Multitool.org
alternatives to carbide cutters 7286
Full Member Posts: 120
gav
« on: May 05, 2017, 11:40:03 PM »
has anyone found an alternative carbide cutter to the overpriced gerber ones?
ive searched the web and may have something.i have them ordered from ebay and when i get them and if they work i'll post pics.
what i can tell you is the product no.is
TCMT 110204 CARBIDE CUTTER
the size of these ones match the gerber ones.i paid 8 euros for a set of ten.
like i said,when they arrive i'll see if they fit.they should though.
it would cost me 50 euros to get 2 of the original gerber ones on amazon.
keep you posted.
gav.
Global Moderator Point Of No Return Posts: 36,498
Re: alternatives to carbide cutters
« Reply #1 on: May 06, 2017, 12:58:00 AM »
 :popcorn:
gav
« Reply #2 on: May 06, 2017, 01:44:12 AM »
just to add to it,carbide cutters are not designed to work in pliers.they cant crush objects,like say nails or steel pins,theyre too hard and brittle.they break.but theyre cheap to mass produce.
gerber could have used 154cm which will last but wheres the after sales money to be made in that.
better to sell a 100 dollar tool and then make lots on it for years to come.
its like car tires,you dont get rid of your car just because your tires go bald.you go buy a new set.
gerber took a chance on carbide cutters years ago knowing that owners of their multis would keep replacing the cutters because they love that particular tool and want to keep it working.
charge a high price for replacement parts and laugh all the way to the bank.
carbide cutter tips,which is what the gerber ones are,are alot cheaper than what gerber charge for their original replacement ones and you can buy them in packs of ten.
they must have made millions on cutters alone over the years.
clever.clever.clever.
Hero Member Posts: 702 High Octane Gasoline
« Reply #3 on: May 06, 2017, 03:14:41 AM »
Are there any aftermarket steel replacements instead of carbide I wonder?
Last of the V8 Interceptors
gav
« Reply #4 on: May 06, 2017, 08:16:29 PM »
not that i know of or can find anywhere anyway.unless someone whos handy with steel fabricating has done it themselves at home.i am looking into it myself though.it depends on the costing.i cant ask a fella to make a pair.it would have to be 100 min to make it worth anyones while.
it would be nice though.stainless steel cutters on my center drive.that dont split at the sight of two copper wires.
No Life Club Posts: 1,158 Find me if you can...
« Reply #5 on: May 06, 2017, 08:26:26 PM »
keep you posted.
gav.
Not sure what the dimensions are of the Gerber's inserts, but you likely just bought the wrong stuff. Those are carbide inserts used in metal working like lathes or mills. I should have caught it right away with the TCMT, as CNC prgramming is my bread and butter. Those inserts are meant to cut by "shaving" material, not by shock impact like scissor cutting. Their edges are not sharp.
Also, those inserts are ISO standard. Each letter and number in the description has its own meaning. In case of TCMT 110204, it has an inscribed circle of 6.35mm (1/4"), 7-degree relief angle, and a counter sink hole. Dimensions of the TCMT 110204 can be found easily, like here: http://www.mitsubishicarbide.net/mhg/enuk/turning_inserts/no_srs/20044850. I think something like the Gerber inserts may have sharper than 7-degree relief angle.
« Last Edit: May 06, 2017, 08:57:02 PM by chrono »
gav
« Reply #6 on: May 06, 2017, 08:51:27 PM »
i hear ya brother but the ones i bought had the closest measurments to my center drive ones.i know from researching it though that carbide cutter tips are no good in pliers.theyre not designed for it.
this whole rant comes from my own frustration at my own center drive cutters always breaking at simple jobs like changing a household plug or snipping 4mm wide cable ties.i've spent nearly as much on cutters as the tool cost me.these ebay cutters cant be any worse than the gerber ones.can they?
« Reply #7 on: May 06, 2017, 09:00:57 PM »
Theoretically, you can have those Gerber insert resharpened, though you need to find a CNC grind shop to do it properly. Plus it won't come cheap.
gav
« Reply #8 on: May 06, 2017, 09:16:22 PM »
getting them resharpened isint the problem.they shatter.
« Reply #9 on: May 06, 2017, 09:35:56 PM »
I tried cutting cable ties once, it didn't work but at least they didn't shatter on me.
https://forum.multitool.org/index.php/topic,63712.msg1201288.html#msg1201288
« Last Edit: May 06, 2017, 09:36:57 PM by zoidberg »
No Life Club Posts: 3,857
« Reply #10 on: May 06, 2017, 10:06:30 PM »
Replaceable cutters in general are a bad idea.  Someone made a pair of linesman's pliers with them in the 50's or '60s and they weren't made long.   Just get a Pro Scout or older Gerber that doesn't have them.
« Reply #11 on: May 06, 2017, 11:25:56 PM »
Ok. I thought if the carbide was dull or slightly chipped... Also, after look at Zoid's thread, I am certain the TCMT inserts will not work, as the cutting surface is on the same side where the screw goes into. You have a 97-degree corner on each insert at the cutting area. I have never seen a cutter with an obtuse angle on the cutting blade
It depends. If the function is only 10% of the cost of the tools, proper design of indexable/ replaceable tools are win/ win for both manufacturers and users. However, carbide should not be used in this cutting manner. Usually, when the hardness goes up, toughness goes down. I am actually interested in how Gerber came up with this brilliant idea  :think: (and got away with it)
« Last Edit: May 07, 2017, 12:35:21 AM by chrono »
Zombie Apprentice Posts: 17,513 I'm not a pessimist, I'm an experienced optimist!
« Reply #12 on: May 07, 2017, 12:01:10 AM »
I've got tooling contacts that could make some in a tool steel, but as pointed out previously in this thread, it's highly unlikely to be cost effective. Even in batches of 100+ it would still be incredibly difficult to produce them efficiently enough to even match the current Gerber pricing
Newbie Posts: 8
« Reply #13 on: May 07, 2017, 03:40:54 PM »
Economical alternative to the expensive Gerber 48252 carbide cutter replacement.
Gerber REPLACEMENT Tungsten Carbide Cutters 48252
Two tungsten carbide cutter replacements for Multi-Pliers
Hex head wrench
Four replacement screws
$14.24 + $2.61 s&h = $16.85
TCMT 731 Carbide Inserts C6 Grade For 1/4 & 5/16'' Turning Tools 2mm 10mm
10pcs Carbide inserts
$8.75 + $0.99 ePacket delivery from China = $9.74
No Life Club Posts: 2,320 21 Badges for Eagle
« Reply #14 on: May 07, 2017, 04:18:55 PM »
Hex head wrench
Do you think they will shatter as easily as the ones from Gerber?
BUCK: X-Tract, 360
*=mod
Newbie Posts: 8
« Reply #15 on: May 07, 2017, 05:08:46 PM »
I don't know if they will shatter as easily as the Gerber 48252 carbide cutters.
When I looked at my Gerber 48252 cutters, they appear to be flat and without angular cutting edge.
Unlike the Leatherman replaceable carbide cutters, the Gerber 48252 does not appear to have beveled cutting edge.
I just looked for similar dimension of the triangle size, center hole size, material of cutter, and lastly the price.
If the TCMT 731 shattered on materials just like the Gerber 48252, its fine with me because they're inexpensive $1.95/pair replacements compared to the $16.85/pair Gerber 48252.
« Reply #16 on: May 07, 2017, 09:50:21 PM »
Welcome to the forum vlelet.   :cheers:   :cheers:
« Reply #17 on: May 07, 2017, 11:46:08 PM »
Hex head wrench
Oh I see how those inserts are seated in the tool pockets. I was under impression that the one on top would be on the bottom, hence the comment about the obtuse angle. Now the TCMT has those fancy feature called "chip breaker" on the insert face. If you get TCMA insert which has a flat top (no chip breaker), it will has a bit stronger edge than TCMT.  :cheers:
Newbie Posts: 8
« Reply #18 on: May 08, 2017, 04:49:27 AM »
I'm correcting my previous statement about the Gerber 48252 being flat.
I got curious and took a long look at the 48252 cutter and saw that it is sliding forward and downward to one side which is the cutting side.
Its like the tip of the chisel with the cutting edge sliding forward and down towards the sharp cutting edge.
The 731 is also slightly longer than the 48252.
Comparing with the TCMT 731, it is also slightly angled forward and downward from the flat side to the fancy side.
Does that makes the fancy side the cutting edge of the insert? It's going to make contact first than the shorter side of the cutting edge.
Will it matter if the flat side is placed as the cutting side of the insert?
Newbie Posts: 8
« Reply #19 on: May 09, 2017, 01:26:19 AM »
Follow up for anyone interested, I positioned the fancy side of the cutter inside and cut a few pieces from a metal clothes hanger.
1. It was easier to cut the metal clothes hanger when the cutter is positioned with the fancy (longer) side making a scissor action with the other cutter.
2. Also, it is easier to cut the clothes hanger using the rear or middle part of the cutter than the forward part of the cutter.
3. The $1.95/pair carbide cutter got chipped when I cut the hanger using the forward part of the cutter. Imagine if it was the $16.85 Gerber 48252 carbide cutter.
I think that's the benefit of having a inexpensive carbide cutter alternative, it won't hurt my wallet as much as the Gerber 48252 would.
« Reply #20 on: May 09, 2017, 02:34:00 AM »
« Reply #21 on: May 09, 2017, 04:03:06 AM »
Not sure if you can find TCMA at the size that may fit your cutter, but the TCMA is stronger at the edge than TCMT. Also, being Chinese made, quality of the carbide may be questionable
Zombie Apprentice Posts: 14,514 Yoo-hoo, big summer blowout!
« Reply #22 on: May 09, 2017, 10:07:44 AM »
Can't see the pic.  :pok:
Also, Questionable?! Because its Chinese?!
What about the iphone oh I see what you mean.  :D :whistle:
Newbie Posts: 8
« Reply #23 on: May 10, 2017, 02:07:11 AM »
Anyone knows the specs of the screw that goes with the Gerber carbide cutter?
Newbie Posts: 8
« Reply #24 on: May 10, 2017, 02:11:44 AM »
keep you posted.
gav.
I wonder if we got the same carbide cutter?
Please post pics soon as you get them installed in your plier.
« Reply #25 on: May 10, 2017, 02:44:55 AM »
Here, just a eBay picture http://i22.ebayimg.com/05/i/08/b2/59/20_35.JPG
TCMA has "flat top", meaning no fancy chip breaker, just a smooth flat. And I was serious about the crappy Chinese carbide. My workplace only uses American, Japanese, Sweden... made ones. Simple, cheapest ones are over $3, and that is with discount from distributors. It gotta be with the carbide purity, coating... or something.
Admin Team Zombie Apprentice Posts: 19,885 mmmmm SAKrelicious
« Reply #26 on: September 26, 2017, 04:50:32 PM »
Just had a carbide cutter fail on me trying to cut some 2.2mm brass rod. Once it shattered my MP400 took over duties and was victorious.
'Derail a thread and we'll come at you like a block of cheese'. Captain Mags and Sergeant Fuzzbucket of the Anti Derai.... mmmmmmm cheese
No Life Club Posts: 2,110
« Reply #27 on: September 27, 2017, 03:41:18 PM »
Alternative you say, this was a cut out from a cheap pair of garden shears. I simply refuse to pay for the price that gerber is asking for the carbide inserts. It's ridiculously expensive and does not work. I swear it works better than carbide. It may ding, but can be sharpened. Just some time needed. And $2 to spare.
« Reply #28 on: September 27, 2017, 04:00:00 PM »
Interesting Sam - is there a link to these?  :salute:
« Reply #29 on: September 27, 2017, 04:14:36 PM »
Email them  :pok:
The only way they are going to change things, or offer a suitable tool steel alternative, is if the customer base gets vociferous about it. Numbers matter, and every  :twak: the company gets, adds up to more potential change  :salute:
Total Receipts: $86.66
PayPal Fees: $5.67
Net Balance: $80.99
Below Goal: $219.01
Page created in 3.646 seconds with 33 queries.
© 2018 Defender Web & Tool
