I've drank the coolaid
us Offline Tarheelpwr
on: December 16, 2017, 03:58:52 AM
Just stumbled onto this site. I've been picking up leathermans recently while Cabelas had the promos.  I think I'll be modding some shortly. A mini-surge and modified rebar seem to be in order.
es Offline ThePeacent
Re: I've drank the coolaid
Reply #1 on: December 16, 2017, 04:20:54 PM
looking forward to it!   :salute:
You picked the two go-to Leatherman in my opinion
My toys:
Reply #2 on: December 16, 2017, 05:05:39 PM
 :cheers: have another.
Welcome to MTO.
Reply #3 on: December 16, 2017, 05:33:50 PM
I can't wait to see the mods :like: :like: and welcome to :MTO: again Tarheel :cheers:
Reply #4 on: December 17, 2017, 05:16:22 AM
Thanks!
I did some more comps, and I might be ahead to do a Re-Charge TTI.  No sense is starting with a Wave and then swapping the main blades to Charge ones when I could just start with a Charge TTI and be money ahead. They would both be new purchases at some point down the road. I need to pump the brakes a bit after I pick up a Rebar right now though.
Or, I need to decide if I really care about the cutting hook and higher quality steel blade. If not, wave/mini surge is the way to go.
I'm gonna be keeping an eye out for a $20 off $100 promo from Cabelas. I have $35 cabelas bucks from the Surge I picked up today.  The Rebar and bit kit/extender are gonna be it for a bit.  I've made good use of the current deals. Lol.
Reply #5 on: December 17, 2017, 03:38:40 PM
I also had a question pop up. Is there room in a TTI or Wave to add a modified awl and package opener after I remove the scissors?  Or is it a 1:1 trade?
How about in a Rebar. Is there room to add modified charge scissors without losing anything, or will I have to give up something?
« Last Edit: December 17, 2017, 03:42:35 PM by Tarheelpwr »
00 Offline Dutch_Tooler
Reply #6 on: December 17, 2017, 04:23:13 PM
Time to break out the calipers... tool widths, all in mm:
Wave/Charge/Rebar range:
Scissors 2.50
Large flat screwdriver 2.40
Small flat screwdriver 1.80
Phillips driver 5.00
Large bit driver 5.00
Mini bit driver 2.00
Awl 1.80
Can/package opener 1.90
Rebar:
PE blade 1.80
SE blade 1.85
Saw 1.80
Wave file 1.85 (just in case...)
« Last Edit: December 17, 2017, 04:42:51 PM by Dutch_Tooler »
Cheers!
Dutch_Tooler
Reply #7 on: December 17, 2017, 10:38:38 PM
Wow,DT.  Thanks for all that info.
Is there any slack in a stock Rebar?  Just wondering if I could stuff a pair of scissors without removing anything?  I'm guessing not. I won't have my Rebar for a week or two to examine.
Reply #8 on: December 18, 2017, 04:43:31 AM
You have to reorder things a bit and remove the lanyard ring and maybe a washer :think:  you can add scissors without loosing any tools :salute: :like:
This is my config :cheers:
1121170719a~2 by Poncho 65, on Flickr
Reply #9 on: December 18, 2017, 06:26:13 AM
Thanks Poncho.  Now I'll just have to wait for the Rebar to arrive and the piggy bank to fill back up for a TTi.  I'm assuming the TTi pliers will fir the Rebar with no issues.
Reply #10 on: December 18, 2017, 07:20:31 AM
Valid assumption, the Rebar pliers are a little bit wider and thicker in the widest bit at the plier main pivot than the Charge/Wave ones, which are also more rounded off generally.
Cheers!
Dutch_Tooler
Reply #11 on: December 18, 2017, 02:27:28 PM
What DT said :D I also have a Rebar with that plier head but I got that one in a trade so I can't comment on how easily it went in :salute:
But FYI getting a plier head back into a Rebar frame is a bit of a pain :ahhh :D
Reply #12 on: December 18, 2017, 06:12:01 PM
Good to know.  I'm not 100% sure I'm going to be taking these apart myself.  I might be soliciting the help of others with more experience.  I'd like to get pliers back in the rebar.  I was hoping to stash them in the car emergency kit.
Reply #13 on: December 18, 2017, 08:20:35 PM
It can be, yes, due to the plier springs in the handles and the washers. I find it helps to assemble in the closed pliers position: apply finger or vise pressure on the handle sides at the plier pivot level, then insert the rear end of a 5 mm drill bit opposite the pivot hole side where you insert the pin, then insert the pin and wriggle the drill bit while pushing the pin into place and varying the finger/vise pressure, all at the same time of course :D :D (cover the vise jaws with inner tube or other soft material to avoid scratches on the handles).
« Last Edit: December 18, 2017, 08:22:40 PM by Dutch_Tooler »
Cheers!
Dutch_Tooler
Reply #14 on: December 18, 2017, 08:32:18 PM
Thanks again for the input.  That sounds simple, but I'm sure it took some frustration to figure out that sequence.  It also sounds like a reason to pick up a Crunch since you needed vise grips  :drool:
On a side note, Victornix has OUTSTANDING customer service.  I emailed them and asked to purchase an extra 91mm scissor.  They put a one time complimentary set in the mail same day.  The small gesture worked.  I was on the fence with springing for their knives for game processing, but that gesture sealed the deal.
Reply #15 on: December 19, 2017, 03:31:44 AM
Great advice DT :cheers: :like:
Also I am intrigued that they sent you extra scissors :think: Let us know for sure that it is an extra set of scissors and not just the spring :tu:
Reply #16 on: December 19, 2017, 05:19:35 AM
Will do. They definitely said pair of scissors twice, but we'll see.
I was also looking at some online reviews of Charge vs Wave. I was surprised how much larger the Charge was.  Is it as noticeable as it looks?  I know the weight is similar, I'm wanting this tool to be carried a lot, likely pocket carried. I'm a bit concerned about the profile and thinking about changing my mind to a Wave base tool.
us Offline El Corkscrew
Reply #17 on: December 19, 2017, 05:25:49 AM
so the real question is, how you likin' the 'heels NCAA chances this year???
Reply #18 on: December 19, 2017, 05:32:24 AM
This handle is a LONG story. I'm more of a Duke fan. Don't have much time to follow anything right now unfortunately.
Reply #19 on: December 19, 2017, 06:32:45 AM
God bless you. :pok:
* maxresdefault-2.jpg (Filesize: 104.19 KB)
* C1XW9-GXEAAbcXE.jpg (Filesize: 96.94 KB)
« Last Edit: December 19, 2017, 06:34:34 AM by El Corkscrew »
Reply #20 on: December 22, 2017, 10:34:34 PM
Good news and bad news. Vic scissors arrived and they were full scissors.  Bad news they were the wrong ones.  :facepalm:
« Last Edit: December 22, 2017, 10:36:38 PM by Tarheelpwr »
Reply #21 on: December 23, 2017, 02:18:54 AM
At least they are Vic scissors and those are very nice ones as well :salute: To bad they aren't the ones you were needing though :facepalm:
A piece of straw on the end and they can be pocket carried though :cheers:
Reply #22 on: December 23, 2017, 01:30:55 PM
well that was unexpected   :ahhh
But I agree with Poncho in that they are very nice and useful to carry around, for instance like I did a few years back
(I had a tiny winey nail file with sheath and the scissors fit perfectly in that sheath, and I carried them in the shoulder bag for emergency detailed cutting until I gifted them to someone who I'd knew would use them more and carry them in their purse)    :salute:
My toys:
Reply #23 on: December 23, 2017, 01:40:31 PM
Well.... They tried.  :ahhh
I wasn't expecting them to send 91mm parts as such, they aren't like the SOG of old in that respect.  :cry:
At least you have a cool pair of SwissCard scissors to EDC.  :tu:
« Last Edit: December 23, 2017, 01:42:46 PM by Pablo O'Brien »
us Offline Obi1shinobee
Reply #24 on: December 23, 2017, 08:50:57 PM
 :ahhh :ahhh :ahhh
Reply #25 on: December 24, 2017, 02:03:37 AM
Yea, I'm not complaining.  They didn't cost me anything. They just got my hopes up. I hated the idea of having to buy a tool just for those scissors.
What is the cheapest way to get a pair of 91mm scissors?
Reply #26 on: December 24, 2017, 02:53:04 AM
Climber. Definitely.
Reply #27 on: December 24, 2017, 03:02:50 AM
I'll check it out.  Those don't look like they're 91mm, but I'm new to SAK.
Reply #28 on: December 24, 2017, 05:02:14 AM
There is a small Climber as well I think :think:
Reply #29 on: December 24, 2017, 02:51:40 PM
Looks like Google got me. I found one that was listed at 3.5".  Their website lists it at 4" and Amazon calls it a 91mm model.
Total Receipts: $168.99
PayPal Fees: $9.87
Net Balance: $159.12
Below Goal: $140.88
53%
