Does this Flashlight count as a multitool?
ca Offline Walley
on: March 11, 2018, 04:47:51 AM
I finally received all of my pieces to assemble my new EDC flashlight/lighter and i'm lovin it!
I am not much of a flashlight collector, but I love EDC and I have been into a brass fetish lately and started smoking cigars again.. so this little thing checked all of my boxes.
It's the DQG Hobi PLUS 10180 XP-G2 USB Rechargeable Mini LED Flashlight, which is sold as a tiny keychain flashlight with the 10180 battery but really its a modular system. I haven't seen much mention of it here.
I also got the DQG Lighter 2.0 with 3 extension tubes plus one extension with incomplete hole and connected them together.
now it holds double the fuel capacity and takes a 10440 battery.
it's a nice color beam with 3 settings. 3.5LM,15LM,120LM
* complete.jpg (Filesize: 91.97 KB)
* dual purpose.jpg (Filesize: 156.97 KB)
* battery compartment.jpg (Filesize: 98.35 KB)
* charging port.jpg (Filesize: 99.48 KB)
ca Offline Walley
Re: Does this Flashlight count as a multitool?
Reply #1 on: March 11, 2018, 04:50:51 AM
I did age the brass a bit to have it blend in with my other EDC quickly.
as you can see its nice and slim and not much bigger than a fisher space pen.
my EDC for the past year
* edc.jpg (Filesize: 147.69 KB)
us Offline Old Boy
Reply #2 on: March 11, 2018, 05:58:37 AM
That is awesome and you truly have more skills than I do. I’m not trying to be downer, but be a bit careful ok? Not sure if having any extended flame or heat exposure could make the battery leak or explode.
I’m not an engineer so maybe I’m a bit overly cautious. Just don’t want you to lose your fingers 😉
  • Bored
Reply #3 on: March 11, 2018, 05:58:53 AM
The idea of a multitool is of a tool that can perform more than one function, by design.  A hammer, a screwdriver with a few bits, a light that just lights are not considered multitools.
Nice looking light.
ca Offline Walley
Reply #4 on: March 11, 2018, 06:18:14 AM
Nice looking light.
but this does perform more than one function, its a flashlight that is also a lighter! and a tool that I use both functions multiple times a day at work and play.
Quote
it seems pretty safe, the flame is opposite end of the flashlight separated by one of the extensions that has a solid brass wall, what they call an "incomplete hole" meaning the hole doesn't go all the way through.
I also used locktite on the sections that I don't want to come apart and some plumbers pipe sealant on the section that I open to refill the lighter. each section also has Orings so its water tight.
us Offline gerleatherberman
Reply #5 on: March 11, 2018, 08:19:38 AM
Frank,
I vote it is a multitool. Reasoning is the same as yours.  :)
Thank you for posting in detail about it! I also carry a flashlight and lighter, so that is an appealing combo.
Playing devil's advocate, some members  on MT.o will consider it a multi-functional device and not an MT. Some do not consider a light source as a tool. Which I understand, but tend not to agree with.
But, in a modern sense of what a tool is, it should be considered a multitool..IMO of course. :tu:
« Last Edit: March 11, 2018, 08:21:04 AM by gerleatherberman »
Reply #6 on: March 11, 2018, 09:49:59 AM
It looks very nice.  :like:
A rose, by any other name.... would still smell just as sweet.
ca Offline Walley
Reply #7 on: March 11, 2018, 04:09:37 PM
i feel that lighters and flashlights are both tools on their own.
here are some tool deffinitions that fit well imo.
1. a handheld device that aids in accomplishing a task
2.an instument used in performing an operation or necessary in the practice of a vocation or profession. a scholar's books are his tools
so if we can establish that a flashlight and a lighter can each fit the deffinition of a tool, and combining both into one package has it fit the deffinition of a multitool.
then i guess that descibes it and I can include it in my collection of MTs.
us Offline Captain Hook
  • Don't read this......You rebel you ;)
Reply #8 on: August 20, 2018, 06:58:10 AM
Hmm, idk if I'd want lighter fluid that close to battery acid...
Cool Idea all the same though :popcorn:
~Formerly _MattGyver_ ~
Reply #9 on: August 20, 2018, 11:04:55 AM
What exactly is the problem with having a lighter near a battery?  ???
The best of MY limited knowledge says that there are no safety concerns with this particular configuration, so if someone can explain to me that would be great.  :cheers:
Reply #10 on: August 20, 2018, 04:04:28 PM
I can’t see a problem  :think:
Nice flashlight/ lighter :like: :tu:
Reply #11 on: August 20, 2018, 08:42:58 PM
Well, it's just a personal phobia. I used to handle leaky batteries at an old job of mine.  Looks like a cool idea for an mt though. Could it fit in altoids survival kit?
Reply #12 on: August 20, 2018, 09:18:09 PM
There are different kinds of batteries.  :tu: What kind did you work with?
Eneloops? If I threw one in the fire, I would be fairly confident that there would be no boom.  ;) a puff maybe.   :think:
I believe that Walley is using lithium batteries?  :think: if they are a good brand and not over-stressed, no leakage should happen.
I believe he said the battery compartment is completely separate from the lighter portion anyway.   :think: :tu:
Total Receipts: $168.99
PayPal Fees: $9.87
Net Balance: $159.12
Below Goal: $140.88
53%
