Swisstool Spirit Upgrade
00 Offline Mechanickal
Re: Swisstool Spirit Upgrade
Reply #30 on: March 27, 2018, 03:40:57 PM
My only complaint is the difficulty to cut stranded wire.
00 Offline Sam Lim
Reply #31 on: March 27, 2018, 04:52:21 PM
In Vic defence, I do have another SS spirit that snips thin gauge stranded cleanly on the soft wire cutter. Max I have tried up to 1.5mm2 wire. Anything thicker it will wander into the hard wire cutter region and locks up the pliers.
00 Offline Sam Lim
Reply #32 on: March 28, 2018, 04:19:57 AM
Lerit will be the name.  :cheers:
Lerit had held up pretty well. 3rd day in and pretty darn happy with her.  ;)
us Offline gerleatherberman
Reply #33 on: March 28, 2018, 05:13:58 AM
Awesome news, Sam!   :cheers:
us Offline NetsNJ
Reply #34 on: April 01, 2018, 08:28:58 PM
I'm loving the Phillips headed plier pivot.   :salute:
00 Offline Sam Lim
Reply #35 on: April 02, 2018, 05:32:19 AM
The bolt of this screw occasional gets caught in my sheath.. I had changed them to a barrel screw. Found it in my bin of salvaged parts. I cannot remember which tool it came from....... It have exactly the correct length I need. A while ago, someone posted a link for the post screw from amazon. I bought that but it was too short to go through 4 layers...
us Offline twiliter
Reply #36 on: April 02, 2018, 09:48:14 PM
I have wondered why the length of the cutters is not bigger on the Spirit, in fact I would gladly sacrifice some of the jaw depth if the cutters were were aroud 30% longer, so this is an upgrade of sorts and very clever, well done Sam!  :cheers: That being said, I do seem to manage fine with the Spirit cutters as I use them only incidentally, sometimes having to make multiple cuts to get through things like 10 gauge Romex or 2 strand barbed wire. They seem to work fine for me on multi-stranded wire and insulated shielded wire like coax cable pretty easily, but sometimes I end up finishing the cut with the scissors when there is some insulation or a strand or three that doesn't get cut completely through. The bypass style of cutters (found on all MTs) is not as efficient generally (in my experience) as a good set of diagonals for any type of wire, which is what I use if I know I'm going to be doing any planned wiring or extended wire cutting. I do think the quality of the Spirit pliers is superior to the LMs, but that is more opinion than anything else, because aside from a challenge here and there I haven't really used the LM pliers as extensively as the Spirits. Also I prefer the plier shape to the LMs, which I find too pointy and narrow for my purposes, and have modded them to a more versatile tip, which I never felt the need to do with the Spirit.
The mod does seem to solve the cutter length compromise, but I think I will be keeping my smooth clickety Swiss Made tool intact.  :)
« Last Edit: April 02, 2018, 09:49:42 PM by twiliter »
00 Offline Sam Lim
Reply #37 on: April 10, 2018, 01:44:07 PM
Well, having the ability to disassemble and assemble will come the inevitable.  ;)
Reply #38 on: April 10, 2018, 01:56:00 PM
That is some bad ass modding right there. Awesome job!
es Offline ThePeacent
Reply #39 on: April 10, 2018, 02:43:58 PM
the best upgrade to the Spirit   :salute:
My toys:
Reply #40 on: April 10, 2018, 02:56:05 PM
 :like: :tu:
00 Offline Sam Lim
Reply #41 on: April 10, 2018, 03:10:52 PM
To be honest, the most headache part is solving the problem with the pivot size with what's available at home. The rest of the things are simply finding the right part and put them together.  :cheers:
00 Offline Sam Lim
Reply #42 on: April 10, 2018, 03:11:33 PM
 :salute: TP and Stevie!
00 Offline Sam Lim
Reply #43 on: April 13, 2020, 06:55:26 AM
Update.
Got a 91mm scissor into Lerit. Really have change out the original scissor as its use is very limited. It is a left hand scissor and it DOES matter. I do empathise with the lefties as most scissor are made for right hand use. In normal operation for a right hander, its extremely difficult to see what you are cutting.
Its really one of the more problematic mod I have done. Getting it to lock up, and close without the spring activating when stowed. If I had access to welding, it would be alot much easier as there's not enough material at the back of the 91mm to engage the back spring.  But the current lock down hinders movements and finding a welder. Went back the hard way again to work with what I have. Had to dump the can opener to give me a little more working space. Next, probably a OHO blade, or a diamond file?  :think:
Reply #44 on: April 13, 2020, 09:07:33 AM
Update.
Sam, great work!  I always think the 91mm scissors is better than the Spirit's.  For next iteration, may I recommend the OHO blade?  I know J-sews made one long time ago, but it's time to see some new iteration!
id Offline jaya_man
Reply #45 on: April 21, 2020, 03:48:25 AM
Top notch mod :like: :drool:
