Help with sanding thin metal strips
Offline max6166
on: October 03, 2008, 09:47:40 PM
I am sanding some liners from a SAK I am working on by hand.
I first tried laying the sandpaper flat on a table and rubbing the liners back and forth across it with my fingers. I wound up sanding my fingers to the point of bleeding though, because the pieces are so small.
If I hold the liners down on the table and sand across the top though, I can only sand one side at a time as my fingers will always be on one side.
Does anyone have any tricks for sanding the entire surface of a small thin piece of metal in one go?
Re: Help with sanding thin metal strips
Reply #1 on: October 03, 2008, 10:01:41 PM
That is a tricky one mate :think:
Reply #2 on: October 03, 2008, 10:26:55 PM
This is why its best to use new liners if possible  :pok: Don't say you weren't warned ;)
I'm afraid I've found no trick.  I start with 400 grit (UK size) and work upwards.  Its not a speedy process but an order of magnitude faster than sanding blades. Whilst you don't need a mirror finish you really do want a very smooth surface.  This is not one of those jobs to rush or skimp on or you'll regret it, right after you've finished peening :D
Neil
Offline max6166
Reply #3 on: October 03, 2008, 10:58:15 PM
I am actually planning on using new liners when I go to build the actual knife. I know it sounds crazy, but I am just trying to restore a couple of the current liners as a learning exercise.  :think:  :D
gb Offline Roadie
  • Hello...is this thing on?
Reply #4 on: October 03, 2008, 10:59:46 PM
Try using a hot glue gun to glue the liner to a bit of wood, that should hold it in place while you sand one side and peel off easily enough to let you turn it over? No idea if it'd work but it's all i can think of! :D
Offline max6166
Reply #5 on: October 03, 2008, 11:17:17 PM
Thanks Roadie! I never would have thought of that.  :cheers:
gb Offline Roadie
Reply #6 on: October 03, 2008, 11:19:00 PM
No problem! Let me know if it works :D
Reply #7 on: October 03, 2008, 11:38:44 PM
Sod that - I just got the Proxxon on it :D
Mind you, they do look a bit naff  :P
  • Benner fan club #003
Reply #8 on: October 03, 2008, 11:49:41 PM
I just steel wool the crud off and slap it back together :P
Total Receipts: $407.03
PayPal Fees: $21.76
Net Balance: $385.27
Above Goal: $85.27
128%
