CRX Brass Tiny XM-L2
CRX · 9 · 995
gb Offline CRX
on: February 23, 2018, 03:30:08 PM
Here's a big one  :D
Measuring in at 16mm x 8mm, powered by three button AG4/377 cells, XM-L2 emitter and all soldered brass construction.
This is a twisty light and works by the outer casings being filed at an angle so when it is twisted contact is made by the ends coming closer together, same principle as those hinges that raise the door as they open.
Max – 10lm
Current – 20 mA
Length – 16mm
Width – 8mm
Weight – 5 grams (with cells)
Re: CRX Brass Tiny XM-L2
Reply #1 on: February 23, 2018, 03:44:57 PM
Awwwwww!  :like:
Where do you get your brass bits from?
wales Offline magentus
  • mmmmm SAKrelicious
Reply #2 on: February 23, 2018, 03:48:55 PM
 :like: very much!  :cheers:
Reply #3 on: February 23, 2018, 03:49:32 PM
I see that you are at the budget light forums.  :)
I signed up recently.
Reply #4 on: February 23, 2018, 03:50:59 PM
gb Offline CRX
Reply #5 on: February 23, 2018, 04:05:59 PM
Awwwwww!  :like:
It's K&S brass tubing, can be found on various auction sites/ modeling shops.
gb Offline CRX
Reply #6 on: February 23, 2018, 04:06:48 PM
Cool  :cheers:
Reply #7 on: February 23, 2018, 05:42:08 PM
Nice - I just use BLF for shopping hints
Reply #8 on: February 23, 2018, 11:03:29 PM
Wow  :drool:
