Fitting kick pocket clip to a crunch problem
Wspeed · 28 · 2494
on: January 25, 2018, 06:18:11 PM
Got my kick pocket clip and screw from Loki-mobile yesterday
So got round to have a go today trying it on my LM crunch
But the screws are a different the crunch screw is course thread
And the kick screw is fine thread  :rofl:
I really want the kick screw as the head is bigger to cover the kick clip
And the crunch screw is the same size as the kick clip hole so won't stay?
So what are my options ? a screw sleeve from a other LM maybe
Any help much appreciated
I have seen LM crunches with the kick clip and kick screw fitted  :ahhh
* image.jpeg (Filesize: 182.3 KB)
Re: Fitting kick pocket clip to a crunch problem
Reply #1 on: January 25, 2018, 06:33:28 PM
Is there a hardware shop nearby that might have the screws you need?
 :think: :think:
00 Offline Sam Lim
Reply #2 on: January 25, 2018, 06:39:45 PM
I think you will need the original kick pivot screw for the clip's screw to work. It have a pre threaded hole for the clip's screw. I dun think just by using the crunch's pivot screw and and screw will work properly. U will probably not be able to balance the tightness of the internal implement with the wobbiness of the clip..
Reply #3 on: January 25, 2018, 06:54:30 PM
 :think: :think:
Hi no not for screws that look like the LM ones
Only normal type fastners!!
                                             :think:
I agree i was thinking of a pivot screw from a LM kick or other LM maybe  :like:
00 Offline Sam Lim
Reply #4 on: January 25, 2018, 07:00:19 PM
 :think: :think:
                                             :think:
Simplest, cheapest way, get a kick and scrutinise that particular screw. I would like to think the pivot screw on the wingman/sidekick series on the pocket clip side should also work. They are the same dia. And torx are easier to work with than knurled screw!
Reply #5 on: January 26, 2018, 07:11:24 PM
Apart from the thread pitch being different  :bnghd:
It's a 5mm thick pivot just like the wave scissors have
So hopefully other LM multitools might work? as long
It's got the same thread pitch as the LM kick  :think:
Length if longer is fine as it can be cut down to size  :ahhh
Reply #6 on: February 02, 2018, 02:15:55 AM
Any progress on this :whistle: I hope you have found a way to do this :salute:
Reply #7 on: February 02, 2018, 01:59:37 PM
Hi yes I got loki-mobile looking for one at the moment
He found one that looks good, but I'm waiting for a pm to let me know
How long the pivot is  :think:
Hopefully soon than I can show some photos with the clip fitted  :tu:
au Offline pietervn
Reply #8 on: February 03, 2018, 07:29:58 AM
G'Day,
As far as I know you will need the original Kick pivot bolt too. The clip is designed to screw into the threaded Kick pivot when you add the clip.
Have a look at this thread: https://forum.multitool.org/index.php?topic=42112.0
Pete
Offline george1
Reply #9 on: February 03, 2018, 11:08:40 AM
lf the original Crunch splined head fits the Kick pocket clip you can do what l did when l added one to  PST.
Basically  l drilled and tapped the orignal pivot (the long part) using the original thread type.
l then purchased a stainless button head torx screw and used this to hold the clip in place.
lts a bit more work but at least l didn't have to waste a Kick.
Cheers
George
Reply #10 on: February 03, 2018, 01:17:15 PM
Hi thanks for your reply  :like:
G'Day,
Pete
Cheers
George
This is what I got coming from loki-mobile :tu:
* image.jpeg (Filesize: 262.78 KB)
Reply #11 on: February 04, 2018, 04:44:17 AM
Reply #12 on: February 04, 2018, 04:58:51 AM
:popcorn:
Re: Fitting kick pocket clip to a crunch problem (Update)
Reply #13 on: February 09, 2018, 07:27:47 PM
The pivot screw came in the post today  :mail:
I don't know what model LM the pivot screw came off
But the pivot that holds the tools is 13.6mm in length
And the pivot from the LM crunch is 12.6mm in length
After filing off 1mm from the pivot that holds the tools
I Than had to file the head a bit thinner
from 1.10mm to 0.85mm
This is as the thickness of the kick clip is 1.02mm
So the kick screw wasn't stoping the kick clip from rattling
About without making the head thinner
I didn't have to change or use a file on the LM crunch
So can still be returned to standard  :tu:
* image.jpeg (Filesize: 63.18 KB)
* image.jpeg (Filesize: 194.29 KB)
* image.jpeg (Filesize: 181.8 KB)
* image.jpeg (Filesize: 167.86 KB)
« Last Edit: February 09, 2018, 07:36:36 PM by Wspeed »
Reply #14 on: February 09, 2018, 09:48:09 PM
Very nice 8) Would definitely make me want to carry the crunch more :like: :like:
Reply #15 on: February 09, 2018, 10:00:02 PM
That looks alright that does! It really suits a clip... (wait for It, wait for it)... nice one!!!  :salute:
00 Offline Dutch_Tooler
Reply #16 on: February 09, 2018, 10:13:48 PM
:imws:, both of them :2tu:
Cheers!
Dutch_Tooler
Reply #17 on: February 09, 2018, 10:28:42 PM
Very nice addition  :like: :tu:
Reply #18 on: February 09, 2018, 10:37:51 PM
Thanks everyone  :2tu:
It looks like it's made for the crunch  :like:
au Offline pietervn
Reply #19 on: February 11, 2018, 08:45:54 AM
That looks really nice.
Does it wear comfortably in your pocket?
Cheers
Pete
Reply #20 on: February 11, 2018, 12:21:39 PM
Hi yes got it in the right hand front pocket
You would almost forget it's there  :tu:
Reply #21 on: February 18, 2018, 06:31:10 PM
Update pic
Wearing the pocket crunch :salute:
* image.jpeg (Filesize: 302.45 KB)
Reply #22 on: February 18, 2018, 06:47:39 PM
Looks great!  :salute:
Reply #23 on: February 18, 2018, 06:56:44 PM
Thanks Fuzzy  :tu:
I don't even know that I am wearing the pocket crunch  :salute:
es Offline ThePeacent
Reply #24 on: February 18, 2018, 07:04:56 PM
Update pic
neat!   :like:
My toys:
Reply #25 on: February 18, 2018, 07:19:57 PM
Thanks ThePeacent  :tu:
Reply #26 on: February 18, 2018, 09:15:33 PM
Reply #27 on: February 18, 2018, 09:19:56 PM
Thanks Zoidberg  :tu: :like:
