A lot of cheap-o MTs have a bit kit that has a square shank hole on one end and 1/4 hole with magnet on the other. Some tend to be 1/16th of an inch too short for the Gerber phillips, so a bench grinder can easily shave enough off to work. After grinding it down until the depth is right, just file the inside and outside down smooth so it doesn't put any marks on the phillips shank.Proper adapters can be found online, but are more expensive.
Does anyone know a bitholder that will fit the gerber mp800 with or without modification?Sent fra min PLK-L01 via Tapatalk
Quote from: RF52 on November 15, 2017, 01:43:47 PMDoes anyone know a bitholder that will fit the gerber mp800 with or without modification?Sent fra min PLK-L01 via Tapatalkthe bit holder from Ganzo tools is perfect fit, the Leatherman bit extender for the ST300, Rebar, Blast, Fuse and Kick too and of course the MP600, MP700 bit holder also fits perfectly.As said before, many cheap MTs come with bit kits that fit the Legend Phillips screwdriver
