Sharpening help.
RF52 · 63 · 2558
00 Offline Mechanickal
Re: Sharpening help.
Reply #30 on: March 23, 2018, 09:53:00 PM
Dang my copy of the deluxe system looks close to the real deal...
I think that is a good thing
What does the stone side look like?
I'll put up a pic tomorrow for you
Great!
I'll post comparison pics thereafter.
Cool How much did your version cost if you don't mind me asking?
Complete set + delivery at my doorstep: €15
se Offline RF52
Reply #31 on: March 23, 2018, 09:57:26 PM
Great!
Can't really beat that price But since I'm a bit impacient at times I bought mine at a sport/outdoors store so I could get it right away and go home and try it
Reply #32 on: March 23, 2018, 09:59:49 PM
Great!
No need to explain why you bought the real thing when I bought a knock-off...
se Offline RF52
Reply #33 on: March 23, 2018, 10:02:08 PM
Great!
Haha, maybe you are right
Reply #34 on: March 23, 2018, 10:41:19 PM
Excellent kit RF52!  :salute:
« Last Edit: March 23, 2018, 10:42:30 PM by Fuzzbucket »
se Offline RF52
Reply #35 on: March 23, 2018, 10:43:59 PM
Thanks Very pleased with how well it functioned
se Offline RF52
Reply #36 on: March 25, 2018, 09:12:51 PM
Here are photos of the stone side with and without flash, hopefully you can see something
mc Offline Gerhard Gerber
Reply #37 on: March 26, 2018, 05:29:18 PM
My Lansky setup & accessories....including DIY stand made using a drill bit  :whistle:
Reply #38 on: March 26, 2018, 05:39:23 PM
Oh right,
My turn!
The box as delivered:
Cardboard coverbox removed:
Box opened and protective foam + manual removed:
Stones reversed:
se Offline RF52
Reply #39 on: March 26, 2018, 07:14:57 PM
I need to make a stand for mine too looks good
se Offline RF52
Reply #40 on: March 26, 2018, 07:16:51 PM
Oh right,
My turn!
Stones reversed:
Looked very similar And as long as it's working the way you want it doesn't matter what it is
us Offline Marcellus
  • What does Marcellus Wallace look like?
Reply #41 on: March 27, 2018, 03:46:11 AM
Good choice. You're all set for the majority of blades.
The smaller pen blades can be a challenge if you set the fixture on 17 or 20 degrees, but can usually be sharpened at 25 degrees.
The blade will still get plenty sharp.
Use the sharpie method to check if you are honing the edge.
Practise and use your thumb or eyes to " chase the burr".
id Offline jaya_man
Reply #42 on: March 27, 2018, 08:48:47 AM
I also use the Lansky Deluxe Sharpening System... So far its working great for me... I’ve used it to sharpen my SAKs (except the 58mm), MT’s, folders and kitchen knives... and strop afterwards...
Seldom use the extra course hone except when I need to reprofile edges... The coarse hone I use on blades which have been used regularly... otherwise, its normally just the medium to extra fine hones for touch-ups...
Also thinking of getting the special hone for serrated edges...
se Offline RF52
Reply #43 on: March 27, 2018, 09:03:02 AM
Great
Reply #44 on: March 27, 2018, 02:43:05 PM
When I started looking at Lansky  I figured I'd buy the basic kit and then get those rounded stones for recurves.....which I "need" for my Kukri  :facepalm:
After getting the 4 diamond stones I feel a bit over-invested, plan on rather getting a Spyderco Sharpmaker, and where that doesn't work the belt grinder will have to suffice.
Offline aikon2014
Reply #45 on: March 27, 2018, 02:55:33 PM
I do recommend freehand as well, just so you learn it abd get a feel for it, ypu can use your Lansky stones for it. And also learn stropping! Do NOT underestimate the power of the strop  :D
Especially if you have a couple of them with some compound on one of them!
se Offline RF52
Reply #46 on: March 27, 2018, 06:17:24 PM
I have been thinking of getting/making a strop or two
Offline aikon2014
Reply #47 on: March 27, 2018, 11:03:23 PM
I went to K-Rauta and got a plank which they even helped me saw into proper lengths, and then I ordered Bältes Läder at slojd-skinn.se at 4cm and just made strops with contact glue. Easy peasy! :)
I recommend this compound:https://www.sliqhaq.se/strigelpasta-micron-p-521.html?cPath=4_32_114
Just a size of a green pea will cover a rather big strop.
First strop with the compund and then strop with raw leather, then you can shave with it!
se Offline RF52
Reply #48 on: March 27, 2018, 11:33:14 PM
Thanks!
Reply #49 on: March 28, 2018, 11:40:13 AM
The Strop is powerful indeed  :salute:
Most of my sheaths are thermo-molded plastic covered with leather, people are amazed when I show them how to use the sheath as a strop.......they all think stropping starts and ends in a barber shop  :like:
Offline aikon2014
Reply #50 on: March 28, 2018, 07:40:30 PM
Yes, it is so underrated in my opinion! It is so powerful, imho at least as important as the sharpening/apexing itself.
se Offline RF52
Reply #51 on: March 28, 2018, 08:49:15 PM
Do you use the "rough" side or the smooth side of the leather to strop?
Offline aikon2014
Reply #52 on: March 28, 2018, 08:54:51 PM
I use both, don't really think that it matters because as far as I know, it's small silicon particles in the leather that does the "sharpening", so it should be equal whatever side. But I know that others like to put compound on the suede rough side because it sticks easier and do the raw leather stropping on the flat smooth side.
se Offline RF52
Reply #53 on: March 28, 2018, 08:57:03 PM
Thanks I have an old belt I'm going to make into a strop, should be long enough for a couple so I can try both and see
Offline aikon2014
Reply #54 on: March 28, 2018, 09:04:22 PM
I have an old belt I made into a couple of strops as well, works just as good as any other leather I tried!
Offline aikon2014
Reply #55 on: March 28, 2018, 09:05:18 PM
Btw, don't use that much pressure when stropping, the weight of the knife plus a tiny bit more, maybe 1.5-2X the weight of the knife is lagom!
se Offline RF52
Reply #56 on: March 28, 2018, 09:10:47 PM
Good to know
Offline aikon2014
Reply #57 on: March 28, 2018, 09:12:01 PM
Good to know
I don't know if I have to say it, but don't "cut" into the leather do it the other way, away strokes and use the same angle as when sharpening the knife, if you do 20 degrees each side when sharpening and putting the apex on the knife, use the same angle when stropping :)
se Offline RF52
Reply #58 on: March 28, 2018, 09:15:12 PM
Good to know
I knew about not cutting the leather but good info about the angle, didn't think about that.
Offline aikon2014
Reply #59 on: March 28, 2018, 09:22:47 PM
Good to know
And most of all, even with very little stropping you will usually notice a huge difference!
