Kevin, good luck with your CentreDrive!Mine has a new mod.
Quote from: MusicMen on June 16, 2017, 04:17:49 AMKevin, good luck with your CentreDrive!Mine has a new mod.Do you have a write up of this? The wire stripper looks great!!Charles.
I will be getting a black CD thru buying a gun cleaning kit for a bit over $50 in total Some of these kits are on eBay if you fancy a black CD and some extrahttps://www.ebay.com/itm/US-MILITARY-OTIS-CQB-CLEANING-KIT-5-56mm-223-NEW-IMPROVED-GERBER-MULTI-TOOL/202580054550https://www.ebay.com/itm/NEW-OTIS-CLEANING-KIT-5-56-GERBER-MULTITOOL-SOLDIERS-TOOL-KIT/113633953001From what I read, I should not have too high of expectation on the tool, huh? An ultimate MT for me is half a Leatherman Surge (with PE blade and scissor), and the bit driver of the Gerber CD. Is such mod possible?
Thanks Gman! I agree. I really like this tool. It's been my go to since I bought it.
Is the CD driver a must? There are probably other tools that can use as a bit driver.. Assuming the driver is going into the internal tool bay?
I like that ezdog!
It's pretty difficult to top a Center Drive!
Nice job!
Would it be possible to replace the bit holder between the blade and the center drive tool with a few tools from another multi tool?
Obviously without a standard Gerber locking mechanism MP600 tools are out.
