Leatherman MUT - Fire Starter Mod (New Version)
Guest · 8 · 2539
nuke
  • Guest
on: January 05, 2018, 01:55:12 PM
Hi friends,
Today, I will share with you the mod I made. (new version)
I have done this before, today I am presenting a better case.
This one is a fire starter. This mode is portative. I can change the magnesium rod whenever I want. I just have to create some screw mount for the magnesium rod, that is really easy to create something like that. Also I can use the rod on my Leatherman, I don't need to take out. It's strong.
The old one is here: https://forum.multitool.org/index.php?topic=73814.0
Good day.
Re: Leatherman MUT - Fire Starter Mod (New Version)
Reply #1 on: January 06, 2018, 11:39:34 PM
Excellent mod, nuke :tu: How did you make the brass part :think: :cheers:
Reply #2 on: January 07, 2018, 12:00:58 AM
Nice !   :tu:
00 Offline Dutch_Tooler
Reply #3 on: January 07, 2018, 10:46:12 AM
@Ponch, I can see tell-tale signs of a turning bit so I'm guessing a lathe.
Cheers!
Dutch_Tooler
nuke
  • Guest
Reply #4 on: January 08, 2018, 01:38:32 AM
Hi,
Firstly, I cut the brass metal 0.6 centimeters in diameter and 2.5 centimeters in length then I punched a hole in the center of it 0.3 centimeters in diameter. Finally, I created some screw mount for the magnesium rod and that brass part. That's it. :)
Thank you. :cheers:
nuke
  • Guest
Reply #5 on: January 08, 2018, 01:39:39 AM
Yes, you are right. ::)
nuke
  • Guest
Reply #6 on: January 08, 2018, 01:53:08 AM
I think this picture is very descriptive.  :salute:
Reply #7 on: January 08, 2018, 02:37:01 AM
 :cheers: :cheers:
Total Receipts: $55.09
PayPal Fees: $3.15
Net Balance: $51.94
Below Goal: $248.06
17%
