Gerber Center Drive Club
pr Offline Juan el Boricua
Re: Gerber Center Drive Club
Reply #540 on: December 19, 2024, 04:03:29 AM
Thank you Barry!
Reply #541 on: December 19, 2024, 06:48:23 AM
Now just noticed that Center Drive Plus (silver) has half serrated blade.
Had to look up was i really seeing right noticed that CD has third version too while browsing Gerber site and it is Rescue Model
Aldo that model comes with Coyote Tan sheat, now i may need to get one just for that sheat cause Gerber doesnt that kind sheat anywhere.
Reply #542 on: December 19, 2024, 04:36:48 PM
I used to have a coyote tan sheath for mine  :facepalm:
Reply #543 on: December 21, 2024, 12:32:01 AM
Offline Dogforpm
  • New User
Reply #544 on: December 23, 2024, 05:37:35 AM
Hi, my CD managed to shear off the pivot bolt at the knife blade side on the weekend. It appears that replacement bolts are not available from Gerber. Anyone know where I can get a suitable replacement?
Secondly, when I was disassembling, a small folded piece that looks like some kind of retainer came loose from the bit holder. I can’t work out where it goes. Can someone please post a close-up photo of the bit holder so I can see it?
Reply #545 on: December 23, 2024, 11:46:47 AM
Offline Dogforpm
  • New User
Reply #546 on: December 23, 2024, 04:34:55 PM
Thanks very much @Antti. That’s helped me see where the piece goes. Now I’ve just got to find a new pivot bolt and get the remains of the old one out of the centre piece
Offline jf34
Reply #547 on: December 27, 2024, 07:20:51 PM
Welcome JF34 and, good tool choices you've made. I'm going to guess that the one with the laser etched date code is a first generation model, and the other one is a later production model; both real models. One way to be sure is to look on the blade of the "undated" one and see if it has a date code etched on the back side, right under the thumb hole or, stamped inside the handle under the blade. By the look of yours, I'd say look for the stamped 5-digit code on the handle.
thank's a lot you help me a lot , and you were totaly right , i have the  4 digits number  etched just like your photo on my centerdrive , who don't have any stamped code .
then i m happy to say my two center drive are real  and not fake .    it's like  poker when you purchase second hand on  web add ....
Reply #548 on: December 27, 2024, 07:26:10 PM
Reply #549 on: December 28, 2024, 02:01:40 PM
Glad to help, jf. :cheers:
Today's carry; Center Drive and Climber Plus.  [ You are not allowed to view this attachment ]
Reply #550 on: December 28, 2024, 02:03:38 PM
Great combo Juan!
Reply #551 on: December 28, 2024, 02:06:25 PM
Reply #552 on: April 13, 2025, 05:33:02 PM
Had anyone come across this bit set for the Center Drive before?  It came in a MOLLE sheath with a black oxide CD.  I have only ever seen the straight bit set with no extensions or Allen wrench.
Reply #553 on: April 13, 2025, 05:38:23 PM
Picture's not showing on my end but, if it has like one or two "extended" bits, my understanding is it's from a Berry Compliant, GSA approved set for the military. Seen them occasionally on the bay but no longer on Gerber's web.
Reply #554 on: April 13, 2025, 05:41:58 PM
Thanks Juan.  I was having trouble posting the pic.  I didn't catch that right away  :facepalm:
That's what it is then.  I couldn't find a reference to it anywhere.  I appreciate it!
Reply #555 on: April 13, 2025, 05:43:07 PM
On a similar note, are you aware of the Center Drive being issued to any military anywhere?  I'm not but I might have missed something  :rofl:
Reply #556 on: April 13, 2025, 05:52:37 PM
If I recall well, it does come in some weapons maintenance kits issued for the US Armed Forces, but haven't seen it anywhere else.
Edit- not issued, but sold to; most are by Otis Defense. Here's one
https://awsin.com/57078-otis-weapons-cleaning-tool-kit/
Reply #557 on: April 13, 2025, 05:57:13 PM
Thanks Juan!  I wondered with the Berry compliant sheaths and MOLLE pouches.
Reply #558 on: April 13, 2025, 06:05:13 PM
The Berry Amendment states that the DoD can only purchase textile, and other goods solely from US sourced and manufactured materials. Here' s a bit more technical info.
https://www.trade.gov/berry-amendment
Reply #559 on: April 13, 2025, 06:15:14 PM
Thanks Juan!  I'm going down the rabbit hole  :rofl:
Reply #560 on: April 13, 2025, 06:16:09 PM
 :facepalm: :rofl: :facepalm: :rofl:
us Offline JonesE
Reply #561 on: April 13, 2025, 07:01:32 PM
Barry, Juan is spot on. The Center Driver is from an M4 cleaning kit. The square bit with the four prongs is for the front sight adjustment.
JonesE
england Offline ladder5
Reply #562 on: April 13, 2025, 08:51:40 PM
Hi, i've modified the standard carbide cutter's, they now cut flex cable and multi strand wire a bit better, and still have enough strength to cut Mig welding wire, which there great at as standard, and i’ve discovered the hard wire notch strips the ends well.
I could have ground off more and they’d cut electrical wire better but i didn't want them to turn into dust! the mig wire is the primary use and the electrical wire cutting is a secondary function if some body else damages a electrical wire >:( the mig wire damages my USA MP600 non replaceable cutter’s.
The brown wire was “cut” by the standard carbide cutter
Reply #563 on: April 13, 2025, 09:35:10 PM
Nicely done, Ladder5!!! If only I had known before replacing them for HSS ones...oh well, now I know. Thanks! :tu: :cheers:
Reply #564 on: April 14, 2025, 01:38:47 AM
Thanks Juan!  I had no idea this was even available.  When I was in, you were lucky to even get a multitool, let alone a kit like that.
Reply #565 on: April 14, 2025, 01:41:33 AM
That makes sense then JonesE.  I wondered about that.
We had to use a sight adjustment tool from the range master, if they were lucky enough to have one available.  It's good to see that the quality of equipment has gotten better over the years.
JonesE
Reply #566 on: April 14, 2025, 01:42:04 AM
Excellent work!!
Reply #567 on: April 19, 2025, 10:45:53 PM
Thanks, i ground them on diamond stone’s by hand.
If any one else wants to have a go I found it easiest to screw them to a small length of plastic/wood for holding and using a side to side motion.  Don’t bother wasting your time holding them in your finger’s, it doesn't take long before it gets painful, ask me how i know ::)
I’ll probably do the others at some point.
Reply #568 on: August 03, 2025, 06:10:36 PM
Victorinox tweezers added to the CD, the perfect spot for them existed all along! no more walking about the workshop when i get a splinter.
us Offline JonesE
Reply #569 on: August 03, 2025, 07:06:31 PM
Ladder5, Great tweezers mod for the Center Drive. I really like that. I may have to poach that idea from you.
Thanks for sharing,
JonesE
