This is interesting to follow. Quote from: Lynn LeFey on March 28, 2018, 10:24:37 PMOh... and it wouldn't help to replace the aluminum liners with brass, because then the stainless steel would be less noble than the brass, and the corrosion would most likely affect the stainless steel. So... Brass contains significant amounts of zinc, so chances are that the zinc in the brass would be eaten away first. Hence the general rule to avoid using brass submerged in seawater. (As opposed to some bronzes which are very good for just that). With galvanic corrosion the relative surface sizes of the metals matter a lot too in practical terms. So you can for instance use stainless steel nuts and bolts to hold together aluminium constructions, but the other way around would be bad.
No quit in this Lady!
Very nice work, Lynn! I have yet to get into SAK modding, but this thread has a lot of tips and tricks that inspires confidence with SAK modding!
Quote from: gerleatherberman on April 11, 2018, 05:25:08 AMVery nice work, Lynn! I have yet to get into SAK modding, but this thread has a lot of tips and tricks that inspires confidence with SAK modding! Honestly, a big thing that pressed me toward doing this was to encourage others to give it a try. I am BY FAR not the most skilled person at this kind of crafting. And I think if I can do it, most anyone with some effort and patience can.And a dremel... and a hand drill, and files. Oh, and hardened metal punches. Jeez... come to think of it, it's not just my collection of multitools that has grown since joining this forum. I have a pretty big collection of hand and power tools for working on MTs now. What I'd recommend is go on ebay, and look for those SAKs that beg to be saved/rehabbed. Get a couple for cheap(ish), and go for it. Absolute WORST case is you mess up already-messed-up tools. That was my plan, and it seemed to work out. I'd have to check but I think the three donor tools and additional parts cost me maybe $40 total. You can do it! It's like lego for MT addicts.
Really good job! Informative and motivational for all us "wanna-be-modders-who-have-lots-of-ideas-but-never-gets-around-to-realize-them" (or is that just me?)
Quote from: Toppskarven . on April 11, 2018, 06:17:23 PM Really good job! Informative and motivational for all us "wanna-be-modders-who-have-lots-of-ideas-but-never-gets-around-to-realize-them" (or is that just me?) I fall into that category too Sent fra min FRD-L09 via Tapatalk
Quote from: RF52 on April 11, 2018, 06:51:37 PMQuote from: Toppskarven . on April 11, 2018, 06:17:23 PM Really good job! Informative and motivational for all us "wanna-be-modders-who-have-lots-of-ideas-but-never-gets-around-to-realize-them" (or is that just me?) I fall into that category too Sent fra min FRD-L09 via Tapatalk Awesome, guys. I REALLY do hope this gets you hyped up to give this a try. Like I said, I think I failed in every imaginable way along the way, but it was a great learning experience.
Thanks all.I think I managed to find every conceivable way to screw up at every single step, ruining a few liners during disassembly, failing on the initial peening, so wasting precious pin stock, assembling wrong. It was absolutely a learning experience.
What are you planning Matt?
Quote from: magentus on April 14, 2018, 10:41:01 PMWhat are you planning Matt?+1, I want to know too! Whatever it is, it should be called the Mini Mattsman.
Well.... I'd like to replace the corkscrew on my Compact with a Phillips. But getting donor SAKs appears to be a bit difficult as eBay.com restricts SAKs being sold to Ireland But I found a source for the brass rods
Quote from: MTMatt on April 15, 2018, 01:24:26 AMWell.... I'd like to replace the corkscrew on my Compact with a Phillips. But getting donor SAKs appears to be a bit difficult as eBay.com restricts SAKs being sold to Ireland But I found a source for the brass rods I have a spare Philips knocking around.... it’s from my first SAK but I dislike the backside Philips so I don’t think that I’ll be using it.Gimme a shout if you want it.
