Mod for slimming the Swiss Tech Micro Slim 9 in 1:
LEVEL: EASY TIME: 15 minutes (With light tools and a bit of effort, with heavy tools would be a few minutes)
Tools used:
- Victorinox Mountaineer for the metal saw
- SOG EOD Powerlock B63-L for pliers and prying with flat screwdriver.
To see bigger the images click in them
1 There are 2 versions of the Micro Slim:
- welded+pinned (up)
- only pinned (down)
This mod only works for the only pinned
2 Pry the cover and will pop up (with a pry or a screwdriver)
3 Pull out the blade and the spring (with pliers)
4 Pry the metal band to get space for the metal saw (with a pry or a screwdriver)
5 Cut the pins (with a metal saw)
6 Extract the metal band (with pliers)
7 Extract the pins (with pliers)
8 Pry the nail file (with a pry or a screwdriver)
The result:
You now have a slimmed Micro Slim
Weight before: 63,1 g
Weight after: 46,2 g
Weight reduction: +- 27%!
And TSA complaint!!! Wrench, bottle opener and phillips and big flat screwdrivers (no blade and no file).
As a variation you can leave the nail file by not doing the point number 8 (is well fitted and it wil not fall off)
P.S.4. The micro slim is big, but with the reduction of weight is less heavy than the Leateherman PS4 56,4 > 46,2 g. So, is an option
