The only way I could ever get it to work is on 14 or 16 gauge wire, when part of it was already stripped enough to fit the wire in the notch. By then you could go ahead and finish stripping the end with whatever you used to get the stripper notch to work. I might be using it wrong too. I think there are some creative uses for it, like bending wire or something, but I consider it fairly useless.
Quote from: twiliter on December 30, 2017, 05:16:22 PMThe only way I could ever get it to work is on 14 or 16 gauge wire, when part of it was already stripped enough to fit the wire in the notch. By then you could go ahead and finish stripping the end with whatever you used to get the stripper notch to work. I might be using it wrong too. I think there are some creative uses for it, like bending wire or something, but I consider it fairly useless. Yep, but maybe someone hacked it and found the right way to use it, so I decided to ask
That only works on models with the stripper in the next layer over to the blade, Soldier, Spartan, Compact, etc., not so easy on a SwissChamp. Also he is using the blade to strip the wire, the notch is pretty superfluous. I have seen that video, thanks for retrieving it VM. I generally use a set of side cuts to strip wire, pinch the insulation twice then pull the end off, but if I was going to do it a lot I think I would invest in a Squirt ES4.
If you will open the main blade on the knife and then open the bottle opener to 90 degrees you can lay the wire to be stripped across the handle and put it in the notch, then close the main blade gently on the insulation of the wire and rotate the knife or the wire until the insulation is notched all the way around. Then open the blade, remove the wire and use the notch in the bottle opener to pull the insulation off of the wire.Here is a video I just found on the internet (the only difference between the way he uses it and the way I use it is that I use the notch to pull the insulation off.)
Quote from: VICMAN on December 30, 2017, 06:27:23 PM Still I find the wire stripper on my Wave much more useful and overall better designed.I will agree that the wire stripper on the Wave is more efficient in comparison.
Even if it's not so good for stripping insulation, the notch is useful for bending thick wire.
Now I’m thinking of making a V-notch on my Forester out of that strange stock stripper
