Learning to make Sheaths
sak60 · 195 · 11200
Re: Learning to make Sheaths
Reply #30 on: June 30, 2017, 04:46:38 AM
Nice job :tu:
us Offline MusicMen
  • 21 Badges for Eagle
Reply #31 on: June 30, 2017, 05:56:44 AM
Sweet   :tu:
BUCK: X-Tract, 360
*=mod
au Offline sak60
Reply #32 on: June 30, 2017, 06:29:39 AM
Thanks JR and MusicMen
This is the sheath that came with the knife.
* IMG_0099.JPG (Filesize: 185.59 KB)
* IMG_0100.JPG (Filesize: 224.67 KB)
Andrew
Reply #33 on: June 30, 2017, 08:03:38 AM
I got a old knife that was my grandfathers, the knifes in bad shape the handles wrapped in electrical tape and the sheath looks kinda like that one, but i think it's got an Indian head or scout stamp and a little metal trim. Maybe I'll dig it out tomorrow. It's been a while, maybe I can clean it up,
« Last Edit: June 30, 2017, 08:09:14 AM by MadPlumbarian »
au Offline sak60
Reply #34 on: June 30, 2017, 12:52:36 PM
That's awesome, thanks for sharing that; it would be good if you could restore them seeing as it was your Grandfathers', if not then at least make sure it doesn't deteriorate further.The sheath is actually in worse condition than it looks in the pic. I didn't want to lose what's left of the names on it so with a new one I don't have to worry about damaging the sheath, as the knife is in with others that get moved around a bit. :cheers:
Andrew
us Online SteveC
Reply #35 on: June 30, 2017, 05:26:47 PM
Great job !    :salute:
au Offline sak60
Reply #36 on: July 01, 2017, 12:34:28 AM
Thanks Steve.  :tu:
Andrew
au Offline sak60
Reply #37 on: July 06, 2017, 08:12:47 AM
Something a bit different. This is the start of a frog for my Remington 1915 dated P1907 bayonet.  I'll also have to make and attach a small strap and buckle across the top of the locket opening.
* IMG_0118.JPG (Filesize: 82.08 KB)
* IMG_0115.JPG (Filesize: 99.17 KB)
* IMG_0116.JPG (Filesize: 98.54 KB)
* IMG_0117.JPG (Filesize: 88.29 KB)
Andrew
au Offline sak60
Reply #38 on: July 07, 2017, 06:54:24 AM
Just the strap and buckle and a couple of rivets to go.
* IMG_0128.JPG (Filesize: 159.13 KB)
* IMG_0129.JPG (Filesize: 130.17 KB)
* IMG_0130.JPG (Filesize: 141.68 KB)
Andrew
au Offline Gohard
  • Leatherman fanatic!!
Reply #39 on: July 07, 2017, 06:55:58 AM
That looks good. You're a pro now.
au Offline sak60
Reply #40 on: July 07, 2017, 07:22:13 AM
Thanks Gohard  :tu: lots to learn and doing it for my own enjoyment. Cheers  :)
Andrew
au Offline Gohard
Reply #41 on: July 07, 2017, 07:43:03 AM
Made a few myself. The welt is just there to stop the blade cutting through the stitching and on the blunt side to shape the sheath. I normally don't use rivets on sheaths.
But if someone ask for them I do fit it. Nice work there mate
* IMG_4112.JPG (Filesize: 330.76 KB)
au Offline sak60
Reply #42 on: July 07, 2017, 07:48:48 AM
Hey they're great! Way ahead of where I am, I don't do tooling either. I started because I wanted to recreate some falling apart WW2 sheaths that's why I'm using rivets. Yours are terrific thanks for showing them.
Andrew
au Offline Gohard
Reply #43 on: July 07, 2017, 07:54:54 AM
Thanks. If you need advice. I might be able to help.
au Offline sak60
Reply #44 on: July 07, 2017, 01:04:49 PM
Thanks for the offer. :salute: Any advice is welcome. :hatsoff:
Andrew
Reply #45 on: July 07, 2017, 05:11:57 PM
Pretty cool! Love the aged look.
When I saw the first pics, I thought of adding a little strip of leather, with a couple of press butons, to keep the "scabbard" in place (probably not needed, just being overly careful). The idea is to ensure the scabbard stays in place and doesn't fall, no matter what you do.
Something like this:
* sheath.JPG (Filesize: 335.18 KB)
au Offline sak60
Reply #46 on: July 07, 2017, 11:18:55 PM
That's a good idea. If I did that I would probably have one snap and permanently attach the other side. This is one of the several original leather frog styles that I'm trying to do. Thanks for the encouragement and ideas. If I can't find the hardware (buckle) small enough the snap option is a good one.  :cheers:
* IMG_0133.JPG (Filesize: 74.53 KB)
Andrew
au Offline sak60
Reply #47 on: July 15, 2017, 08:59:27 AM
The finished .303 bayonet sheath- fairly happy
Also a sheath for a late war Kabar that didn't come with one.  The dyeing is in need of more practice as can bee seen by the difference in colour from belt loop to sheath body.
I'm using spirit based dyes so may get an oil based dye to compare with.
* IMG_0174.JPG (Filesize: 110.3 KB)
* IMG_0175.JPG (Filesize: 112.63 KB)
* IMG_0177.JPG (Filesize: 108.65 KB)
« Last Edit: July 15, 2017, 09:04:33 AM by sak60 »
Andrew
Reply #48 on: July 15, 2017, 09:21:21 AM
Lovely work and your stitching is really neat  :drool:
I just have to say this again!  :salute:
au Offline sak60
Reply #49 on: July 15, 2017, 09:26:10 AM
Thanks Sparky  :hatsoff:
Andrew
au Offline Gohard
Reply #50 on: July 15, 2017, 09:31:17 AM
Nice work there.
Measure all the pieces and allow for a bit extra. Then do the dye first and then cut everything out.
Reply #51 on: July 15, 2017, 02:37:45 PM
Nice job! :tu:
au Offline sak60
Reply #52 on: July 15, 2017, 05:11:29 PM
Nice work there.
cheers Gohard thanks for the tip :salute:
Andrew
au Offline sak60
Reply #53 on: July 15, 2017, 05:14:04 PM
Andrew
us Offline MusicMen
Reply #54 on: July 15, 2017, 06:03:09 PM
Amazing work!   :cheers:
Do you hand or machine stitch?
BUCK: X-Tract, 360
*=mod
Reply #55 on: July 15, 2017, 07:27:29 PM
Awlsome! The buckle looks great!
 :tu: :salute:
au Offline sak60
Reply #56 on: July 16, 2017, 01:21:53 AM
Thanks MusicMen  :tu: I hand stitch using a little hobby vice but I am planning to get a stitching horse as the thread keeps getting snagged on the handle and guide rods.  :cheers:
Andrew
au Offline sak60
Reply #57 on: July 16, 2017, 01:41:20 AM
 :tu: :salute:
Thank you pfr  :tu: I'm reasonably happy with it as it's my first non knife sheath piece. Need more practice wet forming though, as I want to make a case for my phone at some stage.   :cheers:
Andrew
au Offline sak60
Reply #58 on: July 21, 2017, 10:33:30 AM
This is my latest WW2 copy, a USN mk 1 sheath for my Pal RH-35. I only had the photo to go on this time so guessed the dimensions.  :)
The extra length in the belt loop is intentional though.
* IMG_0180.JPG (Filesize: 140.9 KB)
Andrew
au Offline Gohard
Reply #59 on: July 21, 2017, 11:49:31 AM
Looking good
