First modding projects in progress: Urban Knife & CyberClipper
nl Offline glenfiddich1983
Last weekend I finally had some spare time to start with my modding projects. I'm going to make two mods: my "Urban Knife" and the "CyberClipper".
The Urban Knife will consist of the following four layers:
- large serrated blade, divot tool (from the Golfer), corkscrew
- scissors, multipurpose hook
- spatula
- can opener, cap lifter, reamer
The CyberClipper will be a Clipper with an added Bit-holder layer from the Cybertool:
- large blade, small blade, corkscrew
- metal file, small flat screwdriver
- bit holder
After deciding on the mods, it was time to decide on the donors. I sacrificed the Golfer, Serrated Spartan, Cybertool 34 and SwissChamp. Also I ordered some new scales.
Here they are, together with the Pioneer X  :D
Time to start taking them apart!  :ahhh
First: marking the center of the pins:
Then the drilling starts
Bushings came out undamaged!
Poor SwissChamp!
There certainly was a learning curve in the whole pin drilling process. The first knife took me an hour to take apart, the fourth one only ten minutes!
After some drilling this is what's left of the donors:
Time to make some new pins!
Giving myself more than enough length to work with
tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap
To be continued...
« Last Edit: May 09, 2017, 02:30:33 PM by glenfiddich1983 »
[--- arms length ---] (-.-)
                                ^-- where the cat sits
us Offline MusicMen
  • 21 Badges for Eagle
 :popcorn:
BUCK: X-Tract, 360
*=mod
Looking good!   :like: :like:
00 Offline Mechanickal
So basicaly you drill in the center of the pin so the bushing gets room to shove off. You reuse the bushing and hammer the top of the new pin flat (almost mushroom like) to hold the bushing in place again?
At least that's what I can understand from what I'm seeing... but on the other hand I'm sure there are enough threads explaining this subject... :facepalm:
That's correct  :salute:
wales Offline hiraethus
  • I brake for cake
Do enough cellidor mods and eventually you'll build up a stock of bushes.  You end up sanding or snipping the bushes off one side of the knife as it's too much hassle to punch and drill each one individually. :oops:
Looking good so far buddy :o :like: Can't wait for more pics and the end result :tu:
id Offline jaya_man
Yes... that is correct...and make sure to use the correct dril bit size...
id Offline jaya_man
Hey Glen, you did rember which tools go with which backspring, right?
If you have an impact drill, chuck the pins in it... perfect peen head done in seconds.
id Offline jaya_man
Off to a good start I see
I have a picture of which tool goes with which spring  :salute:
Sounds like a great trick to do peen heads... if only I read this earlier  :D
I'll remember it for the next mods. I have plenty of pins for my first two mods now.
Well, I sorted out the necessary tools for my first mod, cleaned them all and sanded the liners. Before I put the thing together i'll make a mock up first, to verify if these liners are the right liners for these tools and if everything fits.
To be continued, probably next weekend...
id Offline jaya_man
Can't wait to see the fiished build :popcorn:
+1 :popcorn:
br Offline BleaKrytE
  • Hello world. I'm Vinícius!
Way to go buddy! Looks great!
Enviado do meu iPhone usando Tapatalk
Uni student, environmental activist (yes, I'm that annoying guy that mentions climate change every third minute), motorcyclist.
+1 :popcorn:
+2   :tu:   :popcorn:
Had some spare time today, so started putting the thing together.
At first I was struggling a bit with the scissors, but after I got some advice and started over from the other side, I got it in.
All tools are functioning like they should, with no tools rubbing against each other  :salute:
The next step is probably the hardest: cutting the pins and peening this side of the pins.
It will probably be friday in the evening when I have the time to continue. In the mean time: anyone has some advice?
Should I put the bushings in first and then cut the pins 1 mm above the bushings? More than 1 mm? Less than 1 mm?
Just me and don't know how anyone else does this but I put the bushings first then cut the pins :tu: Putting a mod together layer by layer is a very enjoyable process to me and let's you really see how a knife works  :tu: I then would recommend as small of a ball peen hammer as you can find :cheers: I luckily had a very small one that I was given by a great uncle before I was even school age :dd: :like: I don't know the weight but it is somewhere between 4 and 6 ozs :think: (Don't know the kgs on it though :facepalm: ) make lots of small taps and take your time. Also I have heard some of the better more experienced Modders use small shims under the bushings so you don't over peen the knife and then when they get it close to what they want they remove the shims and do the final peen before filing the top smooth before scale time :tu:
Hope that helps some but I am new to this as well. What I did do seemed to work though :cheers:
Looking great so far as well :tu: :like: :like:
us Offline MusicMen
Looks great so far.  :tu:  Good luck with the final peening.  :cheers:
BUCK: X-Tract, 360
*=mod
Looking back I now see your ball peen hammer and it looks about the right size for peening ::) :D :like:
id Offline jaya_man
Looking great Glen... I put the bushing in ... put another liner on top of it, then cut..
Thanks all!  :cheers:
Do you cut directly above that liner? Or 1mm above it?
id Offline jaya_man
Directly... the liner is about .8-1mm... just to get even lengths... and I file the pins flat for good peening...
se Offline kottskrapa
Can't wait to see the finished mod!!
It's not failure if you learn something from it
wales Offline magentus
  • mmmmm SAKrelicious
Fantastic WIP pics and narration G-Fiddy! Can't wait to see the finished results too.  :cheers:
ca Offline Syph007
  • SAK Surgeon
Yup!  I cant remember the last time I carefully removed bushings, but I did in the old days when I didnt have spares so its a good skill to have.
Now I hold one side of the SAK against the belt grinder and it removes all the brass quite fast.  Then the outer liner lifts off and I can have it broken down to components in about 1 minute time total.
Modding thread : Here
Website : WWW.SAKModder.com
Facebook : SAKModder
Instagram : robertjlessard
Busy with the final peening!
Cut the pins
Start tapping!
Getting close!
To be continued...
Take a beer and hurry up! Can't wait for the results much longer!! Sitting here with a whiskey and trying to calm down
 :ahhh finished  :ahhh
making pics now!  :D
Total Receipts: $0.00
PayPal Fees: $0.00
Net Balance: $0.00
Below Goal: $300.00
 0%
