A rock is a better multi-tool than the Magnus.
The openers and cord cutter seem to have good retention, but the cord-cutter seems too thin to have a Phillips on its tip. Not to mention it does not lock, and is bladed, so, not the best implement I've seen. There are three short implements there. Have a claw opener, like Leatherman, to cover the openers, and then, in the two remaining slots, have a nice, thick, square shank Phillips, so that you can fit the Ganzo adapter and get more use out of the tool. Retention seems adequate, the cord cutter is not really needed on a tool that has a one-handed blade. I am pretty sure I'll get it. Lots of reviews on it, mostly Russian, but the handles seem smooth, and everything works on it. As for Leatherman wire-cutters fitting in there, I guess I'll have to test that out myself. Even if they do not fit, I imaging they'll start selling replacements separately. If so, I'll probably get a set. And they might even fit my LM tools. Fingers crossed.
Likely non-locking so it can be sold in the UK and EU countries that ban locking blades. He should have cut it a little deeper and then filed the tang until it was a tight lockup. His lockup is too loose. Charles.
Yup, just like I feared. Looks like I'll have to swap the can opener position again, like in the Storm. Can opener could not hook on the can when used right-handed. It is too deep in the handle. Left-handed it works.(Image removed from quote.)
Also, do Leatherman wire-cutters fit in its pliers? They look like they're the same shape.
RP,To be completely honest, the Roxon 801 seems like a way better tool overall. The NexTool looks cool, but the drivers are awful looking and the frame looks less refined than the Roxon 801. So, besides a hard-wire thing in the back of the pliers pivot, replaceable cutters(if you can even buy extras), a longer PE blade, slightly better can opener, and locking saw; what is the point? You lose the nice Roxon file(with nice driver on tip), fantastic bottle opener, corkscrew, locking phillips driver(which mounts the bit driver), and the nail puller. Am I missing something?
