Battery terminal cleaner ?
Here's an easy one, but you have to say what each part is specifically for.Perhaps if you know what it is you may want to keep quiet and let others guess... Show contentThat means you Zoidberg
Quote from: Syncop8r on August 25, 2018, 12:19:17 AMHere's an easy one, but you have to say what each part is specifically for.Perhaps if you know what it is you may want to keep quiet and let others guess... Show contentThat means you Zoidberg Combination wrench for spark plug / wheel nut and screwdriver handle also usable for removing hub caps?
Design fault: the chain tension screw is too close to the bar to use the screwdriver (the wrench parts get in the way).
Yeah I loosen off the bar nuts a bit... but the bar is still in the same place.
