Login
Register
Menu
Home
Help
Forum
Tool Talk
Leatherman Tools
The opposite problem - pliers too tight
aluminated
16 ·
4250
« previous
next »
Print
Pages:
1
Go Down
aluminated
Sr. Member
286
on:
August 03, 2017, 06:00:25 AM
This weekend I decided to pull off the Wave-with-Rebar-pliers (and vice versa) mod.
Although the Rebar pliers work great, these particular Wave pliers have always been overly stiff. I've oiled them but they only stubbornly open or close. Other than a decade of use, is there a way to free up the action a bit more?
Thanks very much.
Last Edit: August 03, 2017, 06:03:03 AM by aluminated
Merit Badges
SteveC
Global Moderator
Just Bananas
67,635
Re: The opposite problem - pliers too tight
Reply #1 on:
August 03, 2017, 06:29:25 PM
I don't know if it will work or not but ... You could try to hit the pivot on the moving side with the pliers supported so that the fixed side of the pivot is unsupported. Same as trying to tighten but with nothing on the back to support it the pivot might loosen.
Does that make sense ?
Like this but with nothing supporting the pivot
DSC08436_zpsqg3ugld5
by
SteveC
, on Flickr
Last Edit: August 03, 2017, 06:40:42 PM by SteveC
Merit Badges
AimlessWanderer
Zombie Apprentice
17,517
I'm not a pessimist, I'm an experienced optimist!
Reply #2 on:
August 03, 2017, 07:11:48 PM
I'd just try half an hour of soft wire cutting, which gets the pliers moving while under a bit of load. If you start trying to forcefully loosen the pivot, it won't be long before you're having to forcefully tighten it back up again.
aluminated
Sr. Member
286
Reply #3 on:
August 03, 2017, 11:05:31 PM
Hmmm. I had the Wave pliers on the Rebar handles all loosened up last night. Then I gave them an extra hard squeeze and they went right back to tight. Frustrating.
Since the swap I performed was for a friend, using his Rebar and his Wave, I don't think I want to hit it...yet.
What is the definition of "soft wire"? Coat hanger or solid copper or stranded copper or...?
Merit Badges
AimlessWanderer
Zombie Apprentice
17,517
Reply #4 on:
August 03, 2017, 11:13:45 PM
They were loose then went tight again?
Check the cutters for burrs/bruising, or anywhere else where something is catching
aluminated
Sr. Member
286
Reply #5 on:
August 04, 2017, 12:11:26 AM
They loosened to be more acceptable when I put them in the open configuration in a vise and torqued the handles a bit.
Then I gave them the hearty handshake treatment and right back to tight. There is no burr or bruising because they were purchased new and were not used. These are tight and consistent through their entire range of motion.
Gotta say that the top of the file is a bit stabby though.
Thanks for the help so far guys!
Merit Badges
AimlessWanderer
Zombie Apprentice
17,517
Reply #6 on:
August 04, 2017, 12:52:29 AM
If you got them loose enough, then a firm grasp re-tightened the pliers again, something is happening that I don't understand.
SteveC
Global Moderator
Just Bananas
67,635
Reply #7 on:
August 04, 2017, 01:23:28 AM
Yes that has me
as well
Merit Badges
Syncop8r
Absolutely No Life Club
8,763
Reply #8 on:
August 04, 2017, 01:34:45 AM
Simple - aluminated is the Incredible Hulk.
AimlessWanderer
Zombie Apprentice
17,517
Reply #9 on:
August 04, 2017, 02:33:55 AM
Quote from: SteveC on August 04, 2017, 01:23:28 AM
Yes that has me
as well
Glad it's not just me.
The only explanation I can think of (not suggesting this is happening, it's just the only thing that springs to mind) is galling on the plier pivot, or in the bore of the metal jaw on the pivot. I would have thought this quite unlikely though, and I've never heard of Wave pliers galling on the pivot.
aluminated
Sr. Member
286
Reply #10 on:
August 04, 2017, 03:08:28 AM
Here's a video showing the difference. I loosened at the vise first and the rest is on video.
Merit Badges
captain spaulding
Absolute Zombie Club
20,793
What's the matter, kid? Don't ya like clowns?
Reply #11 on:
August 04, 2017, 03:34:08 AM
I remember seeing a thread years ago about this exact pliers problem of them tightening back up after a strong squeeze. I do not remember the outcome of the thread though.
I'm the milk man!
aluminated
Sr. Member
286
Reply #12 on:
August 04, 2017, 03:37:56 AM
Thanks for looking anyway!
@ Hulk: I'm much more like Bill Bixby than like Lou Ferrigno.
Oh yeah, I didn't see the answer to the question of what constitutes "soft wire."
Anybody?
Last Edit: August 04, 2017, 03:39:43 AM by aluminated
Merit Badges
AimlessWanderer
Zombie Apprentice
17,517
Reply #13 on:
August 04, 2017, 11:56:30 AM
By soft wire, I meant copper wire
ducttapetech
Zombie Apprentice
18,707
Whiskey Tango Foxtrot, over.
Reply #14 on:
August 04, 2017, 01:29:59 PM
My Surge would tighten sometimes after a hard cut. Usually it would loosen after a while. I think there was some old metal shaving for wear it was first breaking in. About after a year of use, it quit doing it. I think it finally worked out the tiny metal shavings. I had a Swiss Spirit that did this also.
Last Edit: August 04, 2017, 01:31:51 PM by ducttapetech
Merit Badges
aluminated
Sr. Member
286
Reply #15 on:
August 05, 2017, 01:17:04 AM
Thanks again for the help, all.
Merit Badges
Print
Pages:
1
Go Up
Forum
Tool Talk
Leatherman Tools
April Goal:
$300.00
Due Date:
Apr 30
Total Receipts:
$158.99
PayPal Fees:
$9.20
Net Balance:
$149.79
Below Goal:
$150.21
Site Currency:
USD
Powered by
EzPortal
Search
This topic
This board
Entire forum
Google
Username
Password
Always stay logged in
Forgot your password?
