Swisstool Spirit Upgrade
00 Offline Sam Lim
on: March 25, 2018, 09:52:16 PM
Always wanted to do this but have not got the time..
Spirit is an excellent tool but the wire cutters had always been something I really dislike.. Its simply does not cut properly. I had mine that's used and the cutters are pretty much busted. So it gave me an excuse to tear it apart.. :P
Fitted in a LM Plier head. Fitting is done. Problem faced - pivot size, back spring etc.. many challenges to overcome.. Already have an idea of where to get a proper pivot screw once I am happy with how it holds up.
Its a bit unfinished, 3am here.. have to Zzzzzz.. At the moment, its fully functional. Taking it for a ride tmr at work.
Pivot problem solved with bushing. Took me 3 hours to make the 2 bushing!! Super primitive method!!  :facepalm:
Pliers tip need some re-profiling work to close it properly.
00 Offline Mechanickal
Re: Swisstool Spirit Upgrade
Reply #1 on: March 25, 2018, 10:55:35 PM
Nice job!
Apart from a strange brand combo :D
00 Offline Sam Lim
Reply #2 on: March 26, 2018, 01:09:48 AM
Nice job!
Carry a leatherman for its pliers, Vic for tools.. Best of both worlds?  ;) ;)
se Offline stoneshank
Reply #3 on: March 26, 2018, 02:25:03 AM
Leatherinox splurt?
~ if you're not good, be creative ~
00 Offline Sam Lim
Reply #4 on: March 26, 2018, 02:35:42 AM
Leatherinox splurt?
Victoriman Lirit sound better?..
Reply #5 on: March 26, 2018, 03:01:56 AM
Very nice work Sam :clap: I :like: it :cheers:
us Offline gerleatherberman
Reply #6 on: March 26, 2018, 03:08:29 AM
Very brave of you, Sam! Nice idea and looks cool so far! A definite upgrade.
Why Vic has not changed the micro wire cutters on the swisstools...I'll never know.
I would likely vomit if I knew I just nullified the warranty.  :ahhh
At least when you mod LMs and Gerbers, most mods can be reversed for warranty work. Edit: I even have spare plier heads for my blunted MTs.
Hats off to you, Sam! :hatsoff:
00 Offline Sam Lim
Reply #7 on: March 26, 2018, 04:15:55 AM
Here, warranty is almost non existant unless purchases are from authorised dealers at exorbitant price. Vic I have never really check out how the warranty works. But even if I were to send it in and they replace one or fix it, it still a plier cutter that I will have difficulty using. So.. I am fixing things that are already broken. No losses if I can't fix it.  ;)
00 Offline Sam Lim
Reply #8 on: March 26, 2018, 04:23:27 AM
 :hatsoff: still quite a bit of detailing work to be done. I was thinking if I were to enlarge the holes to 5.5mm would that be easier.. But without proper press drill, I doubt I can perfectly align all 4 layers per handle.. That would be 8 holes to drill through.  :ahhh.. I chose the bushing over drilling.. If this pliers breaks, one with replaceable cutter will take its place..  :D
Reply #9 on: March 26, 2018, 04:31:22 AM
Excellent points!
I bet there are some Spirit fans out there that are cringing. :rofl:
00 Offline Sam Lim
Reply #10 on: March 26, 2018, 05:19:14 AM
Excellent points!
I believe so.. I think there are quite a number of die hard Spirit fans...
Reply #11 on: March 26, 2018, 05:45:41 AM
 :like: :tu:
wales Offline hiraethus
  • I brake for cake
Reply #12 on: March 26, 2018, 06:10:21 AM
Adding a Leatherman pliers head to a Spirit is not an upgrade. :twak: :P
00 Offline Sam Lim
Reply #13 on: March 26, 2018, 06:14:08 AM
Lol... A die hard fan just cringed.  :rofl:
Your BO spirit is safe. Not to worry. That's one of my baby.
« Last Edit: March 26, 2018, 06:15:48 AM by Sam Lim »
00 Offline Sam Lim
Reply #14 on: March 26, 2018, 06:16:35 AM
:like: :tu:
 :tu: thanks! Congrats on your promo stevie!
Reply #15 on: March 26, 2018, 06:22:52 AM
Very true! It's a BIG upgrade . :drink:
00 Offline Sam Lim
Reply #16 on: March 26, 2018, 01:06:42 PM
Finished my day with just this MT. Its honestly the first time I carried only a Spirit as a MT with me. Before this, I simply cannot live with the original set of pliers. Sorry Vic.. Paired with a separate utility cutter, OHO doesn't quite matter anymore.  :) it truly carry a good set of quality tools.
Reply #17 on: March 26, 2018, 01:26:38 PM
I'm in the fence where the best intro multitool is. I know SAK's, and I got a Leatherman squirt that does a good job but... Yeah
Reply #18 on: March 26, 2018, 06:11:11 PM
That's wicked!  :drool:
I'd like to see the faces of LM and Vic representatives when they see this.  :like:
Reply #19 on: March 26, 2018, 06:12:15 PM
Leatherinox splurt?
All of a sudden gerleatherberman's username makes sense. :salute:
00 Offline Sam Lim
Reply #20 on: March 26, 2018, 06:58:31 PM
They will become best of buddies forever..  :drink:
Yes, Gerleatherberman doesn't sound so weird now...
00 Offline Sam Lim
Reply #21 on: March 26, 2018, 07:13:12 PM
Some updates on this..
Did a little bit of work on the pliers tip to let the handles close properly..
Some hiccup on the pivot screws I had in mind... Its too short. But I found this instead. The smooth area is the exact length I need. Still fastened by bolts, but that doesn't bother me.
 :multi:
Reply #22 on: March 26, 2018, 08:52:01 PM
Looking great!
00 Offline Sam Lim
Reply #23 on: March 27, 2018, 12:44:16 PM
Looking great!
 :salute: works and behave just like a stock plier. With way better wire cutter.  :)
Reply #24 on: March 27, 2018, 12:46:08 PM
And now you have a Rebar with Spirit pliers? :dd:
es Offline ThePeacent
Reply #25 on: March 27, 2018, 01:20:56 PM
is the triple scratch mark there to know which side of the tool are you looking at?  :think:
My toys:
00 Offline Sam Lim
Reply #26 on: March 27, 2018, 01:30:39 PM
That would be a downgrade?  :whistle:
Reply #27 on: March 27, 2018, 01:31:53 PM
00 Offline Sam Lim
Reply #28 on: March 27, 2018, 01:32:15 PM
That's so smart of you! Yes, till I did this, I never remember where is the knife, scissors etc....  :facepalm:
00 Offline Sam Lim
Reply #29 on: March 27, 2018, 03:36:46 PM
OK, let's be fair. Any spirit users that really think that the original pliers head is superior, pls do kindly shout out why.
I personally find it rather difficult to use. Apart from the strange design of the wire cutter, the pliers tip are neither Blunt nor needlenose.  Making both tasks quite a challenge. Btw, does anyone else notice at the hard wire notch, there is a intentional gap between the teeth. I can never figure out why is that built in such a way.
