Axe redesigned after 8000 years!
gb Offline daverobson
on: August 18, 2017, 09:22:21 PM
Our resident axe experts will probably have seen this but I've only just come across it.
A Finnish inventor has redesigned the axe! To stop immediately on impact.
No more chopped legs.
http://www.dailymail.co.uk/news/article-2623425/Inventor-comes-redesign-axe-8-000-years-curved-blade-stops-swinging-straight-wood-leg.html
« Last Edit: August 18, 2017, 09:23:49 PM by daverobson »
Re: Axe redesigned after 8000 years!
Reply #1 on: August 18, 2017, 09:40:23 PM
I have seen clips of that in use, and it seems that it could be a strain on the wrists, and only has one function (splitting). Personally I feel happier with traditional patterns  :salute:
Reply #2 on: August 18, 2017, 09:54:41 PM
« Last Edit: August 18, 2017, 10:44:55 PM by daverobson »
us Offline thatotherguy
Reply #3 on: August 19, 2017, 01:12:43 AM
I don't think I would like how it twists on impact. I would have to hold it tight enough to swing without flinging but loose enough to allow it to twist without hurting my wrists. I too prefer the traditional designs. Perhaps they've been around essentially unchanged for so long for a reason.
us Offline kaput
Reply #4 on: August 19, 2017, 01:16:30 AM
How does it split the wood all the way through again? The wedge width?
nz Offline Syncop8r
Reply #5 on: August 19, 2017, 01:59:44 AM
Watch the slow motion video - it seems the blade striking at an angle and prising the wood apart works better than forcing the blade vertically through the wood.
Quote
Its centre of gravity, which isn't directly above the blade but to the side, means the axe automatically comes down at an angle to split the wood.
us Offline chrono
  • Find me if you can...
Reply #6 on: August 19, 2017, 02:48:39 AM
I am not chopping wood, so no expert. However, from observation, there are a few potential issues with this design:
- Strain on the wrist, as others pointed out: this design works like a shovel, but side way. The handle would rotate a bit in your hand
- Chopping only on one side: The blade curves toward left or right, depending on the design. I think one of your shoulder will hurt more than the other at the end of the day.
nz Offline Syncop8r
Reply #7 on: August 19, 2017, 03:09:21 AM
Perhaps they could make one where the handle stays as is and the head rotates upon striking the wood.  :think:
Reply #8 on: August 19, 2017, 11:25:14 AM
I think the head would turn prematurely from the momentum on the downswing
Reply #9 on: August 19, 2017, 11:36:35 AM
The inventor became a member here and kept linking to his page without permission and eventually got banned because he wouldn't listen to the mods and Grant about linking :facepalm: Most thoughts about it were the same as the above comments as well :cheers: :D
Reply #10 on: August 19, 2017, 08:00:55 PM
This guy rips it apart at the end  :facepalm:
https://www.youtube.com/watch?v=w_s3Ci1Dl0s
« Last Edit: August 19, 2017, 08:08:27 PM by SteveC »
Reply #11 on: August 19, 2017, 08:21:31 PM
 :oops::oops:
hr Offline styx
Reply #12 on: August 19, 2017, 08:25:50 PM
perhaps we should ask this delightful lady what she thinks about it
https://www.youtube.com/watch?v=7fWo0P0MdJM
nz Offline Syncop8r
Reply #13 on: August 20, 2017, 12:12:19 AM
Firstly: barefooted axe-girls... :dd:
Secondly: Also striking at an angle (or flicking it sideways), perhaps more easily done with a double bit as the centre of mass doesn't move when rotating.
Reply #14 on: August 20, 2017, 01:54:06 AM
:dd:
Reply #15 on: August 20, 2017, 02:25:39 AM
What those guys said above that vid
:dd:
 :like: :like:
nz Offline Syncop8r
Reply #16 on: August 20, 2017, 03:27:18 AM
I really shouldn't, but
no Offline Grathr
Reply #17 on: August 20, 2017, 07:45:55 AM
Thats impressive!
Reply #18 on: August 30, 2017, 01:48:24 PM
Honestly, I think I like the Kindling Cracker much better.... although I haven't tried either of them.
Reply #19 on: August 30, 2017, 03:40:03 PM
That's the first time I've seen the Kindling Cracker. :tu:
Good idea for a home wood burning stove or a larger camp site.
I'm not sure if I could take one wild camping or backpacking. :think:
I'd prefer the Barefoot Axe Girl :like:
« Last Edit: August 30, 2017, 03:43:13 PM by daverobson »
ca Offline JP
Reply #20 on: August 31, 2017, 02:15:57 PM
^^^ I agree.
Sent from my XT1563 using Tapatalk
hr Offline styx
Reply #21 on: August 31, 2017, 03:33:58 PM
That Kindling cracker might be onto something
ca Offline jzmtl
Reply #22 on: August 31, 2017, 10:54:03 PM
Even then it's still a solution looking for a problem, if it's too thin to stand up and slit from the end, just lay it flat on another piece and split one end of it, then twist axe handle and wood in opposite direction to finish splitting.
nz Offline Syncop8r
Reply #23 on: August 31, 2017, 11:50:31 PM
The intention of the kindling cracker is to make cutting kindling safer.
Reply #24 on: September 01, 2017, 12:24:17 AM
I know this rambles on for the first 9 minutes but this is how my Grandad used to cut his firewood.
https://www.youtube.com/watch?v=g_lMbV-Bm7c
Reply #25 on: September 01, 2017, 12:25:17 AM
https://www.youtube.com/watch?v=4-RhakR3Hg8
nz Offline Syncop8r
Reply #26 on: September 01, 2017, 12:57:46 AM
Same splitting tips in this video too (from about 2 minutes in):
https://www.youtube.com/watch?v=X5W6r5U7yBE
ca Offline jzmtl
Reply #27 on: September 01, 2017, 03:44:01 AM
Yep exactly that, all that's necessary is a different way to hold the wood instead of $150 lump of cast iron plus a club hammer.
hr Offline styx
Reply #28 on: September 01, 2017, 08:31:19 AM
Or they can simply invest in a splitting maul or splitting axe (supposedly there is a difference between the two :think: )
au Offline gregozedobe
Reply #29 on: September 01, 2017, 04:43:26 PM
A few months ago I did what I was told by my health professional and bought an electric powered kinetic log splitter.  In a couple of hours work today I split more firewood than I could have in a serous 1/2 a day with either my maul or my splitting axe (and a lot of it was curly grain eucalyptus which can be a real pain to split).  I can still move (albeit with a slightly stiff back) so while expensive it was money well spent.
June Goal: $300.00
Due Date: Jun 30
Total Receipts: $70.00
PayPal Fees: $4.19
Net Balance: $65.81
Below Goal: $234.19
June Donations
