Bending a LM tool
be Offline Rebelgium
Bending a LM tool
on: February 06, 2018, 04:41:15 PM
Hi there,
I'm making a custom MT and for this project I need to bend a LM can opener tool.
I just want to bend it sideways, by about 10°, and the bend distributed over the entire length of the tool. A very easy bend.
Well, it should be very easy at least. If we we talking plain steel/copper/most metals
The other requirement is that the tool doesn't lose its hardness. This is crucial as I intend to sharpen one of the edges of this can opener, and ofcourse I'd like it to stay sharp as long as possible.
So in conclusion I need to
1 ) Determine exactly what type of steel a LM can opener is made from
2 ) Then I can look up the appropriate way to bend it. ( Heat? To what temperature? Bend when hot or once it has cooled down? Or bend when cold? Is work hardening g an issue? ... )
3 ) Look up how to re-harden the tool ( IF it had to be softened first to do the bend in the first place)
So far I'm still stuck on number 1.
There are many types of stainless steels, and each have different ways to bend and/or heat treat them...
Anybody with knowledge on any if these three points?
Anybody who has bent These/similar tools before?
Thanks
us Offline Lynn LeFey
Re: Bending a LM tool
Reply #1 on: February 06, 2018, 04:53:16 PM
Zachary Fowler discusses how he turned the can opener on his Victorinox Spirit into a spoon gouge. I've set the time stamp to where he discusses this particular mod. TLDR: Heat until cherry red, hit with hammer. You can't take Spirits apart, but you CAN take Leatherman tools apart. I'd recommend doing that if you intend to modify the can opener by heating it to glowing red.
What >I< would personally do is remove the can opener from the rest of the tool, heat, shape, then heat again, using a magnet to test to make sure that you're heating it until the magnetic attraction goes away, then quench in water/oil. This will make it HARD. Then put it in an oven at 450 for a few hours to temper. I don't know what steel it's made of, but that's pretty standard for any tool you want to have a cutting edge. Whether or not it will WORK...  :think:
00 Offline Mechanickal
Reply #2 on: February 06, 2018, 05:00:40 PM
Want to bend a tool?
Pablo O'Brien is the man to talk to here! 8)
Reply #3 on: February 06, 2018, 06:56:26 PM
Leatherman uses 420HC on their blades , maybe something else for the can openers 440  :think:
« Last Edit: February 06, 2018, 08:25:12 PM by SteveC »
Reply #4 on: February 06, 2018, 07:03:02 PM
If you hit with a hammer, it'll just snap off. You'll have to heat it up with a torch first. Good luck!
Or like Mechy says, get Pablo to do it!
Reply #5 on: February 06, 2018, 07:05:03 PM
Leatherman uses 420HC on there blades , maybe something else for the can openers 440  :think:
I imagine it will be 420 for everything, I wouldn't think they would change stock for a can opener... or would they?  :D
tr Offline ddogu
Reply #6 on: February 06, 2018, 08:10:54 PM
Doesn't heating steel make it "un-steel"? AFAIK heating up a hardened and processed steel makes interferes with the molecular structure and softens it. :think:
Reply #7 on: February 06, 2018, 08:34:32 PM
Yeah I imagine it will, but there is no other way that I can think of. If indeed leatherman do heat treat components like can-openers etc...?  :think:
« Last Edit: February 06, 2018, 08:40:10 PM by Fuzzbucket »
Reply #8 on: February 06, 2018, 08:44:07 PM
Whatever metal/tempering Leatherman uses, the metal tends to snap, not bend. I've seen a lot more broken implements than severely bent ones on Leatherman tools. So, yes, heating would be crucial.
Reply #9 on: February 06, 2018, 08:53:35 PM
It's a horribly distinctive sound when they ping off too... (gulp)...
Reply #10 on: February 06, 2018, 09:16:39 PM
I broke the file on a Wingman TWICE, and the phillips on a Micra. I know the 'ping' all too well. :D
us Offline Kampfer
  • Tactical Desk Jockey
Reply #11 on: February 07, 2018, 12:33:00 AM
Everything is 420, Blades are 420HC
Reply #12 on: February 07, 2018, 10:37:07 AM
Hi there,
Which size/type LM can opener, Wingman, Wave, Surge, OHT, other?
Bend to which side, left or right?
Reply #13 on: February 07, 2018, 11:08:17 AM
Hi there,
Wave size. I'll bend it to the left (looking from the top of the tool)
Reply #14 on: February 07, 2018, 11:12:02 AM
My speculation: A file will be hardened, but not tempered. Leaving it very hard (as a file should be) but brittle.
I think a canopener will be tempered. That is, if it is hardened at all. So a canopener *should* be less brittle
Reply #15 on: February 07, 2018, 11:12:25 AM
Hi there,
Okay, no promises but if I can find a couple spares and some free time at work next week I'll do some testing.
Reply #16 on: February 07, 2018, 01:02:21 PM
Hi there,
That would be great! Very interested in the results.
I'd do some testing too but I have no spares, it's a one shot deal.
I've done some measurements and I need to make a correction: I'd bend the last 18mm by 20° to the left side. By the last 18mm I mean the tip of the tool, the hinge needs to stay straight.
« Last Edit: February 07, 2018, 01:11:44 PM by Rebelgium »
Reply #17 on: February 07, 2018, 01:05:50 PM
Hi there,
wales Offline hiraethus
  • I brake for cake
Reply #18 on: February 07, 2018, 02:08:35 PM
Give it a go with the one you have - if it snaps I'll send you a replacement.
us Offline ironraven
Reply #19 on: February 07, 2018, 10:29:43 PM
Maybe a sketch is in order so we can get some idea of how far you're trying to bend it. And what you're trying to fit it into.
Reply #20 on: February 08, 2018, 10:55:21 AM
* IMG_20180208_104903.jpg (Filesize: 105.69 KB)
Reply #21 on: February 08, 2018, 12:35:48 PM
Btw, off topic...
Re"belgium"?
There are others??! :ahhh :ahhh
be Offline Top-Gear-24
Reply #22 on: February 08, 2018, 01:38:24 PM
Btw, off topic...
Re"belgium"?
There are more of us out there than you'd think, but most of us are "the quite type" ...  :pok:
Reply #23 on: February 08, 2018, 01:41:31 PM
Btw, off topic...
Re"belgium"?
Brilliant!  :rofl:
Reply #24 on: February 08, 2018, 04:27:42 PM
Btw, off topic...
Re"belgium"?
Quite?
I don't think your spelling was quite right there! :pok:
And if you want me to stop posting, all you've got to do is ask :think:
Reply #25 on: February 08, 2018, 08:21:06 PM
Btw, off topic...
Re"belgium"?
Quite?
So, your best defence is pointing out a typo ...  :think:
Cause that's what it was, a typo ...  Since I only made that mistake once, if it was a spelling problem I would've made the same mistake more than once ...  :whistle:
Usualy with LCD watches, when the battery is so far gone that the light doesn't work, the writing usualy goes nearly invisible during the time of the lighting.
I know a guy who's willing to let his MINT mechanical SAK go for 150 including the Victorinox sign hovering above it (attached at the back of the SAK with see through plastic) which is usualy missing.
Usualy I try not to charge anything for people who were in real need (like the older woman who can't do it herself) but they always want to give me something.
But usualy because I regret what I typed...
These could be typos ...
Carrying the Spirit again.
Usual carry in the weekends.
Naturaly in my Skinth :D
... Mine is actualy navy blue, but for the Skinth it's a great colour.
Fits with lots of other colours and doesn't make me look like a mall ninja :D
No need to stop posting, I was just messing with you mate  ;).
Oh, and have you noticed ... ?
Reply #26 on: February 08, 2018, 08:31:05 PM
Why do people never point that out to me?
I can't evolve forwards if everyone is like "I'm to polite to say anything about his foul spelling" :facepalm:
Reply #27 on: February 08, 2018, 08:40:05 PM
There are no grammar n*zis here mate, as long as we get what's being said, it's all right  ;).
Reply #28 on: February 08, 2018, 08:48:50 PM
Quiet right old boy !   :D
Reply #29 on: February 08, 2018, 09:20:01 PM
You've seen MY posts... right? And I'm at least in theory a native English speaker. (In fact, I am actually a native 'redneck midwesterner' speaker. I just try to hide it)
Total Receipts: $168.99
PayPal Fees: $9.87
Net Balance: $159.12
Below Goal: $140.88
53%
