Tool Name: Skeletool X
Basis: Skeletool
Aim: Add that little something I've been missing from carrying the Skeletool around.
Mods:
1. Removed most of the liner that holds the spare bit.
2. Added scissors from A Gerber Truss (dropped right in and I also put in a thin washer to get just the right amount of friction)
3. Modified scissor shape for even better fine work and took off a smidgen from the bit that presses against the spring so that the tip of the scissors near the pivot wouldn't accidentally get pushed up when closed.
4. Designed and 3D printed an insert to the carabiner head that can hold 2 bits to replace the extra bit spot I lost.
Links:
