Take a look at the new WorkChamp, https://www.victorinox.com/global/en/Products/Swiss-Army-Knives/Large-Pocket-Knives/Work-Champ/p/0.8564 , the liner lock for the screwdriver is clearly visible. Also, the shape of the locking screwdriver is different enough that you can tell it's the Soldier frame that's in use. Even this Hunter https://www.victorinox.com/global/en/Products/Swiss-Army-Knives/Large-Pocket-Knives/Hunter/p/0.8573 has a visible linerlock for the main blade. I think the big change was when they adapted to making the locking liner available for just one of the ends, e.g. like on that Hunter or the new Sentinel. The liner locking Sentinel no longer has protruding liner at the opposite end from the blade.
I don't think they switched those models from slide lock to liner lock. The slide lock button is on the opposite scale (the scale without the logo), and not shown in the pictures online or in the catalog.
So no more Outrider?
Quote from: gregpost on July 11, 2017, 03:50:19 AMSo no more Outrider?The Outrider is now with a liner lock. Red or black scales.
Remember its not just the lock that was different.The slide lock version had different backsprings, and tools vs the liner lock. So they were making 2 separate sets of parts for the same size knives. Going with the liner lock only makes tons of sense! Heres the openers from both types. The mm values were how thick the steel was for that part. The pivot hole sizes were also different.(Image removed from quote.)
Too bad the Fireman's gone. I have an old and hard used one, linerlocked, and I think it's one of the best outdoor SAKs ever.
Remember it's not just the lock that was different.The slide lock version had different backsprings, and tools vs the liner lock. So they were making 2 separate sets of parts for the same size knives. Going with the liner lock only makes tons of sense! Heres the openers from both types. The mm values were how thick the steel was for that part. The pivot hole sizes were also different.(Image removed from quote.)
