Learning to make Sheaths
sak60 · 195 · 18590
au Offline sak60
Re: Learning to make Sheaths
Reply #90 on: August 04, 2017, 02:49:40 PM
Andrew
Reply #91 on: August 04, 2017, 03:10:32 PM
Nice work on that one! Are you thinking about doing some other leather items. Like bags, belt pouches or belts?
au Offline sak60
Reply #92 on: August 04, 2017, 03:40:53 PM
Hi Ducttape, I'm just doing sheaths for my WW2 blades that have ones that need it at present though have done a supertool pouch and a belt for my son. I am liking it as a pastime and a good skill to have. Once I have perfected things a bit more I may do some more pouches for my folders and things and I plan on making myself a billfold because I can't find one to buy that doesn't have card slots. I don't have plans to do elaborate or large scale items like bags. Thanks for the compliment on my work. :cheers:
Andrew
Reply #93 on: August 05, 2017, 10:02:31 AM
Great work mate,inspiring  :salute:
au Offline sak60
Reply #94 on: August 05, 2017, 10:05:08 AM
Thank you Zed  :salute:
Andrew
ca Online Chako
Reply #95 on: August 05, 2017, 02:21:26 PM
au Offline sak60
Reply #96 on: August 05, 2017, 04:41:45 PM
Thanks Chako for the links I appreciate it. :tu:
That quiver looks like it was a lot of work but great result. Really like the small bag too.
 You look to be well set up. I am getting by with the basic tools that I need for what I'm doing now. I'd be interested to know what dye and method you use, as getting an even and predictable colour seems to be a challenge. Thanks again for the comment and links.
Andrew
ca Online Chako
Reply #97 on: August 06, 2017, 02:24:10 AM
If you get the antique staining gels, I found those to be the easiest to use. Simply rub a section with a wool dauber and then quickly wipe away any excess with a damp sponge. I also tend to use a clear coat of acrylic finisher.once the piece has dried.
Oil based dyes also work well...getting an even finish take a bit of practice.
As for tool setup, indeed I am. It all started with my finding a box of weird tools at the local pawn shop. I bought them out of curiosity, and after some research and plenty of book reading, I slowly started to acquire the various tools needed. I still lack a leather sewing machine....doing all of my sewing by hand still.
« Last Edit: August 06, 2017, 02:28:02 AM by Chako »
au Offline sak60
Reply #98 on: August 06, 2017, 02:55:14 AM
Thanks Chako for the info about the dyes. I have seen oil based dyes referred to on YT also the antique stains in store. Will do some research into them.
I actually like the sewing part except for the punching of holes as my sheaths are multi layered in some places and haven't had any success punching single layers and lining up the holes  :(
I put it together and punch the lot.  :cheers:
Andrew
ca Online Chako
Reply #99 on: August 06, 2017, 04:48:06 AM
There are tools to make your life easier.
For example...
1. Adjustable Groover. Run this along a leather piece, and the tool will cut a groove into the leather. Run an overstitcher inside that groove and you have just sunken your stitching for a more professional look.
https://www.tandyleather.com/en/product/craftool-e-z-adjust-stitching-groover
2. Overstitcher. This tool will accurately allow you to mark holes on various pieces of leather.
https://www.tandyleather.com/en/product/craftool-overstitchers
3. Diamond hole chisel set. Quick and easy way to punch accurately spaced holes in leather for stitching. You can also find just a single one piece tool that will do the same.
https://www.tandyleather.com/en/product/diamond-hole-chisel-set
Take a look at Tandy Leather's web site to get an idea on leather crafting tools and components.
https://www.tandyleather.com/en/category/stitching-lacing-tools/3
« Last Edit: August 06, 2017, 04:50:14 AM by Chako »
au Offline sak60
Reply #100 on: August 06, 2017, 07:54:07 AM
Thanks Chako I was just watching a vid from them as I'm thinking about getting one of the knife handles that take the little curved blades.
Andrew
ca Online Chako
Reply #101 on: August 06, 2017, 01:18:50 PM
Get yourself a starter stamping kit with swivel knife such as this kit...
https://www.tandyleather.com/en/product/craftool-basic-7-tool-set
You will find that you can 90% of most anything with this starter set. The other stamps you can get piece by piece if and when you need to expand.
or get yourself a larger starter kit such as...
https://www.tandyleather.com/en/product/deluxe-leathercraft-set
or
https://www.tandyleather.com/en/product/basic-leathercraft-set
With these style of kits, you not only get a good assortment of stamps and a swivel knife, you also get a proper mallet (never use steel on steel stamps), and some small leather kit materials to practice on.
May I also recommend these good books to start with...
https://www.tandyleather.com/en/product/leathercrafting-book
https://www.tandyleather.com/en/product/abc-s-of-leatherwork-book
https://www.tandyleather.com/en/product/leathercraft-tools-book
« Last Edit: August 06, 2017, 01:29:31 PM by Chako »
au Offline sak60
Reply #102 on: August 06, 2017, 02:02:27 PM
Thanks for taking time to post these.
The starter tools would probably be useful when I want to start stamping.
Out of the two leatherwork books would you favour one over the other?
Andrew
ca Online Chako
Reply #103 on: August 06, 2017, 02:06:26 PM
The first book is the better one of the two. The third book is an essential if and when you want to start buying leathercrafting tools as it explains everything in how to maintain and use them.  :salute:
au Offline sak60
Reply #104 on: August 06, 2017, 02:08:27 PM
Thanks :tu:
Andrew
au Offline Gohard
  • Leatherman fanatic!!
Reply #105 on: August 06, 2017, 04:23:03 PM
By hand??????
Nothing wrong with that.
You can choose where the holes will start  and end.
Only problem is when you do a belt for a customer and he want it stitched.
au Offline Gohard
Reply #106 on: August 06, 2017, 04:25:43 PM
or
Thanks for the advise Chako. Will also look into getting those books.
au Offline Gohard
Reply #107 on: August 06, 2017, 04:32:46 PM
Thanks Gohard and pfrsantos, I used your ideas in this one. Also used Resolene to finish over the dye.
Perfect
au Offline Gohard
Reply #108 on: August 06, 2017, 04:39:13 PM
Message me when you want to make wallets. I Can help you with this. Took me a year to work out all the teething problems.
Reply #109 on: August 06, 2017, 05:11:02 PM
Such an inspiring thread.  I've made some small leather items and I know the skill involved as mine look like poo  :rofl:.  Its ok tho they work and its great fun.
au Offline Gohard
Reply #110 on: August 06, 2017, 05:15:12 PM
Practice practice and more practice
ca Online Chako
Reply #111 on: August 06, 2017, 11:08:23 PM
I have been thinking of moving my leather stuff downstairs for several good reasons, and all my ammo reloading stuff upstairs. It also has been a few years I have wanted to try my hand at a gun belt for my SAA pistols. Maybe this month might just see those changes and possibly work on that belt.  :think:
If I do the belt, I just might make a step by step thread about it and post it in here somewhere.
Nice wallets!  :tu:
« Last Edit: August 06, 2017, 11:09:49 PM by Chako »
au Offline Gohard
Reply #112 on: August 07, 2017, 12:04:18 AM
Nice wallets!  :tu:
Thanks Chako
A step by step will be good to follow.
au Offline sak60
Reply #113 on: August 07, 2017, 08:31:38 AM
Thanks Gohard I will. :cheers:
Andrew
au Offline sak60
Reply #114 on: August 07, 2017, 08:51:35 AM
Thanks Aloha :) Glad you like the thread.
That's right, if it works and does the job that's the main thing. yes it is fun. I have purchased a few sheaths over time but this is much better I am finding, also I wouldn't have been able to purchase the ones that I wanted to make for my WW2 blades.
Jump in and show yours if you want to, Gohard pfr Chako and others have been really helpful with tips and ideas on how to improve mine. :cheers:
Andrew
au Offline sak60
Reply #115 on: August 07, 2017, 08:55:23 AM
Nice wallets!  :tu:
Thanks Chako
I would really  :like: to see that as well :)
Andrew
Reply #116 on: August 07, 2017, 09:35:20 AM
This 100%  :salute:
au Offline sak60
Reply #117 on: August 07, 2017, 10:22:13 AM
This 100%  :salute:
:cheers: Sparky
Andrew
ca Online Chako
Reply #118 on: August 07, 2017, 03:53:28 PM
Started the big move to the living room.
New workbench which was going to be my ammo reloading bench...but I couldn't drill into that beautiful wooden top. So the ammo stuff will go upstairs where my leather work station was, and the leather stuff gets to go downstairs.
A series of close ups of some of my stamps. swivel knives, modelers, etc... The tool holder was made for my by one of my woodworking colleagues at work.
Getting there.
Taking a break. Need to bring down my 2 marble slabs, 3 parts bins, all my dyes, etc...
I should be done by tonight.
« Last Edit: August 07, 2017, 03:57:30 PM by Chako »
ca Online Chako
Reply #119 on: August 07, 2017, 04:48:42 PM
Just moved a few of my multi-drawer storage organizers. Placing them on the floor is out of the way and easy enough when I need something from there to access.
And all of my chemicals just fit on the top shelf.
And just finished placing my two marble work surfaces. To get a real good impression when tooling leather, it is important to have a nice flat durable surface. These are sold for just the purpose. I first started out with a thinner piece that I sourced at a local monument shop...but that eventually broke. These have been good.
