pics too!
Quick question, is that painter's tape?  Looks like it might be plus it doesn't leave residue when removing correct?
Reply #26 on: February 09, 2017, 02:37:18 PM
Nice job cali  :salute:
us Offline JamesJ
Reply #27 on: February 09, 2017, 08:00:38 PM
Allright! Get that in your pocket and smile every time you use it. :tu:
-JJL
Reply #28 on: February 09, 2017, 11:29:09 PM
Thanks for the comments , Lisa , Steve & James!  :cheers: :cheers:  :cheers:
 :climber:
Reply #29 on: February 09, 2017, 11:31:47 PM
Thanks again , Lees'  8)
Yeppers , 3M Blue Painters Tape........ I love this stuff for projects and craft type stuff..... cuz like ya say: NO RESIDUE! , Even if ya get it wet. :cheers:
Total Receipts: $55.09
PayPal Fees: $3.15
Net Balance: $51.94
Below Goal: $248.06
17%
