Show us your fixed blades
Benner · 4755 · 341609
Re: Show us your fixed blades
Reply #1590 on: June 25, 2015, 02:48:23 AM
How do you the Bushcraft Black?
I love mine.
That's us mobile
us Offline SAK Guy
Reply #1591 on: June 25, 2015, 05:50:16 AM
Just in today....looks and feels awesome!!!!!! Sharpened up effortlessly....it might be the knife for all my emergency and camping bags....great grip too, might be the total pkg!!!! :tu:
- Robert
Quo Fata Ferunt
us Offline SAK Guy
Reply #1592 on: June 25, 2015, 05:59:07 AM
I love mine.
That's us mobile
I forgot to ask you Nate....is it holding up well...keeps a good edge in the field? You use it camping and such? How is the blade coating holding up?
- Robert
Quo Fata Ferunt
mc Offline Gerhard Gerber
Reply #1593 on: June 25, 2015, 09:53:02 AM
Forget about "might be"....will be!  8)
Last weekend used pliers to remove the worn ferro rod, some superglue and the replacement went into the handle that comes with the knife.
When I'm out camping it's the knife that's with me, don't actually wear it on my belt....because mostly I don't have a belt on, but it's fine shoved in my pocket.
Basically, when I leave the house it's become the #1 way to light anything from a BBQ fire to the LPG burner.......and it cuts stuff as well!  :rofl:
Don't know what carbon steel they use, but even with a lot of coating gone rust is not an issue so far.
Reply #1594 on: June 25, 2015, 09:56:30 AM
BTW, if you put me on the spot I'd say I collect large fixed blades....
Using Moras and seeing (just pics) Bark River Knives probably changed that.....  8) :D
Reply #1595 on: June 25, 2015, 01:52:44 PM
I love mine.
That's us mobile
Anytime I go into the woods or go hunting, I take my Bushcraft Black. It is my go to outdoors knife. It is straight up a tank. Holds a good edge for a long time. Easy to sharpen. The coating is holding up very well. The coating on the edge will be lost the first time you sharpen it. Makes the knife look even better. Got a two tone thing going on. The spine is sweet for ferro rods and so far with all the scraping on the ferro rods and wood, the coating is hold up rather well. It will baton wood,  clean game and do fine carving. If I had to go the into wilds with only one knife, the Bushcraft Black would be my choice.
That's us mobile
us Offline SAK Guy
Reply #1596 on: June 25, 2015, 03:46:15 PM
Thanks guys for the glowing reports....going to cut some stuff today (hopefully) and see how my microbevel holds up...it sharpened up really easy.  :2tu:
- Robert
Quo Fata Ferunt
Reply #1597 on: June 25, 2015, 04:15:13 PM
You micro beveled yours?
That's us mobile
Reply #1598 on: June 25, 2015, 04:58:04 PM
+1 ??
I've got the model with the diamond sharpening jobbie on the sheath, and just with that the scandi is easy enough to maintain.
I'm by no means an expert, but if I think of the mechanics of a scandi grind and using/sharpening it, the micro bevel can only mean more work re-profiling later......?
Reply #1599 on: June 25, 2015, 05:07:52 PM
I've only ever touched up the micro bevel on my Puukkos, and have (thankfully) never needed to remove metal from the whole primary grind. My oldest knife has done a lot of gardening, DIY tasks, fuel processing/kindling prep and I think I can still get a few more touch us sharpenings from it before I'll need to consider working the entire flank, as the micro bevel isn't as micro as it used to be. No detriment to performance though
us Offline SAK Guy
Reply #1600 on: June 25, 2015, 05:17:56 PM
That's us mobile
Forgive me if I'm over explaining or telling you something you already know. :salute:
It's a fancy word for saying I put a regular edge on it just like my other knives. On scandi grind knives (like Moras) you are supposed to lay them flat on the grind and sharpen (like you do I think) and that maintains the factory edge and grind. Works great!!! It maintains the "zero grind" edge that most Moras come with.
On my Moras, I steepen the angle slightly when I sharpen so it makes a small secondary edge that is still extremely sharp but (reportedly) less prone to chipping/rolling. It's a thoroughly discussed topic on bushcrafting sites and helps smaller scandi grind knives maintain their edge better...I discovered that second hand as that was the way I have freehand sharpened for 40 years and only recently found out that there was a name for it. Frankly, it's the only way I know how to sharpen and works on everything I have. I'm too old (and crotchety) to learn something new!  :D
Sounds like it is unnecessary on that big robust Bushcraft Black!!
Here's a pic of my edge......
- Robert
Quo Fata Ferunt
mx Offline Dragon Lord
  • Follow your dreams they would lead you to happines
Reply #1601 on: June 25, 2015, 05:55:56 PM
Pocket Shiv
Reply #1602 on: June 25, 2015, 08:15:41 PM
Quote
 :cheers: no arguing with experience
us Offline SAK Guy
Reply #1603 on: June 25, 2015, 08:40:40 PM
Quote
 :cheers: Thanks!  :salute:
- Robert
Quo Fata Ferunt
Reply #1604 on: June 25, 2015, 08:45:41 PM
That's us mobile
I meant more if it came that way or did you do it yourself. Still, thanks for the info!
That blade looks good sharpened that way. I just sharpen the whole edge. They are very easy to sharpen I think. No guess work on the angles or anything like that. Just place it on the stone and go for it.
That's us mobile
us Offline SAK Guy
Reply #1605 on: June 25, 2015, 11:01:01 PM
That's us mobile
That's us mobile
 :cheers:  I've seen Ray Mears use that technique on youtube!  I bet yours is sharper than mine doing it that way and you're right, simple is better esp in the field! :2tu:
- Robert
Quo Fata Ferunt
Reply #1606 on: June 26, 2015, 12:59:56 AM
I bet yours is just as sharp if not sharper.
That's us mobile
Reply #1607 on: June 26, 2015, 09:18:40 AM
I shared what I think about the knife, and considering the name and some of the uses mentioned here, I couldn't help but think about what I've used it for.
There is a massive price difference between the straight knife and the model with the ferro rod and the sharpener, and to be honest, if I didn't get mine with 40% discount it wouldn't have been worthwhile...
The only bushcrafty things I've used it for is:
1. making a quick spatula from a stick to stir the scrambled eggs....once
2. cleaning a fish....once
3. Starting fires. This accounts for 80% of it's use.
The rest is a bit of food prep, and cutting whatever needs to be cut, simply because it's there.
The reason why I use it to make fires is simple - just some practice. Some places it's easier than others, in the South the peeling Commiphora bark catches a spark very nicely, dry grass is pretty like petrol, but funny enough feather sticks with most of our wood is a waste of time...
I hate that one day that very comfortable handle will perish and fail. ;)
us Offline Dale
Reply #1608 on: June 28, 2015, 11:47:04 PM
A few new additions
I'm thinking of the immortal words of Socrates.. He said.. " I drank what?"
Reply #1609 on: June 29, 2015, 12:16:11 AM
That's us mobile
Reply #1610 on: June 29, 2015, 01:19:42 AM
I'm liking the one on the left Dale. Who made it?
us Offline SAK Guy
Reply #1611 on: June 29, 2015, 02:24:43 AM
Fantastic blades!!!!!!!  :salute:
- Robert
Quo Fata Ferunt
us Offline Dale
Reply #1612 on: June 29, 2015, 02:33:06 AM
Thats the Habilis Bushtool
hr Offline styx
Reply #1613 on: June 29, 2015, 09:54:57 AM
Which BRKT is that?
us Offline Dale
Reply #1614 on: June 29, 2015, 02:11:27 PM
hr Offline styx
Reply #1615 on: June 29, 2015, 04:22:08 PM
Sweet
Reply #1616 on: July 01, 2015, 10:43:51 AM
Reply #1617 on: July 01, 2015, 10:44:16 AM
no Offline Grathr
Reply #1618 on: July 01, 2015, 07:37:08 PM
Nice pics! :tu:
us Offline SAK Guy
Reply #1619 on: July 01, 2015, 08:56:56 PM
Great pics Z!!!!! :cheers:
- Robert
Quo Fata Ferunt
