111mm variant with inline awl instead of can opener!
T14 · 85 · 7478
england Offline Guardian
  • Unless
Re: 111mm variant with inline awl instead of can opener!
Reply #60 on: May 13, 2017, 06:01:39 PM
Still waiting.... :whistle:  At this rate I may go to Switzerland to pick it up!
"Unless someone like you cares a whole awful lot, nothing is going to get better. It's not."
― Dr. Seuss, The Lorax
Reply #61 on: May 14, 2017, 12:53:39 PM
Fun fact: this model is not flawless. I would say flawled but that's an awlful joke :facepalm:
But seriously: when opened, the awl pushes the liner and scale outwards. I'm surprised that Victorinox OK'd this design!
BTW, it looks like they designed a new stainless steel spacer to make up for the difference in thickness between the opener layer and the awl.
Reply #62 on: May 14, 2017, 12:55:44 PM
Oh my... Thats not good.  :o
That will either wear the liner and bend it permanently or loosen the rivet, or both, right?  :ahhh
Reply #63 on: May 14, 2017, 12:58:48 PM
I'm afraid you're right. The rivets getting loose is not good at awl. Excuse the pun.
nl Offline Mactire404
  • There's a SAK for that!
Reply #64 on: May 17, 2017, 02:56:04 PM
And considering that torque is applied to the awl this is an accident waiting to happen. :facepalm:
I'll remove it from my wishlist, that's a shame.
My SAK collection and more: http://pocketknives.home.blog
nl Offline glenfiddich1983
Reply #65 on: May 17, 2017, 03:05:40 PM
Considering how easy the awl opens and how easy the liner makes room for it, it's very well possible that the pin was "tightened" with the awl opened, leaving enough space for the awl to move freely. Not an ideal solution and nothing for Vic to be proud of, but I don't really think there is a danger of the pin bushing to break off.  :think:
But if you want to be sure about this, someone should remove the scales and take a look at the pin and bushings  ::)
« Last Edit: May 17, 2017, 03:07:05 PM by glenfiddich1983 »
[--- arms length ---] (-.-)
                                ^-- where the cat sits
Reply #66 on: May 17, 2017, 07:23:06 PM
Maybe this will help Victorinox realize the need for a dedicated 111mm model inline monster awl?
Reply #67 on: May 18, 2017, 10:53:04 AM
 :o     :ahhh   :ahhh
wales Offline Smashie
  • In Memoriam
  • Smurf it!
Reply #68 on: May 19, 2017, 08:55:15 PM
I got one as well. A little attention from the Dremel will sort out the in line awl problem. I've just had a good look at mine and there is an additional spacer between the backspring for the awl and the scale, so it 'should' stay tight. Time will tell.
« Last Edit: May 19, 2017, 09:09:20 PM by Smashie »
Si vis pacem, para bellum
  • Unless
Reply #69 on: May 20, 2017, 01:36:06 PM
Got mine as well after getting hit with huge custom charges :rant:  This is a great knife and the awl 'problem' will be sorted by wear of the awl on the aluminium liner or, as smashie said, use a dremel.
And no one's mentioned the secret pin yet....
« Last Edit: May 20, 2017, 02:21:23 PM by Guardian »
Reply #70 on: May 20, 2017, 01:54:46 PM
And no ones mentioned the secret pin yet....
I did!
But on Facebook :facepalm:
  • Unless
Reply #71 on: May 20, 2017, 02:23:37 PM
I did!
Well!  Now we know where your true allegiance lies! :pok:  :D
pl Offline u99
Reply #72 on: May 20, 2017, 07:34:20 PM
He came to me too. Ask if Victorinox will improve the awl, and if so then when?
Reply #73 on: May 20, 2017, 10:31:00 PM
Makes me sad them putting out a knife like that.
I know nothing about the cost of design and production etc and I don't spend a lot.
But I'm just not seeing that they cared with this design and if they don't then how am I suppose to?
Offline gadgetman7
Reply #74 on: May 22, 2017, 02:09:29 AM
Does seem a little sloppy for them. Not having any type of Philips driver though is a deal breaker for me. Wonder if they're using that scale on any other 111mm knives.
us Offline zrxoa1
Reply #75 on: December 03, 2018, 03:38:11 PM
So, any of you looking to sell that flAWLed 111??
Reply #76 on: December 03, 2018, 05:34:41 PM
I have 2 for sale :)
us Offline zrxoa1
Reply #77 on: December 03, 2018, 10:33:46 PM
You have the SOS 111mm with inline awl for sale??  How much??
Reply #78 on: December 04, 2018, 05:18:59 PM
Yes, I listed them in the trade section but at one point I withdrew everything. But yes, they are still available. I'm asking €70 each, but shipping may be a bit expensive since they are too big to be shipped in a bubble envelope. So probably around €25 I'm afraid.
It's these two (pic posted before):
us Offline zrxoa1
Reply #79 on: December 04, 2018, 08:30:42 PM
Ok. Let me think on it. Might have to sell something to buy one of those.  They’re gorgeous for sure!!!
au Offline Grass
  • First, we take Manhattan
Reply #80 on: December 05, 2018, 04:22:50 AM
If anyone happens to be after one in Australia, I'll sell one for $100 including registered postage. New condition.
« Last Edit: December 05, 2018, 04:25:26 AM by Grass »
es Offline koke
Reply #81 on: December 08, 2018, 11:53:41 PM
Hi.  I ’m considering to take it If zxroa1, doesn’t want it.
How much would be the shipping to Spain?
us Offline zrxoa1
Reply #82 on: December 09, 2018, 12:45:37 AM
I’m going to actually pass for now. Might be a mistake but I have an awl incoming and I’m going to try to mod one of my 111’s and build exactly what I want.
Thank you for the offer to sell though!!!
us Offline zrxoa1
Reply #83 on: December 10, 2018, 09:29:34 AM
Sigh...
Been setting here trying to decide what to do here. I have an awl coming tomorrow to be used as mod fodder. I was thinking of modding my Centurion, replacing the can opener tool with the awl. That should be the easiest way to go. I never use the can opener but I do use that smaller flat head for things. Hmmm...
Then I thought of modding a DAK I have, replacing the second, curved n serrated blade. That would leave my can opener/flat blade alone but then it looks as if the awl would not work there as that end is much taller and the awl would not set there.
I also thought of still doing the mod to my Centurion but at the same time transferring the OH blade from my Sentinel to the Centurion but then I’d lose the half stop the Centurion blade has.
Decisions, Decisions....
Then I think, it would be nice to add a scissors layer....  I’m getting a headache!!!  Haha.
Maybe I’ll just tear my Hercules apart and use it!!!  LOL
« Last Edit: December 10, 2018, 09:30:38 AM by zrxoa1 »
es Offline koke
Reply #84 on: December 12, 2018, 12:19:47 AM
So, as zrxoa1 will do a great job by himself....
Reinier, is there one available and could be delivered to Spain?
I’ll PM you tomorrow morning :)
Total Receipts: $105.65
PayPal Fees: $6.36
Net Balance: $99.29
Below Goal: $200.71
33%
