Firefly Ferro rod.
Zed · 338 · 23456
us Offline TonySal
Re: Firefly Ferro rod.
Reply #300 on: May 31, 2018, 09:22:50 PM
Are you guys kickstarter beneficiaries? ....
I use the toothpick more than the tweezers, so I too would rather have it fill the tweezer hole :/
Charles.
Yes, and I agree that some more flexibility might be hoped for...
Yes, I was and as Duck says, must be backorders- went over by months!
join KNIFE RIGHTS
us Offline TonySal
Reply #301 on: June 25, 2018, 11:45:35 PM
Must be the scales, falls right out of two of mine.
Will use a piece of clear tape, fire would be for emergency only anyway.....  :rant:
join KNIFE RIGHTS
us Offline TonySal
Reply #302 on: July 17, 2018, 04:05:16 AM
... and also,  not much luck with anything but the SAK saw back ...
Could be me......
join KNIFE RIGHTS
us Offline TonySal
Reply #303 on: July 20, 2018, 12:08:19 AM
Uh... oops, holding SAK up to the light, I could see the scale was not snapped all the way. So I fixed and the FF is in ok- still not the best item, but I want to be fair....my fault on this one...
« Last Edit: July 20, 2018, 02:51:07 AM by TonySal »
join KNIFE RIGHTS
us Offline TonySal
Reply #304 on: July 27, 2018, 12:15:52 AM
...and I take back the previous apology... picked up Huntsman and Tinker, fell right out, brand new!  Temp and humidity changes? Lowering to C- real fast.
Tests continue...
Comments guys?    :rant:
join KNIFE RIGHTS
Reply #305 on: July 27, 2018, 03:02:00 PM
Could be me......
Given the idea of the FF, I think it would be best suited to carry in a SAK with saw.  While I'm not saying its the best idea the small blade could work too.  If in an emergency I'd have no problem striking a ferro rod with my knifes edge.
Reply #306 on: July 27, 2018, 03:07:15 PM
Tests continue...
While the temperature here in SoCal is relatively stable we do get change.  I've not had any issue with any scale tools on my SAKs.  Does the FF easily fit or is there some resistance when putting into the space.  I wonder if a bit more resistance would have been better?  For example, on my Swisschamp, the pen has some resistance both withdrawing and inserting, same on my CT29.  Might be some sort of slight bend in the pen but its a positive feel and never an issue of the pen coming out.
ca Offline Syph007
  • SAK Surgeon
Reply #307 on: July 27, 2018, 04:06:46 PM
Tests continue...
You are correct about how the pen retains.  Its not the pen that is bent though its the channel.  If you look down the pen slot on a plus back scale when removed you can see its not straight.
SO..
Pen - retained by bent channel in scale
Tweezer - retained by spring opening force of tweezer
Toothpick - retained by little notch that is part of the toothpick that engages in the plastic slot
This is why from the beginning I said it wasn't a good method for retention to just rely on friction.  Told the maker that too, noone cared.  I still recommend just getting a firesteel meant for carry on a keyring and put that on a sak keyring.  More practical and wont be lost.  There are tons of options for that.
« Last Edit: July 27, 2018, 04:07:50 PM by Syph007 »
Modding thread : Here
Website : WWW.SAKModder.com
Facebook : SAKModder
Instagram : robertjlessard
us Offline TonySal
Reply #308 on: July 28, 2018, 12:07:33 AM
Thanks  :salute: don't think it was really meant for a SHTF situation, novelty idea...I think Vic would have come up with something if they thought it viable option.
join KNIFE RIGHTS
us Offline TonySal
Reply #309 on: July 28, 2018, 12:11:13 AM
...and thanks Syph and Aloha for responding to the new guy.
 :salute:
join KNIFE RIGHTS
Reply #310 on: July 28, 2018, 07:10:04 AM
Thanks Syph.  I'll have to look at my plus scales more closely.
Reply #311 on: July 28, 2018, 07:11:23 AM
Can you find some method for better or more secure retention?  Its still a neat idea but you certainly don't want it to fall out.
us Offline TonySal
Reply #312 on: July 28, 2018, 02:24:35 PM
I suppose you could put a tiny piece of clear tape over it... :think:
join KNIFE RIGHTS
us Offline this_is_nascar
Reply #313 on: July 29, 2018, 02:09:39 PM
I ordered a variety pack of these and have been disappointed.  I'm not having much luck using these in any if my SAKS.
They either won't go in at all it will slide out if they do go in.
Sent from my XT1635-01 using Tapatalk
"The only way to stop a bad guy with a gun is a good guy with a gun". --- Wayne LaPierre 12/21/2012
us Offline TonySal
Reply #314 on: July 29, 2018, 02:13:30 PM
... and only decent striker seems to be the SAK saw...   :rant:
« Last Edit: July 29, 2018, 03:25:24 PM by TonySal »
join KNIFE RIGHTS
us Offline TonySal
Reply #315 on: August 02, 2018, 01:39:24 PM
Got one to stay on my Huntsman plus scales by putting the scale tools in the wrong slots,  can't tell...unless you look closely.
join KNIFE RIGHTS
Reply #316 on: August 02, 2018, 02:51:56 PM
Thats a simple work around.  Hope it stays put.  I sure hope fire fly is listening to the feed back.  I still thing the idea is neat.
us Offline TonySal
Reply #317 on: August 04, 2018, 06:38:15 PM
I dunno A007, you're too nice, all these issues... think we should get on the net and swat this Firefly?
join KNIFE RIGHTS
Reply #318 on: August 05, 2018, 06:47:05 AM
I hoped they would have tested and tested on a lot of SAKs.  New and used.  Come on fire fly people are you listening?
00 Offline Dutch_Tooler
Reply #319 on: August 05, 2018, 10:45:21 AM
I have one in the Swisschamp which hasn't fallen out yet. And I'd even taken that scale off for opening the slot for the short tweezers and put it back on. The slot for the long tweezers on the other scale is now occupied by the toothpick after a minor filing off of its head.
* 752018104822.jpg (Filesize: 140.75 KB)
* 752018104839.jpg (Filesize: 153.57 KB)
« Last Edit: August 05, 2018, 10:50:59 AM by Dutch_Tooler »
Cheers!
Dutch_Tooler
Reply #320 on: August 05, 2018, 01:29:20 PM
I was able to get one into my Executive.  I'd imagine that as you use it, it will get loose fitting in the cavity.
us Offline TonySal
Reply #321 on: August 25, 2018, 04:23:26 AM
After all the mods and work arounds, does it make a damn fire like in their video?!?
If not.... SWAT !!
join KNIFE RIGHTS
Reply #322 on: August 25, 2018, 07:21:15 AM
I've grown very fond of tinder quick or wet fire.  Easy enough to carry and well worth the time to find a way to carry them.  One spark should be enough in an emergency even from this firefly.  I bought some cheapo ones and they worked well enough.  I also have some wicked storm matches.  Good gosh they are hard to put out.
us Offline TonySal
Reply #323 on: August 25, 2018, 02:43:47 PM
...007, are you actually in Hawaii. If be real careful during storms.
join KNIFE RIGHTS
Reply #324 on: August 25, 2018, 03:25:26 PM
I'm in California, thank you tho.   :salute:
us Offline TonySal
Reply #325 on: September 25, 2018, 06:50:22 PM
Going back to the pen in my Huntsman plus scales.
Not putting things in backwatds to prevent the FF from falling out or tape to hold it in, not suitable for real emergencies anyway imho.
Swat the FF
join KNIFE RIGHTS
Reply #326 on: September 26, 2018, 12:38:15 PM
Has anyone actually tried this?  I've not as yet.
Reply #327 on: September 26, 2018, 04:17:37 PM
Might be a case of really neat idea in theory but in a practical application not so much.  On a side note, these make more sense to me  :tu:.  Or something similar.
 https://www.amazon.com/dp/B00PSGOH3C/ref=sspa_dk_detail_0?psc=1&pd_rd_i=B00PSGOH3C
us Offline TonySal
Reply #328 on: September 26, 2018, 05:36:11 PM
I got spark but only from the Huntsman saw back 90 edge. Only tried tissue paper, didnt work but not the best tinder. Something up with their video or correct tinder was used.
Yes I've seen the toggles recommended by outdoor types :)
join KNIFE RIGHTS
Reply #329 on: September 26, 2018, 06:04:43 PM
Attach the toggle to any outdoor gear and you are good to go.  Heres what I like.  Its a clone of the Nanostiker.  I added a piece of "tinder quick" type cotton.  Its super flammable with just a spark.  I also keep jute in a small hank handy.  The clone nano striker is small enough IMO to keep on a keychain.  Its also not threatening looking.  No-one would know what it was.
* IMG_5882.jpg (Filesize: 196.13 KB)
* IMG_5881.jpg (Filesize: 197.03 KB)
