Eleventh Anniversary SOG PowerAccess Giveaway
on: July 29, 2017, 10:40:30 AM
Yet another drool worthy prize to give away from the team at SOG Specialty Knives & Tools.   :cheers:
Enjoy easy component access and a great stone washed finish with the PowerAccess.     :ahhh    :multi:
How to enter the draw:
There is a paragraph on this PowerAccess Information Page.
The one beginning with "SOG's proprietary Compound..."
Simply add on the next two words.
The giveaway will end when the paragraph is complete.
One entry per member, open worldwide and regardless of post count.
Entries will be listed, shuffled and a winner decided by random dot org.
Re: Eleventh Anniversary SOG PowerAccess Giveaway
Reply #1 on: July 29, 2017, 11:22:20 AM
Leverage technology
cs Offline Vladimir
Reply #2 on: July 29, 2017, 11:23:26 AM
works by
Reply #3 on: July 29, 2017, 11:28:54 AM
Sigh.
Reply #4 on: July 29, 2017, 11:29:01 AM
SOG's proprietary Compound Leverage technology works by...
id Offline jaya_man
Reply #5 on: July 29, 2017, 11:55:36 AM
SOG's proprietary Compound Leverage technology works by employing multiple...
se Offline RF52
Reply #6 on: July 29, 2017, 12:00:26 PM
SOG's proprietary Compound Leverage technology works by employing multiple pivot points...
Sent fra min PLK-L01 via Tapatalk
ph Offline an0nemus
  • I Tool Therefore I Am
Reply #7 on: July 29, 2017, 12:20:04 PM
SOG's proprietary Compound Leverage technology works by employing multiple pivot points that generate...
Reply #8 on: July 29, 2017, 12:20:50 PM
SOG's proprietary Compound Leverage technology works by employing multiple pivot points that generate greater handle.....
Big thanks for the chance MTO :cheers: and for SOG for their generosity :salute: Big thanks for hosting this Zoid :like: :like:
Reply #9 on: July 29, 2017, 12:56:10 PM
Thanks.
SOG's proprietary Compound Leverage technology works by employing multiple pivot points that generate greater handle travel in
Reply #10 on: July 29, 2017, 12:59:49 PM
SOG's proprietary Compound Leverage technology works by employing multiple pivot points that generate greater handle travel in relation to
Thanks to SOG and MTO for the GAW. :hatsoff:
be Offline Top-Gear-24
Reply #11 on: July 29, 2017, 01:16:06 PM
Thank you SOG and thank you MTO  :salute:.
SOG's proprietary Compound Leverage technology works by employing multiple pivot points that generate greater handle travel in relation to plier movement.
us Offline 4everYoung
Reply #12 on: July 29, 2017, 02:33:45 PM
Thanks for the GAW opportunity
SOG's proprietary Compound Leverage technology works by employing multiple pivot points that generate greater handle travel in relation to plier movement. The result
ua Offline in_sympathy
Reply #13 on: July 29, 2017, 03:01:49 PM
is a
fi Offline Crow
Reply #14 on: July 29, 2017, 03:07:26 PM
SOG's proprietary Compound Leverage technology works by employing multiple pivot points that generate greater handle travel in relation to plier movement. The result is a leverage advantage
00 Offline Mechanickal
Reply #15 on: July 29, 2017, 04:15:01 PM
SOG's proprietary Compound Leverage technology works by employing multiple pivot points that generate greater handle travel in relation to plier movement. The result is a leverage advantage of approximately
Thanks once more SOG and MTO!
Reply #16 on: July 29, 2017, 04:35:36 PM
Cool giveaway and thanks again SOG.
ro Offline Corwyn
Reply #17 on: July 29, 2017, 05:21:22 PM
SOG's proprietary Compound Leverage technology works by employing multiple pivot points that generate greater handle travel in relation to plier movement. The result is a leverage advantage of approximately twice the
us Offline rdub934
Reply #18 on: July 29, 2017, 05:30:25 PM
SOG's proprietary Compound Leverage technology works by employing multiple pivot points that generate greater handle travel in relation to plier movement. The result is a leverage advantage of approximately twice the power of
us Offline captain spaulding
Reply #19 on: July 29, 2017, 06:23:10 PM
SOG's proprietary Compound Leverage technology works by employing multiple pivot points that generate greater handle travel in relation to plier movement. The result is a leverage advantage of approximately twice the power of a conventional
I'm the milk man!
Reply #20 on: July 29, 2017, 07:45:04 PM
SOG's proprietary Compound Leverage technology works by employing multiple pivot points that generate greater handle travel in relation to plier movement. The result is a leverage advantage of approximately twice the power of a conventional multi-tool, which
« Last Edit: July 29, 2017, 07:46:07 PM by pfrsantos »
es Offline ThePeacent
Reply #21 on: July 29, 2017, 07:56:47 PM
SOG's proprietary Compound Leverage technology works by employing multiple pivot points that generate greater handle travel in relation to plier movement. The result is a leverage advantage of approximately twice the power of a conventional multi-tool, which makes every
thanks much SOG!!
and of course,  :hatsoff: to the forum
My toys:
Reply #22 on: July 29, 2017, 08:03:16 PM
thanks much SOG!!
So you are not joining the GAW?
us Offline theonew
Reply #23 on: July 29, 2017, 08:04:41 PM
SOG's proprietary Compound Leverage technology works by employing multiple pivot points that generate greater handle travel in relation to plier movement. The result is a leverage advantage of approximately twice the power of a conventional multi-tool, which makes every cut smoother
us Offline MusicMen
  • 21 Badges for Eagle
Reply #24 on: July 29, 2017, 08:19:24 PM
Thanks SOG and  :MTO:
Good luck everybody!
BUCK: X-Tract, 360
*=mod
nl Offline glenfiddich1983
Reply #25 on: July 29, 2017, 09:28:52 PM
SOG's proprietary Compound Leverage technology works by employing multiple pivot points that generate greater handle travel in relation to plier movement. The result is a leverage advantage of approximately twice the power of a conventional multi-tool, which makes every cut smoother and sharper
[--- arms length ---] (-.-)
                                ^-- where the cat sits
us Offline theonew
Reply #26 on: July 29, 2017, 09:44:42 PM
sharper :think:
Reply #27 on: July 29, 2017, 09:51:17 PM
sharper :think:
Jup. Smoother and sharper  ::)
Whats wrong with that?  ::)
« Last Edit: July 29, 2017, 09:53:33 PM by glenfiddich1983 »
us Offline theonew
Reply #28 on: July 29, 2017, 10:00:06 PM
Reply #29 on: July 29, 2017, 10:01:13 PM
Not entering just wanting to say Thank you again SOG and good luck to all.
Side note, I have a PPP and cross grip and both have wonderful feel when used.  If you've never used a SOG the smooth action is pretty sweet.  I also love the lego-ability of these tools.
