Quote from: NutSAK on November 14, 2008, 02:04:35 PMFrom the , I assume that you think it is for another reason?Not at all... It's just that this rationale reminded me of this... As for the "better access for a right-handed individual" bit, I can totally understand what you're talking about; however, it makes no sense to me. Since you use a nail knick to open the blade, it could as well be the other way around (it's not an OH configuration). Actually this is were this all started for me. I decided to mod a couple of SwissTools I have lying around to make them OH openers and only then did I realize their blades are no good for that... unless I were a lefty.
Most right-handed individuals are used to holding a tool (knife, multi, etc.) with their right hand as if they are going to use it. They use their left thumb nail to open the blade. With this configuration, a right-handed individual doesn't ever have to change their grip on the tool.If the Swisstool's knife were on the other side of the tool, how would you open the blade, using your thumbnail, without switching the tool to your left hand, then having to switch it back after opening it? The nail nick would have to be on the other side of the blade.
Now, about the can opener configuration on SAKs and how it affects the position of the blade.... It's a little more logical that you might think. It is designed to always be on the "left" side of the knife so that it operates best to open cans, (for right-handed people) regardless of the model of the knife. Therefore, the main blade is always "behind" the can opener on a SAK. If the configuration was reversed to have the can opener on the other side of the knife (behind the blade as you hold it in your right hand), how would the can opener work on wide knives like the Swisschamp? It wouldn't.
Wait though... If you paired the large blade with the can opener, the blade would be on the wrong end of the knife!
Some gimp'ing later:(Image removed from quote.)
That looks like it would work, but the nail nicks for the cap lifter and can opener would then be on the "back" side of the knife, instead of being on the same side as the large blade. I think it might bother me also comfort-wise, since the large blade hinges on the "fat" end of the knife.
I guess I should ask... Why is it important to you to have the blade on that side of the knife?
