A few days ago I got a black SOG Powerlock (with leather sheath) in the mail. It was in great shape but it had that "sandy" feel when opening the pliers/tools...a great excuse to strip it down and lube it up.
The sheaths. The darker one on the left is the one I just got, the right one is my EDC. The (I'm assuming) older sheath on the left is made of
slightly thinner leather...hardly noticeable unless you're holding both.
The one on the top is my EDC, the bottom is the one I just got. Notice no patent number and a different font size in the word "Powerlock".
The blades. The serrations are different between the two tools. The serrations on the top one are more traditional, whereas my EDC tool on the bottom has a tighter pattern and no "points".
The saw blades. The top blade is on my EDC and has a more agressive teeth on it whereas the other one has smaller teeth. You'll probably get cleaner cuts with the latter, but you can get through material faster with the former.
The plier heads. No differences...just wanted to post some worn and scratched black oxide!
Alright, now I've got to take this new tool apart. After all I can't really call myself a die hard fan of the Powerlock if I've never removed the scissors and put them back in...
First things first:
The tools:
Off with it's head:
Now the scissors. I've heard it's a pain in the neck to put this three peice impliment back in and it is. It helped that I had a built Powerlock next to me and steady hands
The only thing I ever did with this handle on my EDC tool was slide the bolt out enough to get the two washers out and put one between the knife and bottle opener. Why did SOG put two washers together between the 1/4" driver and bottle opener? Moving those around helps with the clumping between the blade and opener.
"Well used knife blade:
After I pulled everything out and wiped everything down, I applied some of this old graphite lube to anything that moved...only 39 cents!!!
