Multitool.org
Coil stove 665
Zombie Apprentice Posts: 17,693 Oxygen and magnesium toghether?! OMg!
Coil stove
« on: April 11, 2018, 06:44:51 PM »
The video is in portuguese but I think it's pretty easy to follow/understand. Any doubts, let me know.
 :salute: :tu:
https://www.youtube.com/watch?v=67INAPePf3M
Global Moderator Absolutely No Life Club Posts: 7,483
Re: Coil stove
« Reply #1 on: April 12, 2018, 09:48:47 PM »
That's a cool stove  :like:
No Life Club Posts: 1,263
Re: Coil stove
« Reply #2 on: April 13, 2018, 01:19:52 AM »
Does the wick go all the way through the coil? He places the pot straight on to or the coil too, by the look of the video. I'd think he'd get better results /efficiency if he raised it off slightly and not have the cold water draw heat out of the coil which is vapourising the alcohol. Approximately 8 minutes for how much water?
Re: Coil stove
« Reply #3 on: April 13, 2018, 12:25:13 PM »
He mentions "wicks", not wick. Maybe it's just a couple of them, one on each end, so the alchool vapors can be "pulled" onto the coil. It is first filled with sand so it can be bend without breaking or deforming. Then you remove the sand and pass the coil awl the way through the tube. This was just his first test. He said he just rested the pot over the coil with 400ml water +/-.
The black stuff is heat resistant epoxy glue.
Re: Coil stove
« Reply #4 on: April 13, 2018, 12:27:56 PM »
8 minute boil time is about the same as my trangia with bio fuel in it for around 750ml of water
Re: Coil stove
« Reply #5 on: April 13, 2018, 12:35:06 PM »
Maybe the advantage is that it used awlmost no alcohol.
 :think: :think:
Re: Coil stove
« Reply #6 on: April 13, 2018, 12:48:06 PM »
 :think: :think:
That would be a big advantage. The trangia can get through a lot of fuel
Re: Coil stove
« Reply #7 on: April 13, 2018, 12:55:02 PM »
 :think: :think:
Apparently, this think does run on fumes.
 :D :D
Global Moderator Abandon All Hope Ye Who Enter Here... Posts: 45,523
Re: Coil stove
« Reply #8 on: April 18, 2018, 05:30:02 PM »
Cool !   :tu:
or Hot !   :D
Total Receipts: $86.66
PayPal Fees: $5.67
Net Balance: $80.99
Below Goal: $219.01
Page created in 0.044 seconds with 33 queries.
© 2018 Defender Web & Tool
