Remade Knives SAK 91mm scale 3D model released to the public for free
us Offline Zhenchok
The rough look of them is nicer personally.
“All human beings have three lives: public, private, and secret.” ― Gabriel García Márquez
00 Offline bba952
I get conflicting opinions also about the CF nature of these scales. Whatever it is, it's tough. Even a group mate's effort to use dremel and smoothen it was disastrous
(Image removed from quote.)(Image removed from quote.)(Image removed from quote.)
I might be wrong but it looks like the material  he used to print the scales is a mix of carbon fiber and PLA ( a type of biodegradable plastic)  which does not take heat well. i would recommend next time getting them printed in ABS or nylon, and to make sure that the person printing the scales uses a smaller print nozzle
00 Offline Dutch_Tooler
Feedback to a related question by me in a 3D printing forum suggests that CF holding filament should be printed with at the smallest a 0.5, or better 0.6, mm nozzle...
Cheers!
Dutch_Tooler
ph Offline an0nemus
  • I Tool Therefore I Am
He did say it CF were added in the material. So it might be as you described. Two sets were printed, one with ABS and one with CF filament. Todate, no one has tried putting on the ABS yet as all of us are fascinated by the "CF" scales  :D
Thank you again for releasing the 3D data to the public, Brandon! It was so generous of you  :cheers:
00 Offline Mechanickal
I'll pm you my adres for those ABS ones :whistle:
ph Offline an0nemus
Admittedly, the first batch were of better quality than the 2nd batch. I'm not sure if this has anything to do with the nozzle used. But I'll share with him your feedback, DT. Helpful, as usual. Thanks!  :cheers:
ph Offline an0nemus
Okay, Nick!  :tu:
So seems like Jessan is actualy going to send them my way :facepalm:
Thanks buddy!
Now I do feel like a cheap smurf again though :bnghd:
Way to generous people here...
ph Offline an0nemus
Thanks buddy!
Just passing forward the good karma in MTO, Nick  :cheers: :tu:
us Offline El Corkscrew
Thanks buddy!
:tu: 8)
us Offline dkop1
  • Acknowledged blade-aholic who isn't seeking help.
Made these up with an SLS machine in Nylon 12. Will dye them later on
* IMG_20171201_114559-2976x2232.jpg (Filesize: 122.39 KB)
* IMG_20171201_114531-2976x2232.jpg (Filesize: 138.64 KB)
* IMG_20171201_114424-2232x2976.jpg (Filesize: 146.35 KB)
"Have yourself a nice long rest and be back here in twelve minutes."
"All the good times, that's what I'll remember. I think there were three."
us Offline zrxoa1
Grabbed a set from them on Etsy. Put on my Tinker that had been blacked out by syph007, for the previous owner...
ph Offline an0nemus
Cant wait to see them dyed!  :tu:
ph Offline an0nemus
Wow. Simply WOW. How about we call it Victorinox Stealth?  :like:
So black. 8) :like:
gb Offline VoetSak
Had a go at this tonight. Not quite there yet but heading in the right direction.
Looks best in 2 tone imho.
* rsz_20171203_041612.jpg (Filesize: 75.96 KB)
ph Offline an0nemus
That two-tone does look interesting...and unique  :tu:
Almost forgot. Do I have a set of these coming my way?? :pok:
ph Offline an0nemus
I'll trace where they are right now, Mechanickal
ph Offline an0nemus
Hi, Nick! PM sent. Bad and good news
wales Offline hiraethus
  • I brake for cake
Looks great. :cheers:
us Offline zrxoa1
U miss it??  LOL
  • I brake for cake
Hah, no.  Well, maybe a little. :facepalm:
us Offline schiesz
I have these files and there is some kind of "error" in the STL file, and it has a few stray bits that shouldn't be there.  Then other error is that the back scale has several pieces and it makes it basically impossible to modify (I was planning on adding a pin hole like the Plus scales have). I tried importing it into a few different programs and exporti g it again but always have the same "errors" that make it tough to modify.  Maybe they did that on purpose, to protect their IP,  although they seems fine with people using it.
Anyone else have trouble with this?
Total Receipts: $168.99
PayPal Fees: $9.87
Net Balance: $159.12
Below Goal: $140.88
53%
